Old-school BMXer
DHF front and rear?
Warrior Society Member
I run Kenda Small Block 8's on my MC29er. Light, fast rolling and hooks up in just about everything but gravel.
Also run them on the Chameleon....2.35 F/ 2.1 R. Wife runs 2.4 Mutanoraptor F / Small Block 8 2.35 R on her Blur LT. Also runs WTB Exiwolf 2.1 f / Small Block 8 2.1 rear on her Julianna. See the trend......works well from everything from Santiago Oaks to Aliso and Whitting.....to Santiago Truck Trail/Old Camp and the Main Divide. When I want a more aggressive tire......Nevegal 2.35 DTC it is. |
Lebowski Urban Achiever
Guess I"ll have to give the SB8 that's in the garage another go as we get some rain to solidify the summer powder. I ran it for about a month around June/July: Thought it was great on true hardpack, but at the first hint of sand or gravel it becomes a slip-n-slide. Very touchy to air pressure too, as I think someone mentioned earlier. Too little and the weak sidewalls wallow around; Too much and it becomes a ping-pong ball.
When dialed in, and on the right surface, it is great. Just didn't seem as versatile as I'd like though.
Just because the bike can do it doesn't mean the rider can! |
It seems that the Nevegal is the rear tire of choice here.
I am running the tubeless 2.1's. My question is how long/many rides, do you guys get out of a Nevegal? I have had my front High Roller for almost a year and it looks great but my 5/6 month old Nevegal is history. Partially because i ripped it on the tread this weekend and because the center treads are worn down. Also does anyone know if Stan's does not work well in the cold? I could not get a small cut in the tread to seal this weekend and it was cold in the San Gab's, there was snow on the trail. Thanks |
Queen of the Darkside
I am running the DT 5.10d wheels and the DT Swiss tubeless setup. I burped mine once and I used a CO2 cartridge to add air, and after that it was fine. I have 4 rides on the tires so far so I will be curious to find out how long they last.
My Blog/My Sponsorhouse profile ~Weekends are like recess for adults so play hard until the bell rings Gene Hamilton: Happy, friendly people that may not be the best athletes are more fun than arrogant "experts". |
sailcalifornia (12-10-2007)
Trail Paparazzi
I love Neve's!! There are a lot of Kenda haters out there, but I totally love the tires everywhere. I used to run 2.1's on my Stumpy (they're on my SS now, which is probably overkill for it, but oh well). I run the 2.35 on my Enduro. It'll be getting the tubeless 2.35's eventually.
How long had the Stan's been in the tire? I wouldn't guess that it would freeze up, but it may be possible. It does dry out, though. Especially if you use C02. |
Put MBenga in!
No idea on the Stan's and cold. sorry. |
allison (12-10-2007),
going my speed since 1975
![]() Seriously, Nev's do wear pretty quickly if you have the sticky's. Most of the time you end up ripping the tread off before the tires wear out. One trip to Mammoth and my front was toast. The side knobs were hanging off. I don't know what compound the SB8's are but with 2000 miles this year on the ellsworth, I have went through 2 rear tires and I run them untill they get real smooth (way too long), just replaced the rear a few weeks ago. From the math, I squeeze 1000 miles on them. I have around 600 miles on my single speed 29er with SB8's this year and they still look great though. The Path Santa (OCTFCU) just bought me a new nev 29 front for the winter wet conditions.
The stans is in there from when i mounted them about 5 or so months ago, and i have never used CO2 on them. Thanks, |
The traction of the Kendas is excellent, probably the best tires as far as traction is concerned. However after I sliced 2 sidewalls and had a rock go right through the tread I have almost all but given up on them. I do use the UST versions still though since the sidewalls aren't paper thin. CO2 and Stan's do not mix, it will cause the sealant to not work anymore. I used Stan's before in my Kendas and I have a rule of thumb. Once the white Kenda name on the sidewall starts turning a brownish color it is time for a new tire. The stans weakens the tires over time. One of the tires I slashed was brand new, on it's first ride
Like kissing $30 goodbye.Oh forgot to mention about that. You need to refill the tires with sealant about every 1-2 months. If not it just dries up into a latex rubbery compound and will provide you with no puncture protection. |
Pho'dUp (12-10-2007)
Trail Paparazzi
This tubless deal sounds like such a pain. I have yet to try it because of all this extra work and mess this stans stuff sounds. I know I am going to get a flat because of this, but if we all just picked better lines, we wouldn't be getting slashed tires here and pinches there.
There was still a fair amount of the stans in the tire when i went to throw the tube in, do i still need to top it off if there is some in there when i look in?
Trail Paparazzi
You'll have to ask someone smarter than me ![]() |
Stop riding your bikes through cactus. Jeez, calepic had this exact same thing happen to him coming down Trabuco just yesterday, and he thought his tires could withstand rolling over a prickly pear. He was wrong, and then pulled 5 thorns out of his tires. He claims that I need to ride faster, but whatever.
My Nevegals arrived today, which I will be putting on Allison's old Stumpy (mine now). I'm curious how they compare to Fire XC Pros that I've been running for a few months...
l'homme plus
I ride mainly in downhill applications (race, aggressive trail, etc.) in Southern California. Here are my picks:
Favorites Maxxis Minion 2.5 and 2.35 in both folding bead and dh casing. I typically run the standard front and rear set up in the same size. I change casings/bead depending on the terrain (Mammoth demands dh casing, for example). Maxxis High Roller in pretty much the same fashion as above. I tend to like these Maxxis tires equally, but find the High Roller to be a bit faster and a touch less grippy. Specialized Enduro Pro 2.2 and 2.4 2Bliss with tubes. These are excellent tires and hook up like crazy. They are also an excellent value at around $36. In addition, they are very durable and often outlast some reputedly more durable tires. Tolerable Kenda Blue Grooves and Kenda Nevegals in 2.35 and 2.5 in various casings. I find these tires only tolerable nowadays. I was running some fairly bald High Rollers and loved those, but had to switch and I had tons of Kenda rubber. I went out and my ride went South. Handling and quickness went to pot and I felt like I was riding through mud. Nevertheless, I feel like they have loads of potential with a little snipping and clipping. Miserable Pretty much every WTB tire I have ever ridden: the full range of Raptor tires. They don't even compare to Maxxis. Etc. I pretty much always run Slime tubes unless I am desparate or anticipate forgiving terrain...in which case I may switch to Maxxis Welter Weights.
Downhill Web Kook Git sum! |
Trail Paparazzi
They hook up great down here, but roll slow. I'm usually willing to give up rolling speed for traction, though. Uhm, unless it's on my VQ bike. I'm tying out some lighter tires at the moment.
Col. Clink
In response to the Stan's inquiry. The stuff really only works for thorns, etc. If you cut the tire it won't seal it. I cut tires all the time and rather than throw them away, I just use a glue on automotive patch. Stans is still the sh1t though. I will never go back to tubes.
My troubles on Trabuco were from letting the Stans dry up. As Pat said, I pulled a good 5 spines out of that tire before I put the tube in. Friggin Trabuco owns me. C
tkblazer: you pedaled up mathis? nice, i'm scared to ride down it |
mmmmm, noogs...
im bummed i missed the ride this sunday. i have yet to stanitize my wheels on my dawg and my superlight...i did like using stans when i had my huckler and purple haze. i still need to get the 2.1 nevvy for my superlight from ben, or turnerob. |
