Old 08-20-2007, 09:28 AM   #1 (permalink)
STR BUB!!
ShinKen's Avatar
Question HeadseT Squick BS?
yeap yeah I hate to complain again but maybe this is a quick fix that other people have run into before and can help me out!!
[FONT=Verdana][SIZE=2]I have a 29er Niner that has a Reba fork. CK head set that I've used on the Redline for a while longer before the Niner. Recently I'm getting this noisy squeaky BS that seems to only happen when I put pressure into the bars!! (On the climbs) I clean the thing I try making it nice a tide and even have the pros look @ it and make it work again but the thing just starts with the same BS again.[/SIZE][/FONT]
[FONT=Verdana][SIZE=2]Questions do many of u Reba and/or CK owners have this lame problem too? Is the CK headset the problem? (I’ve heard some people talk about it). What’s the quick fix? Should I look for a different Head Set brand? What’s good out there? What really works? Should I give a dangg? well, actually I do give a danngg abut this one b/c I don’t want to fudDge the frame up if this keeps going this way. [/SIZE][/FONT]
Help A bRottaa Out mAngg!!! any help would totally rule
http://static.flickr.com/11/91529165_041edc585f_m.jpg
The path of the righteous man is beset on all sides by the inequities of the selfish and the tyranny of evil men."
ShinKen is offline
Old 08-20-2007, 09:31 AM   #2 (permalink)
You may have more mileage on your setup than mine, but I run the Reba with the King Dread-set on my Dos Niner and don't have any handlebar squeaks. Oh, you probably apply a LOT more pressure SSing and being a guy that is bigger than me
allison is offline
ShinKen (08-20-2007)
Old 08-20-2007, 09:34 AM   #3 (permalink)
P. W. R.
J_Sims's Avatar
I have an noise on my RIP with the CK but I write it off to the Mav ft end. My ONE9 has a CK as well and is nice and quiet.
Big Thanks to :::
J_Sims is offline
Old 08-20-2007, 09:37 AM   #4 (permalink)
STR BUB!!
ShinKen's Avatar
Wink
thanks girl!! I do apply lots of pressure when climbing but sometimes I hardly press on the bars and get the same noise!! and thats on not so steep hills this is one really buggss da heck out of me b/c is nothing crazy!!
yeah but that bike is like what a month OLD? plus u have a rigid fork and back when I had the redline rigidd the ride was nice and smooth too!
ShinKen is offline
Old 08-20-2007, 09:38 AM   #5 (permalink)
P. W. R.
J_Sims's Avatar
I know it may be a stretch but remove the headset from the frame, clean everything including the head tube and cups.... Apply small amount of grease to the cups before you press them bac in and your noise may go away
Big Thanks to :::
J_Sims is offline
Old 08-20-2007, 09:39 AM   #6 (permalink)
STR BUB!!
ShinKen's Avatar
Question
the only other possibility is if you didn't put red loctite on your headset when you put it in. it helps to seat it and hold it in place.
Hmmmm I didnt know about that!! but than again I didnt do the installation my self so, hmmmmM Neil?
ShinKen is offline
Old 08-20-2007, 09:44 AM   #7 (permalink)
Yeti. Turner. Niner.
PacMan's Avatar
I have a CK headset and Reba fork on my SS with no creaking, but I have less than 200 miles on my set-up. I'll definitely keep an eye--or, ear rather--out for it.
Less typing...more riding.
PacMan is online now
Old 08-20-2007, 09:45 AM   #8 (permalink)
I like Brett and Turtles!
1x1clyde's Avatar
Check the whole front end....stem bolts regreased, stem clamp for dirt or as USUAL bring it over and I can fix it for you
Painfreak: "With that headline I thought we were going to see CC riding in the buff or something along those lines. That's very misleading ."
PacMan: "I always love the view of you looking over your shoulder."
1x1clyde is offline
allison (08-20-2007), ShinKen (08-20-2007)
Old 08-20-2007, 09:55 AM   #9 (permalink)
I had a squeaks coming from the headset/stem area. I loosed the headset cap and the stem while the bike was on the ground (not on the stand) and then tightened everything up slowly and evenly. Squeaks went away.
Old 08-20-2007, 10:08 AM   #10 (permalink)
I run a reba race and a ck headset on my SS and I haven't had any problems.
Was your headtube reamed for the king headset when it was installed?
Try removing the upper and lover cups and look for and small metal shavings in the headtube or around the bearings and races. Sometimes when a headset is installed the fit is so tight that small amounts of metal can be shaved off and work their way down to the lower bearing and race and start squealing.
Try removing everything including the lower race and put a thin coat of polylube or prep-m on everything and re-install. Wipe off all excess, and ensure that everything is torqued down to proper specs when you re-install.
If that doesn't work try either warrantying it thru CK or buying a replacement bearing kit for it. I have a Cane Creek S-8 you can borrow if you decide to try warranting it, let me know
Old 08-20-2007, 10:13 AM   #11 (permalink)
STR BUB!!
ShinKen's Avatar
I'll let u know if I need the Cane. thanks
ShinKen is offline
Old 08-20-2007, 10:13 AM   #12 (permalink)
Previously, I've had problems specific to Rock Shox forks. The stanchions would creek at the crown. I let some green wicking-type locking compound in there, and that solved it.
I have a Reba and CK headset on my singlespeed, and it's quiet.
When I assemble a headset, I put grease everywhere:
- On the steer tube before sliding the race in place
- Between the headset cups and the frame
- Between all races and bearings
- Although I don't typically do this, sometimes you may need to remove the bearings from the cups and apply grease to the inner portion of the cups, then reinstall the bearings. I've only done this when the bearings easily come out of the cups.
As mentioned, also check your stem and bars.
2wheel_lee is online now
Old 08-20-2007, 10:22 AM   #13 (permalink)
watch out for that pole!
Burner's Avatar
just turn your headphones up higher
The Path... it's worth the drive from LA.
Burner is online now
allison (08-20-2007), SAR_boats (08-20-2007), ShinKen (08-20-2007)
Old 08-20-2007, 10:34 AM   #14 (permalink)
STR BUB!!
ShinKen's Avatar
Talking
usually I do!! but latelly I've done a few group rides with out the phones and well, I notice the noise allot more than b4 plus Andy was nice enough to point it out on the last ride!!
ShinKen is offline
Old 08-20-2007, 10:40 AM   #15 (permalink)
King headsets suck....seriously. it is WELL document that for longer travel forks and singlespeeding, creaking is a big problem (based on its design)....not kidding, they just suck. Cane Creek Solos are far better. I will never buy king again for other than a roadbike, and i dont own a roadbike.
FoShizzle is offline
Old 08-20-2007, 10:40 AM   #16 (permalink)
Ask yourself:
What Would Steppie Do?
Old 08-21-2007, 08:44 AM   #17 (permalink)
TURNERob's Avatar
Ask yourself:
Steppie would go hunk a mattress and forget about it.
TURNERob is offline
guero (08-21-2007)
Old 08-21-2007, 10:04 AM   #18 (permalink)
Baker.
guero's Avatar
rigid s/s mattress hunkerrrr!
tkblazer: pump and dump.
guero is offline
Old 08-21-2007, 10:24 AM   #19 (permalink)
Free-XC-Downhiller
SSinGA's Avatar
Don't buy anything new until after interbike -trust me on this one.
My CK has never squeaked although friends couldn't keep theirs quiet. Check the rubber o-ring inside the top bearing cap. Is it worn, ripped, still there?
I got a Cane Creek Solos for the wife's bike and was very impressed with it. Got one coming for the new spot as well.
www.t2bikes.com
SSinGA is offline
ShinKen (08-21-2007)
Old 08-22-2007, 09:51 AM   #20 (permalink)
