Old 08-07-2007, 10:39 PM   #1 (permalink)
Default UST tires + Stan's + Floor Pump = work out
So I noticed that i was developing some little tiny pin holes in my tires. So i decided to hit The Path and pick up a bottle of Stan's. Thought, no biggie easy peasy, pour in the requisite amount into the tire and pump the tire back up.
Right. For the next 20 minutes, I was pumping feverishly to get the bead to seat properly to hold air. It was absolutely comedy, i can only imagine what my neighbors where thinking as i was pumping the hell out of the tire not knowing that it's a tubeless tire. LOL
An air compressor would have made quick work out of this task. But i finally got the tire to seat and instantly noticed the white liquid seeping through the 4 or so pin holes in my tire. Hats off to this product!
Anyone have tips for reseating the bead on UST tires? Is there some trick that I dont know about?
www.coverageispersonal.com
foofighter is online now
BrewMaster (08-13-2007)
Old 08-07-2007, 10:56 PM   #2 (permalink)
Yeti. Turner. Niner.
PacMan's Avatar
I went through the same deal when I built my SS. I decided to go UST rims and tires with a bit of Stan's for good measure. After 10-15 minutes of futility, I gave up and got a Schrader adapter from my LBS the next day so I could use my air compressor.
Less typing...more riding.
PacMan is online now
Old 08-07-2007, 11:00 PM   #3 (permalink)
that thought came through my mind SEVERAL times...compressor would have done the trick.
Old 08-07-2007, 11:09 PM   #4 (permalink)
Buzzsaw's Avatar
The compressor works really well. But, if you are just re-filling Stan's into your setup then just take out the needle. It should screw out. fill-in with amount of stan's, replace needle and fill it back up with air. This way you don't have to break the bead. (Not sure if this is what you did in the first place?)
I know what you went through. I just did that song and dance a few days ago. It's not fun, it's gotta look even funnier to watch and can work up a good sweat in no time. I forgot about the whole needle thing.
Ellsworth Epiphany
BRC Member
D37
Buzzsaw is offline
foofighter (08-08-2007)
Old 08-07-2007, 11:13 PM   #5 (permalink)
bjammin's Avatar
If you soap the heck out of the beads, it acts like a seal to help get the beads to seat.
bjammin is offline
BrewMaster (08-13-2007), foofighter (08-08-2007)
Old 08-07-2007, 11:13 PM   #6 (permalink)
lol yah after i got the dam thing seated i thought, that's why stan sells that dam needle removal tool! i could have just done that and would have save me a lot of sweat
Old 08-08-2007, 08:12 AM   #7 (permalink)
Just another slacker.
Sprockethead's Avatar
Hey Foo,
Yeah, what Ben said, if you soap up the bead real good, it'll help seat the tire. The first time I did this, it was pretty easy. I hung the wheel off my bike stand. Soaped up the bead, added Stans, soaped up the bead and start pumping. The tire came right up. The second tire, I had to smack around to get it to seat.
Note, this only works on new tires. Once the tire has stretched, it's virtually impossible to reseat with a floor pump. You might as well get a schrader adapter and use an air compressor. I don't have a air compressor so I get everything set first then drive down to the gas station and fill it up. I bring a small cup of soapy water and brush with me. Oh yeah, soapy water makes getting the bead over the rim quite easy.
Sprockethead is offline
bjammin (08-08-2007), BrewMaster (08-13-2007), foofighter (08-08-2007)
Old 08-08-2007, 08:28 AM   #8 (permalink)
well lesson learned for the front tire...i'm either A) going to pull the needle and fill it that way or B) get a nice compressor to pump enough air to make that puppy seat...just like mounting tires on a dam car hehe
Old 08-08-2007, 08:32 AM   #9 (permalink)
Bad 5%
Winston's Avatar
Keep a C02 handy for times when the floor pump just isn't cutting it.
Winston is offline
Chaos (08-09-2007)
Old 08-08-2007, 09:07 PM   #10 (permalink)
Also, unless I'm mistaken, Mavic valve stems don't have a removeable core. Step one: Buy Stan's valve stems. Step two: buy an air compressor. It's very rare that I can seat a tire with a floor pump.
If you watch the video on the Stan's website and follow it precisely you shouldn't have any problems.
Old 08-08-2007, 09:13 PM   #11 (permalink)
PacMan's Avatar
CO2 will turn all that nice liquid Stans into a rubber ball. just so you know
I did not know that. It totally makes sense, which is probably why it never occured to me.
Old 08-08-2007, 09:49 PM   #12 (permalink)
Steve Peat Wannabe
project_d's Avatar
Bingo, give this man a cigar. The Stan's valve stems have that feature; Mavic valve stems do not.
project_d is online now
Old 08-08-2007, 09:54 PM   #13 (permalink)
that's really good to know about the stems! i think i actually bought some on Tani's advice the other day when i accidentally bent my needle w/ a portable hand pump.
Old 08-08-2007, 09:55 PM   #14 (permalink)
Steve Peat Wannabe
project_d's Avatar
Listen to bjammin. This really does help the bead to seat. Also, if you don't have access to an air compressor, here's what I've found works:
If you have the stem pointed upwards (meaning it is closest to the ground it can get), the air pressure going into the tire will actually push the Stan's towards the bead, and help to seat the bead.
Old 08-09-2007, 07:01 AM   #15 (permalink)
Default lots of good info so far
You can get a compressor for like $79 at Harbor Freight.
thephat is online now
Old 08-09-2007, 07:37 AM   #16 (permalink)
A little dab will do me
spookydave's Avatar
little starting fluid and a match is all ya need. lol
http://video.google.com/videoplay?do...arch&plindex=5
spookydave is offline
Old 08-09-2007, 08:11 AM   #17 (permalink)
i looked in my tool box this morning and found that the stem that i purchased at the Path is indeed Stan's good looking out Tani!
Old 08-09-2007, 10:06 AM   #18 (permalink)
Steve Peat Wannabe
project_d's Avatar
The new Mavic stems have removable cores. Allison has one on her bike!
Dude, you don't have to lie to make friends.
But seriously, they do now? Huh, I just picked up an XM819 yesterday from The Path, I'll have to check out the stem on it.
Old 08-09-2007, 10:53 AM   #19 (permalink)
Baker.
guero's Avatar
i'm looking to get the dt swiss kit soon for my ex 5.1d's, but i will use the stans juice instead of the stuff dt provides. most of the bubbs i know havent had much success with the dt juice.
when not using turnerob's compressor, the compressor at the arco station by my pad comes in handy.
tkblazer: pump and dump.
guero is offline
Old 08-13-2007, 01:19 PM   #20 (permalink)
This is good to know. Now, when I upgrade to tubeless I won't have to go through the frustration of trying to seat the bead with a floor pump.
RR: Mt. Zion/Chantry Flats (incl. trail work) gurp13 Trail Talk 17 12-05-2006 08:08 PM
More Trail Work JamR Trailhead 5 11-07-2006 08:26 AM
Tires and Size Jordansrealm The Workshop 18
