Old 02-06-2007, 12:28 PM   #1 (permalink)
Buzzsaw's Avatar
Default Wheel trueing
Hope somebody can pitch in and help me out.......
The past few rides I noticed my front wheel "creeking" and popping. It has been happening while "just riding along" and has been doing it more and more.
So, I pulled the wheel off and put it in the truing stand. As I checked the spoke nipples to see if any were loose I found that all the spokes on the disc side were super tight. The spokes on the other side were all loose. They weren't loose enough to spin with my fingers but snug, turning pretty easy with a spoke wrench. I did two cycles around the wheel, tightening the weak side about a total of half a turn.
Any help in what this might be? The wheels are fairly new, about a year old.
Ellsworth Epiphany
BRC Member
D37
Buzzsaw is offline
Old 02-06-2007, 12:41 PM   #2 (permalink)
SolarFederationMember
gurp13's Avatar
Spokes can pop and ping when they have been tightened and they are seating themselves. Some lube on the nipples can help them turn better without turning the spokes themselves and could help deal with this problem. I don't know a lot about trueing but I would think that the spokes being tight on one side and loose on the other might be a sign of a problem. You can spin the wheel while the bike is in a stand and eyeball it to see if it's out of true. But, the only way to be for sure for sure is to use a truing stand.
gurp13 is offline
Old 02-06-2007, 02:15 PM   #3 (permalink)
No Longer Riding
i've never even tried to true a wheel, but i would be interested in the process. I've read some sites like sheldon smith and the like. I guess i'm more of a visual learner
Old 02-06-2007, 02:38 PM   #4 (permalink)
deleted
Old 02-06-2007, 03:46 PM   #5 (permalink)
1_fez_rider's Avatar
The spoke lube that Gurp recommended is a good idea. When I first got my Fezzari Alta Peak, it popped and pinged the first few rides. But now its fine.
1_fez_rider is offline
Old 02-06-2007, 04:24 PM   #6 (permalink)
Lor
Lor's Avatar
I've dealt with this riding motocross. Your rims should be seated if they are a year old and have been ridden on. My suggestion is what you've done. Tighten the loose side in the truing stand put it on and do a quick ride with some strong breaking, turning, and acceleration. You should hear some pops or creaking at first but should go away after awhile. If it doesn't then I would have you LBS take a look for safety. Good luck!
Lor is offline
Old 02-06-2007, 06:53 PM   #7 (permalink)
trail sanitizer
jfromlv's Avatar
A touch of lube between the rim and nipple helps as well.
“Tani, dude, them Incycle guys have matching pants, we’re screwed!”-Winston
jfromlv is offline
Old 02-06-2007, 06:57 PM   #8 (permalink)
Booze Bikes n Boomsticks
Just a thought but you may want to check the torque on the spokes.
Old 02-07-2007, 09:32 AM   #9 (permalink)
Buzzsaw's Avatar
Thumbs up Creeking solved....!!!!????
went on a ride this morning and was pretty stoked to NOT hear the creeking and popping.
I did all the above:
Grease/tighten spoke nipples/checked skewer.
No noise is good noise.
Thanks
Ellsworth Epiphany
BRC Member
D37
Buzzsaw is offline
Looking for a new front wheel andino The Market Place 15 01-24-2007 07:28 PM
Chris King/Mavic 317 rear wheel TURNERob The Market Place 10 11-16-2006 11:28 AM
looking for a front wheel.. b-rad! The Market Place 3 09-12-2006 04:37 PM
Wanted: 20mm thru-axle wheel scruffylooking The Market Place 2 05-17-2006 02:50 PM
xc wheel set trade/sell? flyingmonkey The Market Place 4 03-08-2006 02:01 PM
