What is your experience with suspension seatposts? Any recommendations?
I have a hardtail that I use as my backup bike. In less than a year, I've broken 2 seats, both shearing the metal bar under the seat off cleanly. I assume I'm sitting when I should be standing. So....I'm thinking that spending a bit on a suspension seatpost will be less expensive than replacing the seat 2X per year. Thanks! |
I don't have one on my 2 HT, but I have ridden a bike that did and I can tell ya, I wish I had one, it's a nice ride, but it's a tough decision to go and replace the Easton carbon I have on the Rocky Mtn and the Thomson I have on my SS.
Here's a few: |
BrewMaster (09-27-2007),
Winger (09-27-2007)
#3 (permalink) | |
http://www.canecreek.com/seatposts.html pic of my Sir with Thuddy and cover called The Crud Buster ![]() |
Winger (09-27-2007)
going my speed since 1975
Winger, I have the rockshox seat post and I love it. Its from 2001 and pretty heavy. Its compression bushings (elastimers) and has adjustment via a hex on the bottom. You can find them on Ebay for 25 bucks. No, they don't have them on Sale at Performance
... I have a shot of it on the zion in my gallery. I think it works pretty good, but you do get bob if it's not stiff enough.http://weightweenies.starbike.com/li...nsionseatposts Its the Rockshox mtb 27.2/350... I guess its not that heavy compared to everything else. |
Winger (09-27-2007)
Ghetto Swan Lake
Maybe run a saddle with steel rails (instead of Ti) and a seatpost with a larger wider/longer rail clamp. Or maybe the Kore I-beam saddle/seatpost. I've heard good things about those and not to expensive. I seem to remember the Whyte Ind. suspension seatpost has a an adjustable air spring, and not elastimers. Carl |
Winger (09-27-2007)
Good suggestions so far. I appreciate all the input.
Break #1 was on Main Divide somewhere between Beeks' and Motorway. Break #2 was in Peter's canyon, somewhere between the top of Big Red & the lower dam, along the upper ridge. Best I can tell, it was at a higher speed and I was probably sitting down to peddle & carry momentum up the next hill. I definitely stand when it gets technical. I weigh about 185 + gear and can't lose much more weight. Both seats were low end and had solid rails (steel? Aluminum?). Pedal bob is an excellent consideration. I'm comfortable with the hardtail the way it is, and the suspension seatpost would strictly be to protect the bike seat. |
Winger (09-27-2007)
I have a Thudbuster Unipivot that I used on my hardtail for a while.
Works similar to the newer cane creek, but the nose of the saddle would tilt up when it compressed. I could control how active it would be by sliding forward and back on the saddle. It works great, but went the way of a Ti seatpost and suspension saddle for lighter weight.
Steve Just along for the ride Originally Posted by SheDevil Autoduel...yours is huge!!!
Winger (09-27-2007)
On the edge of chaos
Pedal bob (kickback) can't happen with a hardtail, the BB and hub are always the same distance apart. |
Winger (09-28-2007)
#15 (permalink) | |
Dis Member eD
It's very easy to service yourself and you can buy the service kit from them as well. It does not bob when you pedal and REALLY takes the edge off bumps. Thar she is:![]() |
Winger (09-28-2007)
Rider Doooood
I have a thudbuster too. It worked pretty good on my ironhorse HT a while back. Now I'm thinking I might put it on my On-One Inbred, but the reba Race comes first
![]() You can get different elastomers for your weight and desired springyness. Is that a word? ![]() |
Winger (09-30-2007)
| Rear Suspension Question.... | Dagomako | The Workshop | 4 | 08-31-2007 10:41 PM |
| Decent beginner Dual Suspension frame? | BAD_S197 | General Discussion | 32 | 08-16-2007 02:13 PM |
| for you suspension guru's | MOSH1DH | The Workshop | 2 | 08-04-2007 06:22 PM |
| Showa Engineer Talks Suspension | downhillnews | The Workshop | 1 | 03-20-2007 07:07 PM |
| Turner Horst Link vs. TNT | Von-Skipp | General Discussion | 12 | 04-05-2006 11:52 AM |
