Is the sliver aluminum fitting from Hayes required to bleed the HFX Nine brakes? Obviously I don't want to puke fluid out of the lever all over everything, but is the silver fitting a small check valve or is it just an adapter to get a hose into the bleed hole so that fluid can drain cleanly into a catch bottle for inspection for bubbles etc?
The syringe and hose isn't a problem, and I understand the procedure, but I was curious about the fitting. My rear is a little soggy, and probably needs a fluid change, so if I need to buy the fitting b4 I start it'd be good to know. Thanks in advance, Chris |
| New Hayes rotors and pads are dragging | nouse66 | The Workshop | 15 | 07-17-2007 11:46 AM |
| Hayes Stroker | BFloFoxRider. | The Workshop | 24 | 05-21-2007 04:46 AM |
| hayes adapter (front fork) | FyrFytrRyn | The Market Place | 0 | 09-10-2006 09:11 PM |
| Anyone know of shops that stock hayes items? | EndoMaster | General Discussion | 4 | 03-23-2006 02:53 PM |
| sticky hayes lever? | LBmtb | The Workshop | 4 | 03-31-2005 09:00 PM |
