iSlay
i think he is wrong.
slay. |
Evil Chocula (08-16-2007)
Team Brittle
I have Magura brakes w/ Avid rotors and have no problems..I think he was feeding you a line too..
Technically Canadian
Bulls**t..... I switch wheels between bikes with Avids and Hayes and either works fine...
Cant we all just ride along??? |
Homer
According to the mechanic at my LBS, you aren't supposed to switch manufacturers between rotors and calipers. I don't see why not, but he says that's what all the manufacturers recommend. He says that different rotors are different thicknesses and shouldn't be inter-changed.
Like I said, it seems kind of stupid to me, but that what he says.
Less typing...more riding. |
Whatever!!!
bjammin (08-16-2007)
Homer
Not a chance in heck.
Like I said, I don't care one way or the other, just repeating what I was advised.
Less typing...more riding. Last edited by PacMan; 08-16-2007 at 08:06 PM. Reason: Automerged Doublepost |
Evil Chocula (08-17-2007)
Turnbull haze
I've been using avid rotors with hayes brakes for two years now. Zero issues. |
going my speed since 1975
This is just my opinion that comes from my personal experience...
Those cheap rotors that come with the avid mechanicals don't work with the older hayes if you have a standard setup. For me, they are too thick and just a milimeter too tall to so they rub the caliber. I had to shim the caliper up but I still get a lot of rub no matter what I do. The caliper just doesn't pull back far enough on either side. I originally though the alignment was off, but it really just a little too thick. |
Homer
That was the other point I forgot to include. The every rotor does not have the same shape/size braking surface, so pads may wear unevenly.
#12 (permalink) | |
Exiled Brit
![]() The gauge of the rotor shouldn't be an issue since this can be remedied by making a minor caliper adjustment. After all, a rotor is a rotor is a rotor...
"Britain and America...two great nations divided by the same language." -- Winston Churchill |
Evil Chocula (08-17-2007),
Neccros (08-17-2007)
My Avids are shaped similar to my Hayes so the "different shapes cause pads to wear differently" goes out the window!
I agree... I had to adjust my brakes a little when I swapped wheels but it was about a 5 min adjustment....That was due to the width of the hub and not the thickness of the rotor...
Steve Peat Wannabe
If bjammin's around he could tell you. I think it's not recommended because producer A makes a rotor with a 2" wide braking width, and a matching brake pad with a 2" with, but producer B makes a rotor and brake pad with a 1.5" braking width. So, if you use producer B's brakes with producer A's rotors, you're not going to get the braking power you need. Or at least something to that effect.
That being said, many have the same braking area, so you can switch out brakes & rotors between many of the manufacturers. |
Free-XC-Downhiller
As long as you make sure that your rotor is sweeping the entire pad, which can be adjusted with spacers or maybe a little dremel work to the brake adapter (assuming you are using one), most rotors will interchange between brakes. I believe that most rotors are 2mm thick as well - of course there will be some fluctuations.
I used to use Hope Gothic rotors with my Hayes Purples and am currently using Hope 2 piece rotors with my Avid Juicy 7.
www.t2bikes.com |
Bend over
sounds like EVIL went to Jax in Fullerton...
sales guy..."no the rotors are not compatible, for the rotor to work right you have to buy all new brakes, but these brakes only work with this high end fork which will only work with this limitied edition carbon Frame that you will have to put a 3,000.00 dollar deposit on and wait 6 months until we get them in. now for the bike to pedal correctly you really need to buy all this gear that i have no idea what it is for or what it does...will that be cash or charge? oh for you to use your card that is an additonal 10%" thanks and come back soon. |
#17 (permalink) | |
AKA Optimus Rabbit
Haha... it wasn't Jax, but that sounds like at least three bike shops I've been to in San D.
| 160mm rotors or 185mm ? | ET_SoCal | General Discussion | 17 | 06-26-2008 01:44 PM |
| New Hayes rotors and pads are dragging | nouse66 | The Workshop | 15 | 07-17-2007 10:46 AM |
| Avid Juicy 5 brake set 180mm rotors (all black) $125 | Padre | The Market Place | 5 | 02-23-2007 08:00 PM |
| Hayes HFX-9 HD Dixc / 205 mm rotor F+R's are really bad brakes. What can I do?! | UseItOrLooseIt | The Workshop | 20 | 08-25-2006 09:47 PM |
| Anybody used Avid BB7 Mech Disc Brakes? | pshloss | The Workshop | 20 | 04-29-2006 01:53 PM |
