+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 21
Thread: Tapered Head Tubes - Debate
  1. #1
    STR Veteran One_Track_Mind's Avatar
    Joined
    Jan 2009
    From
    Laguna Beach
    Thanks
    71
    Thanks earned: 1,188
    Default Tapered Head Tubes - Debate
    OK, What's the deal with tapered head tubes?
    This seems like a royal pain in the a$$ for minimal benefit. Please correct me if I'm wrong but the steer tube on the fork stays 1.125" while the bottom crown race/bearings change to 1.5" and the top headset bearings remain 1.125".
    So, same fork, same top headset, different bottom headset/race. Is this an evil conspiracy by headset manufacturers to sell twice as many headsets? If one wants to upgrade their headset, because most stock headsets suck, you'll need parts of both a 1.125" and parts of a 1.5"... leaving you with useless parts.
    This whole thing supposedly makes the front end stiffer while keeping weight to a minimum. Is the increased stiffness quantifiable? How much weight is saved by not making the whole system 1.5"? Wouldn't greater stiffness be achieved by making the steer tube of the fork a larger diameter as well?
    And finally, does the design even make sense? The lower headset/crown race is the pivot point for unwanted movement. The actual movement occurs on either end of that lever, either in the fork legs or at the stem/handlebars. In terms of physics, wouldn't it be most beneficial to have the upper be larger than the bottom, to resist the leverage produced by the bottom pivot point? And if that is indeed the case then all this really boils down to is looks, marketing and sales while making life more difficult for the consumer... Your thoughts please...
  2. #2
    STR Veteran davidB's Avatar
    Joined
    Jul 2007
    From
    Tustin
    Thanks
    4,058
    Thanks earned: 9,682
    Quote Originally Posted by One_Track_Mind View Post
    The steerer tube on some forks is tapered.
    And yes, it's a PITA. One or the other is fine with me, not a both option.
  3. #3
    Warrior's Society mtnbikej's Avatar
    Joined
    Dec 2004
    From
    Orange
    Thanks
    2,725
    Thanks earned: 5,697
    Acrually fork manufacturers are making steerer tubes that taper from 1 1/8" to 1.5.
    I crashed hard enough on my Tallboy to break my leg,
    The carbon is way more durable than most people.
    http://warriorssociety.org ........... http://overthehumpseries.com/ ........... http://www.switchbackcyclery.com
  4. #4
    Joined
    Oct 2007
    From
    Thanks
    11,347
    Thanks earned: 5,319
    About as much sense as a 15mm axle, stiffer than 1 1/8ths or a regular QR but not any stronger than a 1.5 or 20mm. Pros are being able to use any stem, cons are needing a new frame/fork and limited replacement choices. having more surface area makes sense for welded frames but see less of an advantage in carbon. Not a bad thing but not enough to open my wallet any time soon.
  5. post thanked by:
    BH1 (07-22-2009), Diamondback (07-22-2009), rather b riding (07-23-2009)
  6. #5
    member CalEpic's Avatar
    Joined
    Feb 2005
    From
    Laguna Niguel
    Thanks
    12,516
    Thanks earned: 14,585
    I'm not sure there is a ton of weight savings vs a 1.5 top and bottom but one of the arguments for a tapered system is greater choice of stems in 1 1/8. It sounds like several bike manuf are going this new route now so embrace the change I suppose.
  7. post thanked by:
    DISCO (07-22-2009)
  8. #6
    Joined
    Oct 2007
    From
    Temple City
    Thanks
    73
    Thanks earned: 307
    Don't forget that by using a taper system, interchangeability between stems is easy.
    Vu Le - Trek Mountain Co-Op
    I work at Helen's Cycles of Arcadia.
  9. #7
    BH1
    BH1 is offline
    STR Veteran BH1's Avatar
    Joined
    Jun 2008
    From
    Studio City
    Thanks
    794
    Thanks earned: 790
    I love how our industry sets "international standards" so bike companies and component manufacturers can make interchangeable frames and parts... yet those standards seem to change just as everyone is caught up with the last "international standard" update.
    On the other hand, change is good so I guess we can't complain about technological innovation. Reviews I have read have reported nothing but good for this new design.
  10. post thanked by:
    DISCO (07-22-2009), DownHillPhil (07-23-2009)
  11. #8
    Senior Member XS NOIZ's Avatar
    Joined
    Jun 2009
    From
    So. Cal.
    Thanks
    Thanks earned: 103
    Remember that product evolution is good for the sport, but it's always better for the manufacturer.
    Apparently I'm one of "those guys" because I drive a lifted truck, own a quad and like shooting guns...go figure.
  12. post thanked by:
    BH1 (07-22-2009), DISCO (07-22-2009), DownHillPhil (07-23-2009), SAR_boats (07-22-2009)
  13. #9
    booger flicker cid`'s Avatar
    Joined
    Dec 2008
    From
    Upland
    Thanks
    109
    Thanks earned: 202
    Makes a lot of sense.. but adaptability is questioned by cost and availability.
    The 1.5 bottom of the head tube allows for more material/welds/carbon thus more surface area for impact/abuse. But if it costs more and they require diff forks or what not, then that just makes it less attractive. Cost is always the driving factor for the masses..
    They have those little adapter rings to reduce the 1.5 to 1.125 now a days so makes it more compatible i guess.
  14. post thanked by:
    DISCO (07-22-2009)
  15. #10
    boutique brand elitist Iwannabinsocal's Avatar
    Joined
    Mar 2009
    From
    Seattle area
    Thanks
    1,628
    Thanks earned: 967
    The stem selection is the biggest win here. I just built a 6.6 and let me tell you, 1.5 stems, with any length to them (greater than 30mm) were hard to find. I found that FSA and Syncros both made 1.5 80mm stems and went with the Syncros, but those appeared to be my only choices.
    To me, the easier solution was stem manufacturers to start offering more 1.5 stem options, but the market decided it was better to make peoples existing parts less versatile so they could sell more stuff
    "when the oil stops leaking, start worring. The long and short of it-yep. She needs some servicing"
    -BobBurnes 4/3/2009
  16. #11
    STR Veteran Drakethomas's Avatar
    Joined
    Jun 2009
    From
    ISO HQ, Murrieta CA
    Thanks
    858
    Thanks earned: 1,243
    Being in the indudstry and designing and building lots of things from remote dampers to building rocket engines, you will come to realize a few things. Lighter is always a benefit, but to get lighter you have to get thinner, but to get thinner you need more surface area. If you increase the area 2x you increase stiffness and strength by a factor of 4.All benes if you ask me.
    Independent Suspension Operation
    41083 Sandalwood Circle
    Murietta CA 92562
    isotuned@yahoo.com SHOP# 619.760.6261
  17. post thanked by:
    cid` (07-22-2009)
  18. #12
    Booze Bikes n Boomsticks SAR_boats's Avatar
    Joined
    Oct 2006
    From
    Other
    Thanks
    5,955
    Thanks earned: 5,155
    The wonderful thing about standards is that there are so many of them.
    The contents of the above post may not be safe for children, expectant mothers, or the elderly. The above post should probably not be taken seriously but should be taken with a quart of whisky. Misuse of the above post may cause rash, infection, joint pain, bleeding gums, car trouble, bad weather, black mold and/or anal seepage.
  19. #13
    9.8m/secē - It's the law CeeDubb's Avatar
    Joined
    Apr 2007
    From
    MV in the OC
    Thanks
    1,281
    Thanks earned: 1,761
    Standardization is stagnation. Nowadays, major players in most industries do not follow a new "trend" unless there's a benefit.
    Remember when 29ers seemed silly?
    dubbTECH.com - CeeDubb.com
  20. #14
    Joined
    Dec 2008
    From
    Upland
    Thanks
    109
    Thanks earned: 202
    standards are good when it comes to certain items.. look at shimano for example.. f?ck it up for everyone buy doing odd end crap.. some stuff is good, but a lot never takes off due to pricing..
    eg; wth would i pay 2-3 times more for centerlock rotors versus regular 6 bolt
  21. #15
    DirtymikeTDB
    Guest
    Quote Originally Posted by cid` View Post
    Strength on the bike is what the big deal is. 1.5 headtubes, tapered or straight up 1.5 allow for a stronger frame. More surface area to weld up, more stiffness in the frame itself. As far as the fork goes, You really cannot tell the difference in 1.125 and 1.5. Now the reason for the taper, is quite simple. Noone was making a good selection of stems for the 1.5 steerers. Thats all, thats the only reason we have tapered HT's. Its a better way of reinforcing a Steerer on a SC fork. The 1.125.15 steerer is the same strength as what I have on my bike, 1.125 reinforcerd, but its lighter because of the taper iteslf.
    The cool part about it is, Headsets are readily available for whatever combo you want to run. waht to run a tapered steerer fork? Great, everyone is making the headsets for that, want to run a straight up 1.125 fork? Also great, those headsets are also ready to order. The manf.s already had all the parts needed to supply the demand for this. There is nothing hard or complicated about it.
    This is truly the one standard I have seen in bikes in a long time that actually amkes sense.
  22. post thanked by:
    2wheel_lee (07-23-2009), cid` (07-23-2009)
  23. #16
    Joined
    Sep 2008
    Thanks
    Thanks earned: 23
    It is just like any other standard developed in the bike industry, until it is fully accepted there will be limited availability and product choices. Also look how well accepted 1.5 steerer tubes have been. Although any 1.5 frame could be used to create a 1.5 to 1.125 stearer with the proper headset sorting out. I haven't ever ridden a tappered steerer fork, but I have als never said "ugh i wish my steerer was stiffer". I guess till everyone does it we will all gripe about it.
  24. #17
    Joined
    Dec 2008
    From
    Upland
    Thanks
    109
    Thanks earned: 202
    haha, after rereading it, i never once said it was stronger, good point out :P
  25. #18
    Circus Bear Chewyeti's Avatar
    Joined
    Jul 2007
    From
    Yorba Linda
    Thanks
    14,870
    Thanks earned: 15,960
    stem choice... thats it!
    LAME.
    make more 1.5 stems? Nah... that would be too easy! Lets make whole bikes that use different headset parts!
    I LOVE my 1.5 straight head tube on my lyrik. Good stuff... stem choice, I did ok. They are out there... way more than 'iwannabeinsocal' alludes to.
    one or the other.... girls or guys... no david bowies.
    Resident Lawn Dart
  26. post thanked by:
    DownHillPhil (07-23-2009), Iwannabinsocal (07-23-2009)
  27. #19
    Joined
    Mar 2009
    From
    Seattle area
    Thanks
    1,628
    Thanks earned: 967
    I only said I could only find ones with length from two manufacturers, there are plenty if you want on 30 or 50mm, but 80 was the longest I found and only from the two manufacturers in my OP.
    -BobBurnes 4/3/2009
  28. post thanked by:
    Chewyeti (07-24-2009)
  29. #20
    Joined
    Jul 2007
    From
    Yorba Linda
    Thanks
    14,870
    i run an FSA gravity 90, they are out there from sunline, cannondale, etc
    Resident Lawn Dart
  30.    Sponsored Links
+ Reply to Thread
  1. Tapered Head Tubes
    By Zippo in forum The Workshop
    Last Post: 06-10-2009, 04:35 PM
  2. Head on with horse...literally
    By Kritter in forum Trailhead
    Last Post: 12-01-2008, 10:32 PM
  3. Cheap Tubes - Schrader Valve
    By rjcornelia in forum The Market Place
    Last Post: 07-31-2008, 01:15 PM
  4. Replies: 8
    Last Post: 04-15-2008, 09:35 PM
  5. Bulk Tubes?
    By Neccros in forum The Market Place
    Last Post: 04-09-2006, 05:59 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
