Old 08-31-2007, 07:16 PM   #1 (permalink)
I build jumps
destroyer's Avatar
Default Lookign for a new frame AM/FR
Well I'm looking for a new frame. I ride mainly XC/AM but I like to hit all the drops and jumps when I see them. My usual trail I ride is about 3-6 miles of uphill dirt and asphalt and then it's downhill through the desert (about 7-15 miles). So I 'm looking for something that can climb and go downhill. I went to adrenaline bikes the other day, and they were really awesome and pointed me towards the Transition Preston FR. It looks like a great frame for what I'm looking for.
Does anyone have any other suggestions for frames to look at?
I would like to keep it under $800 with tax, shipping, etc... (poor college student).
Thanks guys for the advice.
destroyer is offline
Old 08-31-2007, 09:24 PM   #2 (permalink)
Car Magnet
Check out this link. I would have to know more about your height/weight/ riding style to suggest a partiular one
http://wheelworld.com/itemlist.cfm?c...7&catalogId=39
destroyer (09-03-2007)
Old 09-01-2007, 09:23 AM   #3 (permalink)
Warrior Society Member
mtnbikej's Avatar
What size ya looking for?
I have a hardly used 2005 SC Bullilt frame that I need to get rid of.
7" travel
White front/Black rear
Size Large
WIll sell for $750
mtnbikej is offline
Old 09-01-2007, 04:28 PM   #4 (permalink)
I build jumps
destroyer's Avatar
5' 9" with long arms and I like the feel of short freeride necks if that matters. I weigh 185 and I would say my riding style is some what smooth but aggressive (if that makes any sense).
Right now I'm riding a Iron Horse Yakuza Bakuto 2006 and I really like it except some trails get a little rough going downhill and some jumps/drops need a little more cushion.
Old 09-02-2007, 01:42 PM   #5 (permalink)
Uncle Rico's Avatar
Preston is a sweet frame.
Are you thinking new and used frames?
If I was looking for a frame under $800, I would look for a used SC Heckler. Usually find those for about $650.
Uncle Rico is offline
Old 09-02-2007, 06:53 PM   #6 (permalink)
In that price range, you should definitely check out the Soul Cycles Matador set up in 5" mode with a Rocco R Air. http://www.ridesoul.com/matador I like mine, and it is similar in some ways to the Preston. It has a lower standover, and as such you'll need to run more seat extension than you would on the Preston, but it's also a little lighter. Both bikes are single pivots, they just use different types of linkage, so suspension traits will be similar, though not identical. At the pricepoint you are looking, your options are pretty limited for a brand new quality frameset. One important thing on the Prestons, if you have to choose between an 06 and an 07 or newer, go with the 07 or newer. The reason being is that the leverage ratio is lower which has multiple benefits from quality of travel, to being able to run lighter springs to achieve the same sag.
Good luck with it,
Chris
Flat Broke is offline
Old 09-02-2007, 07:06 PM   #7 (permalink)
Homer
PacMan's Avatar
Adrenaline Bikes' site has Transition Preston frames for $700.
Less typing...more riding.
PacMan is offline
Old 09-03-2007, 11:00 AM   #8 (permalink)
I build jumps
destroyer's Avatar
That was the frame I was looking at, and the tall guy with black hair who helped me was very informative. All the reviews I look at seem pretty good too. My only problem with going a little higher in price is I think I would be better off with a nice fork and say the Preston frame, compared to buying a $1400 frame alone. At least that is what the guy at the shop told me, but it makes sense.
I would prefer to buy new, but if it looked like it was in really good condition I would buy used locally.
Here is a link to the Preston for those that haven't seen it.
http://www.transitionbikes.com/2007/PrestonFR.cfm
Thanks guys for all the advice so far!
Old 09-03-2007, 11:08 AM   #9 (permalink)
Steve Peat Wannabe
project_d's Avatar
Although I've never ridden one, I've heard good things about the Preston, and it seems to be a good bike for the money. At that price, the only other bike I would look at would be a Kona Coiler.
project_d is offline
Old 09-03-2007, 12:23 PM   #10 (permalink)
Homer
PacMan's Avatar
I am thinking about replacing my Reign frame with a Preston. I checked and the shop employee direct purchase price is insanely cheap.
PacMan is offline
Old 09-03-2007, 09:07 PM   #11 (permalink)
Uncle Rico's Avatar
Thats a smokin deal. Do it!
Old 09-05-2007, 04:24 PM   #12 (permalink)
I build jumps
destroyer's Avatar
So if I were to get the Preston frame, I would need to buy a new seat post, head set, and shifter cables (or at least housings)?
edit:
Just realized it takes the same diameter seat post I have now. WooT!!!
Build Specs: Shock Specs: 7.55 eye-to-eye x 2.0" stroke, Upper Pin 46mm x 8mm, Lower Pin 22.2mm x 8mm
Front Derailleur: 34.9mm Clamp, Top-pull, (Top Swing Shimano or Low Mount SRAM)
Bottom Bracket: 73mm x 113mm (68 x 118mm if using a Chainguide)
Headset: Standard 1 1/8" (1" deep cup compatible)
Seatpost: 30.0mm
Seat Clamp: 34.9mm
Rear Dropout Spacing: 135mm x 10mm (nutted axle & QR compatible)
Disc Brake Mount: International Standard
Chain Guide Mounting: Standard ISCG
Old 09-05-2007, 04:35 PM   #13 (permalink)
Homer
PacMan's Avatar
I'm still on the fence about the Preston. I'm not digging the 1 year frame warranty.
PacMan is offline
Old 09-05-2007, 04:39 PM   #14 (permalink)
I build jumps
destroyer's Avatar
I think that if there is a manufacture defect it would show before then. But that piece of mind is nice!
Old 09-05-2007, 06:16 PM   #15 (permalink)
how come you're lookin at a preston? its as much of a tank as the reign is... the 08 reign 0 is supposed to be 29lb according to mba....
Old 09-05-2007, 06:44 PM   #16 (permalink)
Homer
PacMan's Avatar
Ya, but the '08 Reign isn't available as a frame only
I would like something that rides a little "firmer". The Reign is a little too plush on the climbs for me. Of course, a simple upgrade like an RP3/23 would probably solve that problem for me.
PacMan is offline
Old 09-05-2007, 09:34 PM   #17 (permalink)
Pacman,
While the Transition warranty is 1 year, the crash replacement policy is in effect for as long as you own the bike. I've only seen 1 pic of a Preston with a failure issue, and it was the shock mount on the top tube on the older frame design.
Chris
Old 09-05-2007, 09:42 PM   #18 (permalink)
Homer
PacMan's Avatar
Originally Posted by Flat Broke View Post
Pacman,
Chris
I'll have to continue to think about it. I'm a big guy at 215 lbs and I plan on putting that bike through a lot, so I'll have to marinate on it for awhile.
The main thing tempting me is the sick deal I can get on one.
PacMan is offline
Old 09-11-2007, 10:46 PM   #19 (permalink)
I build jumps
destroyer's Avatar
So I called Adrenaline Bikes today to make sure they still had the frame before I drove 2 hours to the store. Well they said they sold it yesterday...
Anyone else know a good place to go for a deal on a Preston? I called a few places and quotes from $1100-1300, which sucks because Adrenaline wanted $699.
Old 09-11-2007, 11:14 PM   #20 (permalink)
F.T.W.
J_Sims's Avatar
the old snooze and lose thing actually in full effect..... Sorry to hear the news
Big Thanks to :::
J_Sims is offline
SOLD!!! Yeti 575 frame w/Push'd RP3 for sale TURNERob The Market Place 38 05-23-2008 06:25 PM
Decent beginner Dual Suspension frame? BAD_S197 General Discussion 32 08-16-2007 02:13 PM
Worth on 02 FSR xc S-work frame? Make me an offer foofighter The Market Place 7 07-24-2007 09:54 AM
Tang flavored SPAM - XL Niner one9 SS frame singleSSpeedster The Market Place 10 09-07-2006 09:47 AM
