How far is it stuck down in the travel Frank? If it is less than half way or so try the 250psi inflating trick (which probably won't work). If not it really is simple to fix yourself, no need to send it into Fox. You just need to unscrew the air can slowly with a towel wrapped around the shock so it doesn't pop apart and fly off once you break the seal. Then you'll just need to lube up the piston seals and put a few cc's of synthetic motor oil (that is what I used) on top of the piston before you screw the can back on. You should do this about every 6 months or so and you'll never have to worry about getting stuck down again
#6 (permalink) | ||||
STR Lurker
What he said, take it off your 6-Pack
Does not surprise me, there is a reason why we are loyal Homers.
SolarFederationMember
Hmmm. While I hope not to have to see what Specialized's customer service is like, I'd be interested to know. I'm a firm believer that, generally speaking, you get what you pay for. I'd like to think that if I'm going to pay upwards of $3-4K for a bike that it would be worth it. However, since my wife has been asking for a Coach bag for a while now, I'm not sure you always get what you pay for. I mean, after all, a flipping Coach purse goes for at least $300 and, in my mind, a perfectly good purse of equal usefulness will go for 1/4 of that. So, I'd be glad to know of Turner's are really worth all that money or if there's a bit of a "Coach" factor there. I am somewhat convinced because many of you who ride Turners seem to be pretty down-to-earth cats who aren't necessarily into bling, per se. You don't seem the type to buy a Coach bag to impress. But, still. Maybe you drank some Kool-Aid some place or something.
