Old 09-12-2007, 08:49 PM   #21 (permalink)
Shrek must be destroyed
Originally Posted by Neccros View Post
work it back and forth and it should loosen... make sure the pin is in properly...
worked it back and forth..... lubed it..... no dice...i will pull pin tomorrow and retry.,
Chewyeti is offline
Old 09-12-2007, 10:21 PM   #22 (permalink)
LycraCladChampLike
sperminator's Avatar
yetti
check the deraler hanger. back a month ago when mine was doing the very same thing all i needed was a new $6 hanger and the problem was fixed. you could just buy a new bike and it will be fixed. you could just hang the bike in the rafters and find a new sport.
Blue Rat: The Guy was a DWARF! No kidding-- an honest-to-goodness midget!
He storms over to my car, looks up at me and says, "I AM NOT HAPPY!"
So, I look down at him and say, "Well then, which one are you?"
sperminator is offline
Old 09-12-2007, 10:44 PM   #23 (permalink)
burn it , at least IH doesn't make crapppy snowboards.... I still say its the hub.
Old 09-13-2007, 06:19 AM   #24 (permalink)
ok... news flash!
one of the links had a bend along the longitudinal axis of the chain! popped out 3 links and replaced with leftover sram links. used my chain breaker... and have a tight link now.... (drove the rivit back in, and it is very stiff....)
advice?
If you overdrove a pin back in, you need to press it back a tiny bit the other direction. Or- you bent a plate doing it wrong. I don't lke splicing chains, it can be done and get ya home, but it's not the best thing and they often fail in that area. Most chains are not meant to be spliced. Speed links are for connecting chains, Shimano uses a special pin for connecting after cutting to final lentgh.
Also- is this a NEW symptom/complaint or were you mis-informing us of your prior complaint (cassette freewheels in drive dirrection)?
DDB@OCR is offline
Old 09-13-2007, 08:51 AM   #25 (permalink)
I was apparently misinformed... freewheel/hub is fine....
chain already had a SRAM power link, so i couldnt use another.....
so the spliced chain is an unhappy chain at the moment... i will try to press the pin back a tad.
Chewyeti is offline
Old 09-13-2007, 08:58 AM   #26 (permalink)
Okidoki.
Make sure the pin is in the plates evenly on both sides and the plates are straight and cherry, but note, that might be the weakest link. So be careful out of the saddle so you don't whack yer knee on the stem when it goes 'KANG!' which can happen when yer chain crosses up in middle/big etc.
(getta new chain soon )
DDB@OCR is offline
Chris King finally makes 150mm rear hubs tkblazer General Discussion 5 09-10-2007 04:42 PM
Chain skipping question Sprockethead The Workshop 12 07-24-2007 09:57 PM
Rear Hub?? Skeeter The Workshop 2 04-23-2007 10:05 PM
Fox Rear Air Shock BUSHING? PHAT TIRE The Workshop 4 03-12-2007 05:57 AM
Rear hub on it's way out???? ECOdork The Workshop 6 10-03-2005 09:30 AM
