Old 08-03-2007, 07:44 AM   #1 (permalink)
Default Replacing brake levers on Juicy 5's ...
So it looks really simple but is there something i need to be aware of? I don't want to hydraulic fluid spraying everywhere when I replace them and there isn't anything in the manual about. Thanks.
mullarks is offline
Old 08-03-2007, 08:59 AM   #2 (permalink)
Noog'alish
danny, are you talking about the actual mechanical lever on the brake or the entire lever assembly?
Denmother: I had the sausage sampler, it was yummy!
Guero: i'm easy
mullarks (08-03-2007)
Old 08-03-2007, 10:02 AM   #3 (permalink)
yeah... are you replacing the entire lever assy?
if you are doing that, there is no pressure in the line (unless you squeeze the lever)
if you are replacing the lever blade...
loosen the set screw that holds the pivot in the blade, remove the pivot pin, then turn the adjuster screw (in lever blade also) to the right until the blade comes off.
mechmann is offline
Old 08-03-2007, 11:51 AM   #4 (permalink)
Just the actual brake lever blade.
Ok cool, it looked really easy but knowing my luck I would pop off the lever and fluid would start spraying all over the place. Too many not so fun experiences working on cars.
mullarks is offline
Old 08-03-2007, 11:53 AM   #5 (permalink)
genusmtbkr5's Avatar
Hope you can have your bike ready for the Beek's ride tomorrow.
Gene"GuidesNewWarriors"
http://www.sharemtb.com/
genusmtbkr5 is online now
Juicy 5 Question Rossage The Workshop 4 05-21-2007 07:42 PM
extra brake levers???? roadkillross The Workshop 5 03-02-2007 10:35 AM
Avid Juicy 5 brake set 180mm rotors (all black) $125 Padre The Market Place 5 02-23-2007 08:00 PM
Brake levers scorns General Discussion 6 10-31-2006 09:43 PM
Marta brake problem Tortuga The Workshop 3 12-31-2005 10:26 AM
