I replaced my big ring with a bash ring a couple weeks ago. I had the chain drop off in 1x1 last week. It happened once before but I started thinking. Should I remove a couple links since I don't have the big ring anymore?
I have a new crankset and chain arriving today and I was thinking if I should keep the chain length the same or try a link or two less. Not sure what the advantage would be but I thought I would ask you folks. What do you folks think? |
when i did the same thing the guy i bought the bash guard from told me to put the chain on big in front and big in back, pull it tight and then back off two links. Not sure if this the the proper way to set the length but i have never had any problems so....
No Longer Riding
i think the rule of thumb is to run the chain on the biggest chain ring you have and on the biggest cog in the back, but not run it through the derailluer. Measure how many links you need and then add two links to that.
edit, Park Tool has a somewhat better explanation eh Chain Sizing - Largest Cog and Largest Chainring Method An alternative method for determining chain length for new chains is to use the largest size sprockets on the bike. It is easiest to size the chain without threading it through the derailleur.
#4 (permalink) | |
Thanks. |
Having upgraditis is OK
Whether it's 4" or 7" doesn't matter as much as the distance that changes between bottom bracket and your rear axle. Depending on their axle path, they might even have the same amount of chain growth. |
biglimey (01-25-2008),
RacinJason (01-25-2008)
A little dab will do me
that's kinda what I'm getting at. The one way for all does not seem right to me.
My 9" travel Brooklyn has zero chain growth and I know my bullit has a bunch. Seems like you would want to know before you install the chain. I take the shock off and run the swing are up and down and find the max lenght. Then do the wrap chain and add 2 links bit. Donno if I'm doing it right but so far I'm not bending stuff due to not enough chain. |
I did the install of my new crankset and chain this weekend. Everything went great. I ended up running the chain through the rear derailleur. I set it so my cage is at the 5 o'clock position when in the biggest gears. Everything is shifting fine and did all the regular test to make sure that everything fit right.
Thanks everyone for the help. |
Mark Reynolds
here is a post on my blog about chain lenght.
http://wickedracin.blogspot.com/2008...in-length.html Hope it helps |
Welcome wickedracin...
Might I suggest going into the "Introduce Yourself" forum so the whole class knows who you are. No need to worry or feel nervous, there's only a couple people here that bite.. |
Dirty Boo (01-27-2008),
wickedracin (02-19-2008)
defending Lady Singletrac
When sizing a chain, compress the suspension so it is at the point of greatest chain growth, wrap chain around the biggest cog and ring you have without routing thru the derailleur, pull tight, then add 2 links, incuding any master link. Sometimes with the master link, its kinda wierd, it can seem like it will only work if you either add 1 or 3 links. better to do 3 than 1.
| anyone going to the jensonUSA 'end of summer bash'? | LBmtb | General Discussion | 7 | 09-06-2005 11:05 PM |
