mazda-monkey
Just a Member
mazda-monkey's Avatar
XC riding- San Juan, Laguna Coast, Aliso woods, on a Trek Liquid 25.
Front - Nevegal 2.1 Stick-e
Rear - Nevegal 2.1 DTC.
Good grip, although I think the intial bite went away after 10 rides. I remember the first ride on them and thinking these suckers stick like glue. After a few rides it seemed like the grip went away slightly even though the tread blocks looked OK. Maybe the grip is the same & I just adapted?
Krztaco
Big Pimp'in Spnd'in Cheez
Krztaco's Avatar
I ride all the local so cal trails on my 30lb Ellsworth Moment.
Here are the tires I've used on the bike and my feedback. All are tubless specific tires run with Stans Sealant on Tubeless specific Rims
--Specialized Enduro 2.4 2BLISS: Used as a front tire, it washed out and if I wanted to commit suicide I'd definitely still be using it.
--Kenda Nevegal Tubeless 2.1: Great size...loved it as a rear tire and will be putting it on the front once needed. As always the Kenda is a high volume 2.1 and is bigger that stated.
--Maxis CrossMark 2.1 tubeless: AWESOME rear tire, light, great traction, low rolling resistance. I don't see another rear tire replacing this one for a long time.
--Maxis High Roller 2.5: Used as a rear tire for Mammoth DH fun....loved it, great breaking and cornering, super tacky too.
--Maxis High Roller 2.7 TUBED: I wish they made a tubelss version, I'd be all over it to run lower PSI....loved it in Mammoth. If I wanted to add 5 lbs on my bike and walk my bike up most of the trails in OC I'd run the Maxis combo or hit the olympic squat rack a few times a week
jschwart73 (01-08-2008)
BeantownRider
BeantownRider's Avatar
If anybody is having trouble finding a good rear for a 29er hardtail I have to recommend the Geax Saguaro 2.2. I've been through a bunch of rear tires and it's closest to the Ignitor in traction and rolling resistance with better volume and more robust sidewalls. For what it's worth, I run a Rampage front and have never looked back.
BrewMaster (02-18-2008)
Upsidedown1
Peddler
I ran Neve's for a month. Dual compound, and wore the tire out on the rear. Went to sb8's and can hardly see any wear on them after 3 races and lots of miles over the last 3 months. I do use stans and love it. Saved me on the Project Rwanda ride after a small tear in my rear tire. Sealed up nice and have not had a problem since.
........and let us run with perseverance
the race that is set before us. (Heb 12:1)
dstepper
Friends don't let friends ride SB8's. I was riding in the decomposed granite on Kenton Devore Trail in the San Gabs. Been on that trial many times but this time with a SB8 that I left on from my slickrock trip to to Gooseberry Mesa. Big mistake the SB8 did not have the downhill braking grip the Nev does and I ended up sliding off the trail and down a 15 ft cliff, luckly I landed in the deep enough water of a stream. Never again will I put a tires wear above safety.
They are great fast rolling tires just not good for the riding I do.
art23rockpile (02-18-2008), guero (01-10-2008), tkblazer (01-21-2008), Vince (02-18-2008)
guero
mmmmm, noogs...
guero's Avatar
how does the maxxis larsen compare to the sb8 under downhill braking ability? i have one that i might through on my superlight.
for a good time, click ---> Adrenaline Bikes
dstepper
Most tires seem to be fine around OC.
It is that decomposed granite you find in the Sierras and San Gabs. Most of the SG trails are hardrock but those loose section that sneak up on ya, you need some aggresive lugs to get to the hard pack. I am lovin the Big Betty up front. I had stress cracks on my Mavic 521 after 5 years, new rear rim is a 819 so I am looking to buy a UST Fat Albert for the rear.
1080P (01-17-2008), guero (01-10-2008)
1080P
between 661&90210
Red face
That decomposed granite is what makes a Big Betty in the front and a relatively fresh (under 3-400 mile) Fat Albert shine. Simply a great combo for shuttling up at Mammoth, pedaling through the deep sand on the trail at the bottom of Mammoth Rock trail, or sticking it on the lose decomposed sand /granite on the steep slippery sections like on Viper in the Santa Clarita Valley when it's dry. I've got around 1000 miles on the Big Betty up front, some pavement, mostly San Gabs and west towards Malibu and Pt. Mugu. It just does a great job. Schwalbe makes high performance tires. They are very expensive, but it's relative. A good set of tires that saves you from blowing a line because they stick, grab, or rail, and prevents a trip to the emergency room is the proverbial ounce of prevention is worth a pound of cure.
I will wince when it's time to shell out for another Big Betty ORC 2.4, but once I'm over the pain, one good arse saving stoppie will be a reminder that they are worth it. From So Cal to Downieville, rocks, streams, granite, desert, sand, they do it well. Sometimes outstanding, sticky. Just do what you can to keep Fat Alberts off of pavement if you run them on the rear.
I'll be interested in hearing how you like the Fat Alberts performance on the rear and what kind of mileage you get out of it in back. I weigh 220-230, and run tubes with about 38-42 psi on the back, 35 to 40 on the Big Betty up front, on a Bionicon Edison in an XL.
SSinGA
Free-XC-Downhiller
SSinGA's Avatar
Default Prototype 2.25 CrossMark review
x-posted from MTBR.
Both tires went one easily by hand with just a little spit needed to get the last section of the bead over the edge. They also aired up using a hand pump and the bead popped into place at about 20psi with very little effort. I started the ride at 30psi and blipped a little air out trailside just to see how they'd do.
Maxxis hit the sizing right on the head with these tires. The sidewall says 56mm at the casing and 54mm at the tread. I got 56mm at the casing and 55 at the tread. The side wall is fairly beefy lending to to they 840g and 820g weights I got.
I have a couple of rides on this proto set of 2.25 UST's and they have really surprised me. I took them out to a local trail that is a good barometer for how a tire will do on most of the area trails. The singletrack is mostly unmaintained, singletrack hardpack with a thin, sandy layer. The majority also has a nice thick topcoat of pinestraw or leaves. There are also areas of exposed granite and "black rock" (slimy. wet granite that is like riding on ice) and a good many roots.
My first ride I wore my knee and elbow pads because I just knew that they would not hold me up-right. I was wrong!! They held on as good as the High Rollers I was using previously. Rolling resistance is nearly undetectable and makes you forget you have 800g+ tires mounted. The little bit of mud I encountered was shed quickly. What really surprised me was how well they cut through the trail litter.
So far the only weaknesses I have detected, and they are minor, is standing climbing and highspeed "panic-style" braking. I would contribute this to the centerline tread that has virtually no breaks and thus can't grab as well. The tire does well on seated climbs, even through very rooty, technical climbs. Most normal brake applications result in good slowing. I plan on putting a lot more miles on these and will follow up this initial review.
Enough blah, blah, blah. Here are some pics
www.t2bikes.com
audiopablo (02-12-2008), BandMan (02-12-2008), guero (01-21-2008), Krztaco (01-22-2008), Schecky (01-17-2008), un-kola (01-18-2008), Waldo (01-18-2008)
sir crashalot
...not Sir "Flashalot"
sir crashalot's Avatar
you can't go wrong with Schwalbe. I'm running ust schwalbe fat Alberts on mavic 823 rims on my Heckler and they are fantastic. A little heavy for the rear-previously I had a specialized eskar 2bliss on the rear, which has great traction and is very light for a ust 2.3, but not durable-sidewall cuts easily and even tiny holes don't seal well on that tire with Stan's; so i put my backup fat albert on the rear. easily the biggest 2.35 out there, about as big as maxxiss' 2.5" tires. It is one tough, grippy tire. man my bike just keeps getting heavier. I'm waiting to try also the ust panaracer rampage 2.3" when it's available; may be a little lighter, and its a great tire as well.
1080P (02-05-2008)
jschwart73
jschwart73's Avatar
Been running Nevegals for a couple months now, the latest being the UST version. Like the grip a LOT, but they don't roll very well and are HEAVY. On the suggestion of my LBS, tried out a set of Specialized The Captain 2Bliss.
Grip is excellent, both steering and climbing. They are a little looser on the brakes in the rear, but the front gripped very well on the brakes, no washouts. I rode on tacky dirt and some rock strewn areas as well and grip on the rocks was spectacular, even on a sideslope rock traverse.
They roll quite a bit better than Neves, that was clearly noticeable.
They're 275g lighter, per tire, than Neves.
Von-Skipp
FLOW
Von-Skipp's Avatar
I think I found a sweet combo of tires for xc/racing.
WTB Weirwolf 2.1 up front
Maxis Crossmark 2.1 in the rear
Both are UST on 819's with a scoop of Stans.
I've been using this combo in CA and in AZ and they work really well. I raced them last weekend are they hooked up great, but I'm sure I could find a faster front tire.
Props to this combo.
jschwart73
jschwart73's Avatar
I am really liking the Specialized The Captain 2Bliss tires - Rode them again today, good grip and roll well. Relatively light (605g each, mounted tubeless).
Schecky
SoCalMTBubbs
Schecky's Avatar
What width are you running?
http://www.ventanausa.com/
jschwart73
jschwart73's Avatar
2.0 (I don't think they offer the 2Bliss in 2.2 yet)
Von-Skipp
FLOW
Von-Skipp's Avatar
Default question
Has anyone run the new Continental Mountain Kings 2.2.
Its a xc/race tire I believe
jschwart73
jschwart73's Avatar
A 2.2 XC Race tire? Interesting.
I've got a set of Maxxis Larssen TT's on the way, 1.9r, 2.0f. Lightweight, we'll see how they do. I am still liking the Spec Captains a lot, but I like tire testing.
DeeZee
2007-08 NBA Champions
DeeZee's Avatar
Default For dry hard pack
Bonti XR.... 600g and rolls fast. Speci Fast track is also good but heavy
Red Hot Sloth
"where I grew up bling bling would get you shot, same with the lycra"
Dirtmistress "Hey! I resemble that remark! I was born in Berkeley and have the chin hairs to prove it!!"
Trizz
I'm a Machine
Trizz's Avatar
after breifly reviewing this thread it seems everyone has wider front tire,
is this something that creates better handling or something.
DasBrink
6th coolest guy in SoCal
DasBrink's Avatar
When sh!t happens, its nice to have some extra meat on the front to save your ass
and there is no need to drag a huge rear up a hill when the front is what gets you around the corner.
You ever sit back and think about how many times you almost ate sh!t?
We should all be dead!
Pho'dUp (02-12-2008), Red Hot Sloth (02-12-2008)
Nevegal Tire Knobs coming off Sprockethead The Workshop 24 05-02-2008 04:12 PM
training tire RidetheRAAM4 The Roadie Hangout 8 08-10-2007 03:46 PM
29'er tire compatibility question EndoMaster The Workshop 8 05-10-2006 08:00 AM
Attn Rubber Gurus! Find me a tire!? Pho'dUp General Discussion 8 06-24-2005 10:07 AM
1 2 3 4 5 6 7
