Old 11-11-2006, 09:43 AM   #1 (permalink)
JfromLV Fan Club Prez.
FyrFytrRyn's Avatar
Unhappy strike three... 888r problem.
well it seems to be one thing after another with this ****ing bike. 3rd run @ southridge this morning @ the rock drop, my rebound went out the window, fork shot to full droop faster than you can say "holy s***", hard too, pogo stick status. stopped and ran the reb. adjuster full + with no change. *sighs and takes anger out on a rock innocently laying neer* so i load up and went home (i did see rob {bikebike69} for a moment though). i took the fork apart to find the rebound side cart to be in pieces, snap ring gone, o rings gone, general destruction on the right side of the fork. the compression side looks okay and felt the same it did a few weeks ago when i changed fluid, as in, when its full+ its stiff, full- its light, but should i replace both carts?( i think they are 150.00 a piece though!!) i know ill rebuild all new seals and such while im at it, should i get orig. marz seals or get those sweet blue enduro ones? which do you suggest?
better than stock?
http://enduroforkseals.com/id53.html
so my questions for you are:
1. stock seals or enduro ones?
2. if you were me, would you do compression eventhough it feels good?
3. any other tips that would be considered when doing this, anything else i should do while i have the bastard apart?
im up the creek until monday i guess when i can get in touch with marzocchi. this is total BS
FyrFytrRyn is offline
Old 11-11-2006, 09:55 AM   #2 (permalink)
Car Magnet
I run push'ed foxes so I haven't actually used a shock with the blue enduros but I have heard nothing but good things about them. As for rebuiling the compression side, If you can afford it then do so, however generally the comp cartrige tends to last longer than the rebound side so if replacing it will put you in dire straits then don't.
Old 11-11-2006, 10:00 AM   #3 (permalink)
FyrFytrRyn's Avatar
well i dont have 300.00 to spend, since the comp side still feels good, i think i can get away with that for now, worst case is i have to tear it back apart to do the compression side and all that will cost me aside fromt he cart is fluid and time.
well, after tearing the reb. cart apart, it appears that since the clip snapped and released the cart shaft main bushing (which stabilizes the rod) it made the fork have total bleed through the top (didnt allow fluid to be dampened through the orig. holes, but through the top which is 15-20 times larger than the holes @ the bottom the fluid is supposed to flow through) this made the fork have NO rebound because the oriface that the fluid was SUPPOSED to be flowing through was no longer being utilized, instead a huge gap was used as a bypass. so i replaced the o-ring on the main bushing deal and popped it back in the cart, minus the snap ring, emersed it in oil and gave it a push then tug, felt normal.. ran the adjusted all the way in (full reb) gave it a push then tug, felt normal. this leads me to believe that if i simple re-install the snap ring, put the fork together and fill'er up, all should be good. im going to leave it disassembled until i talk to marz, but i think if the cart itself were broken, it wouldnt have the ability to reb. at all.
Old 11-11-2006, 12:48 PM   #4 (permalink)
STR Lurker
dhshuttlemonkey's Avatar
Hope you can get it fixed in time for next weekend.
dhshuttlemonkey is offline
Old 11-11-2006, 07:14 PM   #5 (permalink)
FyrFytrRyn's Avatar
your tellin me frank. i hope i can get all the parts by then. if not im racing reboundless, pogo mcgee. im super pissed i didnt get many runs in today, hopefully i can get it rebuilt midweek and go friday and maybe thursday to get it dialed in. so no comments on the enduros above stock huh?
i went to ACE, pepboys, autozone, lowes,home depot, kragen and star auto and never found the right size internal snap ring for the carts, appears to be 9/16 but has a slightly funny shape as compared to the normal snap rings. im going to call incycle tomarrow and see if they stock these small parts, fingers crossed.
Old 11-11-2006, 08:28 PM   #6 (permalink)
STR Lurker
If Incycle doesn't have it, try The Path on Monday. Best bet is driving to Valencia and having the techs at Marzs service it for you. They can have it done in a few hours if you take it there yourself.
Old 11-11-2006, 09:45 PM   #7 (permalink)
FyrFytrRyn's Avatar
where be the path? if its farther than valencia ill just drive to marz. i like doin the work, i just need the parts!
Old 11-12-2006, 09:14 AM   #8 (permalink)
STR Lurker
It's in Tustin. http://www.thepathbikeshop.com
Old 11-12-2006, 06:19 PM   #9 (permalink)
FyrFytrRyn's Avatar
couldnt get a hold of incycle today... oh well, ill call tomarrow before i call marz.. any how i suppose i go with enduro seals. not i dont have a complaint with stockers, but ive heard some stories from people about stocks and ive only heard good things about enduro, and they are blue! haha. hopefully ill get the sucker back together by thursday.
Old 11-13-2006, 06:25 AM   #10 (permalink)
The good things we hear about Enduro seals are usually on Fox replacements. On their high end forks, Zoke has some of the best seals in the bussiness.
Old 11-13-2006, 10:30 AM   #11 (permalink)
FyrFytrRyn's Avatar
so since marz arent better than fox, are the enduros gonna suck on it or what? i already ordered them anyhow, ill give um a shot. i guess.
Old 11-13-2006, 11:50 AM   #12 (permalink)
Marz are good seals, Endros are good seals, is one better than the other? I have no idea. I do think that endro seals are better than Fox seals.
Old 11-13-2006, 09:44 PM   #13 (permalink)
FyrFytrRyn's Avatar
good news.. called marz this morning and talked to a guy named Giddian (sp), asked him if they had those lil clips that hold the bushing to the cart, and asked if they stocked the preload c clips and o-rings, he said they should. well i was off today and decided to just shoot up there (100 miles away, made it in 1 hr 7 minutes!) to my suprise the lovely lady @ the front desk asked what my name was, i replied and she handed me a little baggie with all the parts in it (not only the snap ring that i needed but an extra, orings and c-clips!), free of charge. marz is getting a x-mas card this year! not just waiting on the seals from enduro.
Old 11-13-2006, 09:59 PM   #14 (permalink)
STR Lurker
Glad to hear Marz took care of you. Giddeon did the work on my "works" package for my 888 and 66SL. They also hooked me up with swapping out the white lowers back to black lowers on the 66.
Old 11-14-2006, 11:45 AM   #15 (permalink)
uno, dos, tres bubbs
Skeeter's Avatar
thats awesome love to hear about good service,
Evil Chocula: I speak from experience both giving and recieving.
Skeeter is offline
Old 11-14-2006, 09:35 PM   #16 (permalink)
Full Travel
ka0t1c07's Avatar
Marz is dope. Now I have to call them to see what can they do about my ROCO rebound adjustment knob. Its stiff as hell since it was new. It dont feel right. It was the first release models, so I think it wasnt perfected.
ka0t1c07 is offline
Old 11-16-2006, 03:23 PM   #17 (permalink)
FyrFytrRyn's Avatar
well its all back together. one problem, how tight are the carts supposed to be in the legs? they are about as tight as they were comin out, but they just dont feel tight enough, every time i put a turn on it they just slip inside the legs. thanks!
Old 11-17-2006, 08:41 AM   #18 (permalink)
According to the 06 manual turque for "pumping rod/cartridge bottom nut/screw" is 10Nm +/- 1. For Monster T's (the only fork listed separtely) it's 25Nm +/-1. If yours is other than an 06, pull up the tech manual on Zoke's site for that year and the torque values are towards the back. The preload from the top cap pushing down on the spring/cartridge does a lot of the work in holding things together. Unless you have some violent top out (which you shouldn't) they don't bear that much of a load. The 10mn is enough to let the o-ring seal, but not so much as to crush it.
Good luck and have fun at the races.
Chris
Flat Broke is offline
Fox Vanilla problem.... clay41882 The Workshop 1 07-11-2006 08:07 PM
Marta brake problem Tortuga The Workshop 3 12-31-2005 10:26 AM
