Old 09-12-2007, 10:47 AM   #1 (permalink)
Default 'skipping' while pedaling - hub? rear derail?
Fella's,
was riding fenceline last night, and was trying to torque up a big hill.. and all of a sudden, the bike would skip....
thought it was a derailer adjustment in the rear... but i believe that is set great.
Is my hub skipping? how can i tell?
shimano disc hubs on sun rims......
any help is appreciated.... skipping was cutting into my riding fun...
Chewyeti is online now
Old 09-12-2007, 10:59 AM   #2 (permalink)
It's tough to diagnose without actually testing the bike.
Confirm that the skipping occurs in more than one gear in the back. If it does, it may be damaged or sticking pawls in the rear hub. Fortunately, Shimano freehubs are easy to remove to inspect the pawls.
2wheel_lee is online now
Old 09-12-2007, 11:01 AM   #3 (permalink)
WTFO
Burner's Avatar
the bike would skip??
the chain would skip or the hub would skip?
have you put on a new chain or cassette recently?
Burner is offline
Old 09-12-2007, 11:02 AM   #4 (permalink)
Technically Canadian
Neccros's Avatar
Also check if your Der. hanger is bent or not causing the derailer to be out of alignment.
Cant we all just ride along???
Neccros is offline
DeeZee (09-12-2007)
Old 09-12-2007, 11:14 AM   #5 (permalink)
it would skip in a myriad of gears......
im inclined to think its the hub. (great.... sigh)
recently put new race face chainrings, and SRAM super chain....(32 bucks at jensons). it has been great for weeks! just cleaned and lubed the chain the other night....
if its the hub.... is this the part that failed?
http://www.jensonusa.com/store/produ...ehub+Body.aspx
Old 09-12-2007, 11:22 AM   #6 (permalink)
yeti weight killed the rear hub
Old 09-12-2007, 11:28 AM   #7 (permalink)
Default I agree
Same thing was happening with my son's Kona. It was driving me crazy. Also the drl hanger didn't even look bent.......but it was
Old 09-12-2007, 12:01 PM   #8 (permalink)
hmmm...new chain and chainrings...how old is the cassette?
Yes, the freehub part you linked to is correct. But before you buy parts, take your freehub off to inspect it. Perhaps the pawls may simply be sticking from old grease (crossing fingers).
Also, when you say skipping, do you mean the cranks pedal forward without the bike moving the same amount? Could you describe your skipping?
Old 09-12-2007, 12:16 PM   #9 (permalink)
cassete is a few months old also.... fresh grease.
no sticky link in the chain, as that would make it skip at the same link everytime.....
this 'skip' is more impacted by force.....
chain is in bitchin shape (newish) and cleaned and lubed.
derailer is adjusted.....
skipping = yes... cranks turn while riding, and the cassete spins without turning the wheel. not a chain skipping on the cassete......
do i need any 'special' tools to take my hub apart?
Old 09-12-2007, 12:25 PM   #10 (permalink)
ricky - how are the blackberry's and thorns feeling?
oooooo.... not so good.
depends on what hub you have.
sounds like you need a new wheel.
new wheel? that blowz!!!!
shimano m454 or something hubs.....
crap. i am at work so i dont remember what hubs are on it.
Old 09-12-2007, 12:34 PM   #11 (permalink)
coldbrews's Avatar
I t
coldbrews is offline
Old 09-12-2007, 12:39 PM   #12 (permalink)
Neccros's Avatar
Its either the cables loose(My road bike had this problem) or the hanger is bent....
Neccros is offline
Old 09-12-2007, 12:41 PM   #13 (permalink)
has-been onna hardtail
DDB@OCR's Avatar
Default If the cassette freewheels in drive direction....
Is the cassette lock nut torqued to spec?
It may be a worn/damaged engagement pawl in/on the drive hub.
Might be saveable, might not. Gotta get in there and inspect.
DDB@OCR is offline
Old 09-12-2007, 12:44 PM   #14 (permalink)
i was lengthening the sheath, by backing out the knob at the shifter..... thus tightening the cable
ill investigate
Old 09-12-2007, 02:45 PM   #15 (permalink)
going my speed since 1975
jcampbell's Avatar
Had same problems with a friends bike last night... Hub is probably skipping, its a pretty crazy sound and different that just a chain skip.
jcampbell is offline
Old 09-12-2007, 02:52 PM   #16 (permalink)
Edog's Avatar
Could be that the chain is the wrong width & not sitting on the cogs, if you have the old chain you just took off put them side by side, make sure they match
Ya that's right!
Edog is offline
Old 09-12-2007, 07:13 PM   #17 (permalink)
[quote=Chewyeti;104409]ricky - how are the blackberry's and thorns feeling?
quote]
Yea those where fun to pull out of my face in the shower pretty nice burn too, the things we do too keep our hot bodies. At least I was leadin and i didnt fall on my face in the back of the pack.
Old 09-12-2007, 07:30 PM   #18 (permalink)
ok... news flash!
one of the links had a bend along the longitudinal axis of the chain! popped out 3 links and replaced with leftover sram links. used my chain breaker... and have a tight link now.... (drove the rivit back in, and it is very stiff....)
advice?
mechmann (09-12-2007)
Old 09-12-2007, 07:33 PM   #19 (permalink)
Neccros's Avatar
work it back and forth and it should loosen... make sure the pin is in properly...
Neccros is offline
Old 09-12-2007, 07:37 PM   #20 (permalink)
BFloFoxRider.'s Avatar
i snapped my derailler hanger and i check it before every ride and it was straight... and the worse part is... i was coasting when it snapped!
i've been told skipping could also be the rear cassette is worn?
just my two cents!
Brandon FLOres
This is How we do it!
BFloFoxRider. is online now
Chris King finally makes 150mm rear hubs tkblazer General Discussion 5 09-10-2007 03:42 PM
Chain skipping question Sprockethead The Workshop 12 07-24-2007 08:57 PM
Rear Hub?? Skeeter The Workshop 2 04-23-2007 09:05 PM
Fox Rear Air Shock BUSHING? PHAT TIRE The Workshop 4 03-12-2007 04:57 AM
Rear hub on it's way out???? ECOdork The Workshop 6 10-03-2005 08:30 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
