Old 12-05-2006, 07:43 AM   #1 (permalink)
Riders on the solar storm
PHAT TIRE's Avatar
Default Drivetrain Issue- HELP...Suggestions?
I recently replaced my chain and it wasn't meshing with the cogset so I put a new cogset on as I could see the teeth were wearing. That solved my chain meshing/ mis-shifting concern but in the higher gears I still have a sound like it's chain sucking or kinda grinding. The gears are all shifting fine and the noise is happening under load going up hill. Any suggestions on how to get it to go away? I gotta get this back on the trail before I go nuts on the road bike!!!!
PHAT TIRE is offline
Old 12-05-2006, 08:13 AM   #2 (permalink)
Check this link for fine-tuning your settings: Park Tool Website
It sounds like your either your B tension setting may be off or the cable tension could be fine tuned - the chain may be rubbing on the next higher or lower gear. A new, lubed chain and new cassette should be problem free. You did replace your cables at the same time didn't you?
Old 12-05-2006, 08:20 AM   #3 (permalink)
Bend over
soul rider's Avatar
8sp Chain On A 9 Spd Cassette?
soul rider is offline
Old 12-05-2006, 10:04 AM   #4 (permalink)
PHAT TIRE's Avatar
No the cables are relatively new. 9 speed shram with grip shift
Old 12-06-2006, 01:33 PM   #5 (permalink)
PHAT TIRE's Avatar
I think I got it dialed in today. Went to the shop and got advice from my bud. Thanks all, time to ride
Old 12-06-2006, 03:49 PM   #6 (permalink)
Technically Canadian
Neccros's Avatar
I had this issue on my bike..... turns out it was a weak main pivot spring in an almost brand new derailer....
Cant we all just ride along???
Neccros is offline
Old 01-02-2007, 09:47 PM   #7 (permalink)
1_fez_rider's Avatar
I had that on my bike once. But I then noticed the hanger was bent just a smidge. After bending it back, I had to keep tuning the derailleur until no more sound was occuring in all the gears.
1_fez_rider is offline
New Single Speed Frame Suggestions chumbaracing General Discussion 28 10-11-2007 10:17 AM
Suggestions for a new bike for me Ponch General Discussion 17 06-22-2006 07:15 AM
Helmet Suggestions Jordansrealm General Discussion 19 06-04-2006 09:06 PM
