Gravity is your friend
Hey brain trust... i just bought a new bike and have a couple of rides on it... i've already had both wheels off the bike for various reasons.. hate those darn thorns... haha
Question - my front disk seems to be rubbing against the brake pads... the tire will rotate a few rotations before stopping but i think its enough to ask the question - is the disk rotor supposed to be rubbing the pads? any thoughts or insight on how to correct this without taking it to a bike shop?? Thanks!!! |
Has it rubbed since new? If not, you most likely squeezed the brake lever with the wheel off. To fix take the wheel(s) off and push the pistons in with a plastic tire lever. Install the wheels and you should be good. Some brakes may require you to pop the master cylinder cap off (make sure it's level and clean first) to push the pistons in.
If it rubbed since new, it's most likely not installed correctly. Depends on if it's post mount or I.S. for the instructions. A little more info on your situation would make a diagnosis easier. C
Suck on these
most likely the piston assembly is out of alignment. all u really have to do is check which side is rubbing and slightly untighten the bolts for assembly and move it the opposite direction from the rubbing side and retighten bolts
Why ask why, does it really matter???????? |
your hero
Once worn in after a ride or two a disk brake should run free, without rubbing when the bike is in a stand. Most disks will rub when sprinting or during hard cornering.
Gabriel Zink Adrenaline Bikes 714-288-2012 If you are local bring it by and I will check it for free. |
Thank God For Stevens
My Tektro discs never rub even when I do one footers.
STEVENS ARE THE BEST! |
Von-Diggity (07-06-2007)
| XT Brakes and Specialized Glasses F/S | PodiumEnvy | The Market Place | 0 | 03-05-2007 08:28 PM |
| Front brakes on the right | ubermensch | The Workshop | 14 | 02-08-2007 10:01 AM |
| how are these brakes | roadkillross | The Workshop | 9 | 10-11-2006 10:46 AM |
| Hayes HFX-9 HD Dixc / 205 mm rotor F+R's are really bad brakes. What can I do?! | UseItOrLooseIt | The Workshop | 20 | 08-25-2006 10:47 PM |
