Old 03-11-2007, 01:41 PM   #1 (permalink)
Riders on the solar storm
PHAT TIRE's Avatar
Default Fox Rear Air Shock BUSHING?
My Fox rear Shock bushing is so worn. There's a slight vibration and movement that is slightly annoying. The shock itself is in great shape. Here's my questions
A. Should I try to find a bushing and repair it to save the $100+ for a new rear shock?
B. Has anyone done this or is it a worthless cause?
C. I can install bearings so this is no brainer right?
D. Where do I buy a bushing? Manufacturer or home improvement store, etc.?
Thanks..one guy , four bikes, one garage, no parking!
PHAT TIRE is offline
Old 03-11-2007, 01:42 PM   #2 (permalink)
you're talking about the aluminum bushings that the the bolts go through right? most LBS should have some in stock, but i'm not sure if they would have the size you need. its best to bring the shock in with you so they can see what size you need.
PHAT TIRE (03-11-2007)
Old 03-11-2007, 03:34 PM   #3 (permalink)
your hero
Gabriel Zink's Avatar
Default du bushing
most of the time the eyelette bushings are ok the inner du bushing is what wears out they are cheep but you need a special tool to get them out, we have them at the shop
Gabriel Zink is offline
Old 03-11-2007, 09:37 PM   #4 (permalink)
drive monkey, drive!
dirttorpeedo's Avatar
Talking
the bushing you speak of is a bronze bushing,spookydave kood make one cheap??? or order one,and have a good shop install it for you.bronze bushings are not to be obtained at HOME DEPOT.they are made for and by the shock manu facterer.most of them are oil impregnated,so as to lubricate as time goes on for wear porposes.hope that helps,sorry to drage on tho.....
dirttorpeedo is offline
Old 03-12-2007, 04:57 AM   #5 (permalink)
Bend over
soul rider's Avatar
call fox 1-800-fox-shox
soul rider is offline
air shock ? roadkillross The Market Place 8 02-09-2007 09:53 PM
Fifth Element Rear shock bikebike69 The Market Place 2 11-07-2006 01:25 PM
Looking for 7.5x2.0 rear shock jruiz The Market Place 3 10-30-2006 09:08 AM
Rear hub on it's way out???? ECOdork The Workshop 6 10-03-2005 08:30 AM
'05 Weyless 67 (med) frame w/Manitou Swinger 6-way shock F/S TURNERob The Market Place 6 09-29-2005 04:26 PM
