#1 (permalink) | |
Registered Cool Guy
So I made the switch from air fork to coil and I don't really know how to tune the thing. The fork I have is the OEM Pike built for the Pitch Comp and it lacks a preload knob so all I have is the rebound and u-turn.
Right now it has the medium spring installed. I like the plushness and the sag is exactly 20mm. I put a travel indicator zip-tie on it and I seem to be using all of the fork travel. Sometimes though it feels a bit too soft, like under braking force it compresses more than half way. Should I go for the firmer spring?
#3 (permalink) | |
http://www.universalcycles.com/shopp...s.php?id=30476
Pay attention. You ride down a road. You rode your bike today. |
Chewyeti (12-29-2009)
A little Shaggy
well, fwiw it seems that you're looking at about 15% sag on the fork (not that much), so I'm going to go with it being oversprung if anything.
your problem is with the lack of a compression damper. if it doesnt have the Motion Control cart on the right leg (blue knob), then you're going to have a kinda divey fork. I have a domain, and it doesn't have a compression circuit, and it's essentially the same deal. great plushness at proper sag, but pretty much no control of the suspension movement (especially in heavy braking). If you want to make it tuneable, have your LBS order you a 32mm MoCo cart with gate valve, and all should be well. should just need to check oil height and drop it in. EDIT: in response to rivet, to my knowledge, heavier oil won't do anything on the compression side of things if he doesn't already have a MoCo damper. all it will do is unnecessarily slow down his rebound.
Chewyeti: you're like the Kool-aid man, but full of carnitas freekengo: oooooooooohhhhhhhhh yyyyyyeeeeeeeeeeeaaaaaahhhhhhhhh! SIXSIXONE --- Division26 --- Point1 Racing --- Royal Racing |
Chewyeti (12-29-2009),
Rockinthecasbah (12-29-2009)
Darren |
DISCO (12-29-2009)
Sure it will.....why wouldn't it? The only difference between a Motion control fork and the OEM is the non-adjustability. You've still got a compression damper assembly, It may be a simple orifice damper (I'm not sure what it is) as opposed to a wave washer assembly but heavier oil will certainly slow things down.
Darren |
#10 (permalink) | |
A little Shaggy
the way rock shox works, either you have compression and it's adjustable, or you have none. He likely just has a cap on top to keep oil from falling out. I see what you're saying though, and I'm betting you were thinking of the regular MoCo with no adjustable gate (its hidden inside).
That almost sounds hard to believe. That fork must work terribly.
#12 (permalink) | |
In fact, this setup is no different than running a MoCo Pike with the compression adjuster set to full open. Darren |
DISCO (12-30-2009)
#15 (permalink) | |
Registered Cool Guy
I'll see about adding the MoCo later on but for now I like how it feels. Did a bunch of my favorite trails today and it handled pretty well. Thanks for the info on this.
DISCO (12-30-2009)
#16 (permalink) | |
#17 (permalink) | |
Darren |
#18 (permalink) | ||
Registered Cool Guy
![]() I'm mainly looking at this damping so the fork will resist bottom outs and diving while being plush at the top of travel with proper sag. Sound about right? Or can this be accomplished by getting a firmer spring? At this point I can't afford to do both, so its one or ther other.
At that rider weight you have to go up in spring rate for sure. Having too soft of a spring can make the suspension feel harsh as well as have the effect that you're describing in regards to excessive fork dive. Start there for sure. The replacement springs are $30.
Darren |
#20 (permalink) |
Yeah, if you are bottoming out it's time for the black. Personally I think the MoCo is better suited to air shocks than coils and just run rebound for longevity, when it's cranked down there is virtually no bob and it's still active on medium to big hits. All the little nit picky adjustments might matter on a flimsy carbon hard tail with 80mm of travel, but a bigger bike like the enduro will be more fun to set, forget, and rail.
Garrett (12-30-2009)
| FS: Pike - Outlaws - Saint Brakes - Pedals - Stem - Bars - Tires | Matt13 | The Market Place | 27 | 12-12-2009 12:42 PM |
| DIY Pike Dual-Air to U-Turn | Suunaabas | The Workshop | 5 | 05-22-2009 08:08 PM |
| Question about a Pike | BFloFoxRider. | General Discussion | 3 | 09-16-2008 07:00 AM |
| Pike internals into a reba 29 - with a twist. Question? | Chewyeti | The Workshop | 4 | 08-23-2008 08:46 PM |
| Pike Air vs Reba Air | tbowren | General Discussion | 13 | 06-10-2008 01:11 PM |
