Old 09-18-2009, 02:24 PM   #1 (permalink)
Intense Whore
mfoga's Avatar
Default Fork Service Question
So I was working on my fork (Lyrik) today and noticed that the little spring on the seal is broken. Is it really needed?
Originally Posted by minhster View Post
i have the Kyle Struat knee pads. they were also especially nice when you have to be on your knees to work
mfoga is offline
Old 09-18-2009, 05:30 PM   #2 (permalink)
Drakethomas's Avatar
If you are referring to the tension spring for the external rod wiper, yes they are put there for a reason. That is, over time the seal and stanchion wear. In doing so the amount may be minimal, but it is nonetheless wearing, by using a tension spring you are accomodating this wear occurance.In short it helps provide seal pressure even when the seal is slightly worn.
Independent Suspension Operation isotuned@yahoo.com 619.760.6261
Drakethomas is offline
Old 09-18-2009, 06:51 PM   #3 (permalink)
Intense Whore
mfoga's Avatar
So it will live for the time being until I can get a new one.
mfoga is offline
Old 09-18-2009, 07:19 PM   #4 (permalink)
DirtymikeTDB's Avatar
As long as a new one isnt three years off...... Yeah your fine for a bit, just plan on getting new seals
www.hookit.com/members/dirtymike
I Shamelessly Plug Sponsors as needed!!!
Team GSDR.....God Speed Devil's Rage
DirtymikeTDB is offline
Old 09-18-2009, 09:04 PM   #5 (permalink)
Intense Whore
mfoga's Avatar
It sucks that my seals are fine and had it all back together with new oil when I noticed. You cant just buy that spring can you?
mfoga is offline
Old 09-18-2009, 09:51 PM   #6 (permalink)
RustyIron's Avatar
Sure! You can go visit your friendly, neighborhood fork rebuilder, and he's probably got a bunch of them stashed away in a bucket under the workbench.
But... I've only worked on models of forks, mind you... Don't you have to take apart the fork to install the spring, and if that's the case, wouldn't it make good sense to just buy a rebuild kit?
RustyIron is online now
Chewyeti (09-19-2009)
Old 09-19-2009, 06:18 AM   #7 (permalink)
I have some, which size 30mm,32mm?I have others as well.
Old 09-19-2009, 07:16 AM   #8 (permalink)
Intense Whore
mfoga's Avatar
The fork doesnt need to be rebuilt though. I just went through replaced all the fluids and checked all the o-rings. Plus it doesnt have that many hours on it. I can pull the lowers replace the spring pretty quick.
Lyrik so 35mm
mfoga is offline
Gnutz (09-19-2009)
Old 09-19-2009, 01:22 PM   #9 (permalink)
I got that to.
Old 09-19-2009, 06:03 PM   #10 (permalink)
Lyrik so 35mm
Yeah that should be correct, the control oil should all be up top, all youll need is some lube oil and your good.
Old 09-19-2009, 06:42 PM   #11 (permalink)
Intense Whore
mfoga's Avatar
I got that to.
Think I could send you some money to stick one in an envelope and send one to me. Kinda far to go to Lake Elsinore for a little spring.
mfoga is offline
Marzocchi fork separation Wile E General Discussion 43 09-05-2009 05:40 PM
Fork question.. I need help Extinction The Workshop 6 07-12-2009 08:50 PM
Rigid Fork Question BFloFoxRider. The Workshop 13 06-27-2008 08:16 AM
Question about new fork choice. JimmyJ General Discussion 11 04-20-2008 07:14 PM
Fork Help! freewheeler The Workshop 5 01-11-2008 10:23 AM
