Old 10-14-2007, 07:26 PM   #1 (permalink)
420Moment's Avatar
Default Ti spring
Anyone know where I can get a ti spring for a Marzocchi Roco rear shock?
Thanks
420Moment is offline
Old 10-14-2007, 08:29 PM   #2 (permalink)
Ride Therapy Patient
Default Ti coil spring
What are the specs?
I'm not sure this will fit, but I have an almost new, 300#, 2.25" stroke Ti spring that is for sale. It came off of a SC Heckler Fox DHX 5.0. I bought a higher # coil.
Time and no money or money and no time.
madridg is offline
Old 10-14-2007, 08:46 PM   #3 (permalink)
on a routine expedition
Marshall Willanholly's Avatar
I've got one on my Sunday, and I'm having problems with it rubbing on the shock body on both the Roco and the DHX. I'm using an RCS spring spacer to keep the spring centered, but it hasn't helped. Hearing it scrape the shock body on every g-out was driving me crazy today.
I also needed the spring spacer to allow me to run the Ti spring on the Roco, as it is much shorter than the steel Fox spring, so I ran out of threads before I could add any preload.
It does save a big chunk of weight, however.
420Moment (10-15-2007), Dino Brown (10-14-2007)
Old 10-14-2007, 11:29 PM   #4 (permalink)
Formerly IntegraDriv3r
TrailJesus's Avatar
The Path can probably order you one, and will most likely give you the 10% STR discount too!
STR gets a discount at the path? I just bought some gloves there the other day too. Thought they tacked on 10% just for mentioning the STR name
Originally Posted by art23rockpile View Post
Better to be judged by 12 than carried by 6
TrailJesus is offline
Old 10-15-2007, 06:48 AM   #5 (permalink)
Default first we tack on 10
Then we take off 20. Then we jump you out back, steel the parts back and torture you till you promiss to come back and do it again the next day.
thephat is offline
420Moment (10-15-2007), allison (10-15-2007), denmother (10-15-2007), Ladd Jasper (10-15-2007), Marshall Willanholly (10-15-2007), mechmann (10-15-2007), mtnbikerfred (10-15-2007), Winston (10-15-2007)
wanted fox spring MOSH1DH The Market Place 2 12-09-2006 08:32 PM
AZ Spring Fling Day 2 TURNERob Trail Talk 0 03-20-2006 09:38 AM
Spring Fling teaser CalEpic Trail Talk 6 03-17-2006 07:24 AM
AZ Spring Fling CalEpic Trailhead 83 03-16-2006 07:06 PM
Idyllwild Spring Challenge Race Recap w/ pics (Long) mtnbikerdude87 General Discussion 2 06-17-2005 01:18 PM
