View Poll Results: What type of rear derailleur do you prefer?
High Normal 15 45.45%
Low Normal 4 12.12%
Don't care 14 42.42%
Voters: 33. You may not vote on this poll
Old 09-14-2007, 12:20 PM   #1 (permalink)
Quest: Singletrack
mntbiker12's Avatar
Default Time to sound off on this important debate!
Nope, no politics here.
Just want to talk rear derailleurs. What side of the fence are you on: high normal or low normal?
I rode high normal forever until my most recent rear mech, which is low normal. After a good year of riding with it, I'm faced with possibly replacing it, and I'm wondering whether to stick with it or return to high normal.
Couple of things:
I do like the idea of the low normal and it springing back to the larger sprockets for better downshifts. In my opinion, downshifts up steeps are the most critical and the ones you hate to miss.
However, over the last few months, it feels like the spring has a dead spot between the 4th and 5th sprocket which results in a mis-shift between those two gears. I'm meticulous about cleaning the cassette, chain, and rear derailleur constantly before anything else on my bike to keep shifting crisp. That includes lubing the housing and changing cables frequently. No matter what I do, I can't get rid of the dead spot. Having only owned one low normal der., I don't know if it's a defect, wear and tear, or something common.
So, before springing for a new one, I just wanted to hear from others and whether there's a preference for one over the other.
Thanks.
Woohoo it's Friday and I'm only 2.5 hours on the clock from hittin' some tasty singletrack!!
And then , which if done properly, should result in .
Peace, love & bikes!
Frame for sale: 04 Haro XLS R7
mntbiker12 is offline
Old 09-14-2007, 12:22 PM   #2 (permalink)
Technically Canadian
Neccros's Avatar
*cough*High normal*cough*
Dead spot might be caused by a slightly bent hanger... I could be wrong
Cant we all just ride along???
Neccros is offline
Old 09-14-2007, 12:24 PM   #3 (permalink)
Are you talking about REGULAR and RAPID RISE?
I don't get it otherwise
allison is offline
Old 09-14-2007, 12:25 PM   #4 (permalink)
Neccros's Avatar
Rapid Rise= Low Normal
Regular rise=High Normal
Rapid Rise=Retard Rise!!
Neccros is offline
Old 09-14-2007, 12:28 PM   #5 (permalink)
Quest: Singletrack
mntbiker12's Avatar
Yeah, I guess High normal = regular, Low normal = Rapid Rise
Here's a quick recap on difference straight from Shimano:
http://cycle.shimano-eu.com/publish/...fference2.html
Old 09-14-2007, 12:30 PM   #6 (permalink)
Collette's Avatar
I'm running a long cage, whichever one that is.
Collette is offline
Old 09-14-2007, 12:31 PM   #7 (permalink)
Bad 5%
Winston's Avatar
I prefer mine to say SRAM.
"The Fox is more expensive than the Reba that is why Baller Pat likes it." - DeeZee
http://www.chainedrevolution.com/mem...sc/ThePath.gif http://www.chainedrevolution.com/mem...s/misc/nlz.jpg
Winston is offline
allison (09-14-2007), bjammin (09-15-2007), Burner (09-14-2007), Chaos (09-14-2007), Collette (09-14-2007), Dino Brown (09-14-2007), El Salt (09-14-2007), J_Sims (09-14-2007), LBmtb (09-14-2007), m80kickflip (09-14-2007), ODB (09-14-2007), Pain Freak (09-15-2007), Schecky (09-14-2007), sladnas (09-14-2007), Wrecker (09-16-2007)
Old 09-14-2007, 12:32 PM   #8 (permalink)
Neccros's Avatar
Long cage refers to the range of the derailer in rerlation to the size of the cassette...
So if you run a 34t cassette, you should run a long cage derailer....
Both Rapid rise and regular rise came in long cage
Neccros is offline
genusmtbkr5 (09-14-2007)
Old 09-14-2007, 12:34 PM   #9 (permalink)
denmother's Avatar
I used Shimano Rapid rise for years (8 speed). Then I swtiched to SRAM 9 speed (sponsorship), the shifting is just as good if not better than Shimano Rapid Rise in my opinion. I use the SRAM XO trigger shifters and love them. I converted all my bikes. I use the long cage on my Trail bike and the short cage on my DH bike.
My Blog/My Sponsorhouse profile
~Weekends are like recess for adults so play hard until the bell rings
Gene Hamilton: Happy, friendly people that may not be the best athletes are more fun than arrogant "experts".
denmother is offline
Old 09-14-2007, 12:36 PM   #10 (permalink)
Neccros's Avatar
I thought rapid rise only came out in recent years with the 9 speed stuff???
Neccros is offline
Old 09-14-2007, 12:39 PM   #11 (permalink)
Suck on these
uzziboy's Avatar
how bout dont care/dont need one. i run a rohloff speedhub and just need a tensioner
Why ask why, does it really matter????????
uzziboy is online now
Old 09-14-2007, 12:48 PM   #12 (permalink)
i've never ridden a bike with rapid rise until i rode a yeti 4x... i must i admit that it wasn't bad.. using the big thumb lever to shift into a harder gear is a lot easier to do with the big lever when you're out of the saddle sprinting. i do run sram setups on my bikes though, not a fan of the shimano rear derailluers.. i like the solid shifts that sram has
Old 09-14-2007, 01:03 PM   #13 (permalink)
A little dab will do me
spookydave's Avatar
SRAM = [SIZE=5]MADE IN USA [/SIZE]
spookydave is offline
Old 09-14-2007, 01:06 PM   #14 (permalink)
False.
You can use either short, medium, or long cage derailleurs with an 11/34 cassette. However, if you're using a triple up front, you should use a long cage derailleur (a medium is ok in some cases).
Yes, the cage length determines how many "teeth" of gear changes, but not cassette size. All current Shimano MTB derailleurs can be used on a 34 tooth cassette (older ones were good for 32 tooth cassettes).
Old 09-14-2007, 01:07 PM   #15 (permalink)
you sure? i thought all of the SRAM stuff was made in taiwan...
Old 09-14-2007, 01:12 PM   #16 (permalink)
For newbies, low normal is best. It makes the actions between the left and right shifters the same (push on the same lever and get the same results).
High normal rear and low normal front is very confusing for newbies. Those of us who've been riding gearies for a while have adapted our brains to backwards shifting from both Shimano and SRAM (twist grip shifting was backwards as well).
Interesting that Shimano hasn't adopted low normal on their road systems - too much resistance from the user base? I think so.
Nonetheless, I want to try the new XT Shadow derailleur on my M3. It only comes in a low normal. I'm sure this will be a problem getting used to for quite a while!
Old 09-14-2007, 01:13 PM   #17 (permalink)
cjwally's Avatar
How about SS with no derailleur....Why isn't that an option?
cjwally is offline
Old 09-14-2007, 01:18 PM   #18 (permalink)
Nope, it's been out for a while. It came out with the 8-speed XTR 950 series stuff. It never took off because the industry hasn't embraced it.
Which is exactly why Shimano continues to use it (and it's good for beginners, as I mentioned).
The answer is "don't care."
That would explain why SRAM stuff works well!
DOH!!!....sorry, the OP said no politics.
Old 09-14-2007, 01:31 PM   #19 (permalink)
Quest: Singletrack
mntbiker12's Avatar
Actually, I think it's the other way around and will be top normal.
http://www.beyondbikes.com/bb/ItemMa...2&MatrixType=1
2wheel_lee (09-14-2007)
Old 09-14-2007, 02:42 PM   #20 (permalink)
Sweet! I bought it about a month ago, and I haven't installed it yet. After I bought it, I read somewhere that it was a low-normal. I'm glad that it's not.
