Old 05-22-2007, 03:07 PM   #1 (permalink)
0gravity's Avatar
Default Fork upgrade question
So I've got an 06 Giant Trance 2 (pictured) that's been a great do-it-all rig but I've always wanted more front travel. Separately, I've got a nice hardtail frame that I want to build up over time. So I'm thinking of putting the REBA on this other hardtail and then stepping up to something like the Fox 32 Talas RLC for the Trance.
Some questions...
- In general, do you think the Trance can handle a longer travel fork? The Fox 32 Talas RLC has adjustable travel from 4 inches to 5.5 inches. That doesn't seem to me to be too much for the bike. The front end looks pretty beefy on the bike. Yeah, at full squish it will raise it up a bit, but that's OK on downhills anyway. I'll probably lower it for all climbs.
- Are there other forks I should consider in that 5 to 5.5 inch range? A lock-out is a must.
Thx
0gravity is offline
Old 05-22-2007, 03:17 PM   #2 (permalink)
Noog'alish
a lot of the trance guys are running pikes on their bikes so the talas shouldn't be a problem. the adjustable travel is key
Denmother: I had the sausage sampler, it was yummy!
Guero: i'm easy
Old 05-22-2007, 03:31 PM   #3 (permalink)
genusmtbkr5's Avatar
I have a 100/130mm Rockshox Revelation U-turn w/lockout. It weighs more than the talas but cost much less. It's an all mountain fork and I loved it.
SRAM | RockShox | All Mountain | Revelation
Gene"GuidesNewWarriors"
http://www.sharemtb.com/
genusmtbkr5 is online now
Old 05-22-2007, 03:33 PM   #4 (permalink)
Edog's Avatar
I think a Pike would be a little over kill on this bike, IMO. It's a little on the heavy side more so with the 20 mm hub, so you'd need a new front wheel! I run the Pike on my Reign & it's a great shock. I've been looking at getting the Trance for those longer all day events & I think I would slap one of these puppys up front.
Beat me to it
Ya that's right!
Edog is offline
genusmtbkr5 (05-22-2007)
Old 05-22-2007, 03:40 PM   #5 (permalink)
Noog'alish
hell yea, another reign rider
i also agree on the pike being a bit much, but thats what some guys run i dunno... revelation would be good, as would the talas. a marz xc 700 sl would be freakin sweet
Guero: i'm easy
Old 05-22-2007, 04:04 PM   #6 (permalink)
0gravity's Avatar
This is a great start guys, this gives me more options. That Revelation does seem nice, especially that it's cheaper than a FOX and I could throw in the pop-lock. I dig! I'll start running some comparisons. Either way, I think I'll be psyched. The rear end of this bike can take way more abuse than the front end 4" REBA can take so stepping up to 5 inches will be a big improvement (plus, I'm not getting a full 4" out of that REBA anyway).
0gravity is offline
Old 05-22-2007, 09:46 PM   #7 (permalink)
m210's Avatar
i agree with the revelation. i have a rev 426 on a heckler. very plush but not soft. my favorite fork so far.
m210 is offline
Old 05-22-2007, 10:31 PM   #8 (permalink)
Lebowski Urban Achiever
Waldo's Avatar
OGrav - I used to run a 2004 Talas (80-105mm travel) on a bike with about 3.5" of travel in the rear. Most of the time I'd keep it in the middle of the travel range and it was fine. For very steep climbs or nastier descents, I'd take it to one end of the range or the other, and it worked well. I now have a Reba Team on a 3.5" travel bike, and my only regret is not getting the externally adjustable travel version of the fork.
One thing to check: I know Giant has a very generous frame warranty, so you should make sure that running a longer-travel fork won't void the coverage. Otherwise, I'd say go for it.
"My ass is sore after a long ride." - MtnKitty
Waldo is offline
Old 05-23-2007, 06:57 AM   #9 (permalink)
Up da middle up da middle
I'd go Revelation if I was you. Much beefier crown than the Fox. Plenty of adjustments and nice price. I'd definitely go U-turn. You could save some coin by going coil U-turn but it'll weigh a bit more.
Pho'dUp is online now
Old 05-23-2007, 07:01 AM   #10 (permalink)
Burner's Avatar
does the revelation have a maxle option?
Pho'd Up: I already really enjoy the little captain in the rear.
Pho'd Up: That F'ing Captain bites me in the arse again.
Burner is offline
Old 05-23-2007, 07:10 AM   #11 (permalink)
Ditto the recommendations on the Revelation. A friend has one on his MKIII, and the fork is very nice. The floodgate is an awesome "on the fly" type tool once you have it setup properly. His is the air version, and it's one of the nicer air forks I've felt.
Something to think about: the Revelation is a QR dropout chassis Pike, same dampening etc. So if guys like the Pike for it's feel, the revelation will get the same reviews. As far as saving weight by going Revelation vs. Pike, I'd do a little research on that and maybe think with an eye towards the future. If you ever think you might want to get a little more agro (either with the Trance or another frame of similar travel), the Pike will be torsionally stiffer because of the 20mm axle.
Either fork is great for your application, but having made parts purchases only to have to unload them at a loss and pay for the part a second time when my needs/wants changed, I thought I'd throw that out there.
Chris
Flat Broke is offline
Old 05-23-2007, 10:42 AM   #12 (permalink)
0gravity's Avatar
Chris
That's something to consider but a 20 mm axle means no front quick-release, right? That would then complicate transporting my bike since I use basic Rocky Mounts that require a quick release front end.
The Revelation has gotten such rave reviews here, I'll probably go that route (but maybe still the Fox). Either way, I need/want a quick release for now.
0gravity is offline
Old 05-23-2007, 02:42 PM   #13 (permalink)
ODB
Team Sting-Ray
ODB's Avatar
Don't let that dissuade from going with a thru-axle. Fork-Ups have got you covered: Hurricane Components
ODB is offline
Old 05-23-2007, 11:17 PM   #14 (permalink)
never say never
cru jones's Avatar
I ran a revelation(air) on a 06 mk iron horse that i rode for about 5 months. For the pricepoint that its at, it cant be beat. If youve got the extra coin, i'd def. go with the talas.
cru jones is offline
'06 Fox 36 Vanilla RC2 fork TURNERob The Market Place 25 04-17-2007 07:07 AM
Which fork? Flat Broke General Discussion 12 10-08-2006 06:47 PM
Manitou Sherman Breakout Plus fork for sale TURNERob The Market Place 1 06-25-2006 01:54 PM
Choosing a rigid fork EndoMaster The Workshop 8 04-05-2006 11:59 AM
RS Pike Team fork for sale! TURNERob The Market Place 24 09-19-2005 11:27 AM
