Old 11-06-2006, 08:39 AM   #1 (permalink)
JfromLV Fan Club Prez.
FyrFytrRyn's Avatar
Default shes super creaky YEAH!...
any of you guys have a problem with your forks creaking? (triple clamp type) well it sounds like the forks atleast. i took the fork out of the clamps, cleaned, and lightly greased it all, re-assembled and it still does it. could it be a headset problem? yes the head set is tight. chris king sealed. any suggestions are welcome. whole bike is aluminum, and some people say aluminum bikes just creak. thanks!
FyrFytrRyn is offline
Old 11-06-2006, 08:59 AM   #2 (permalink)
Aluminum frames creak when they devolpe cracks. Creaks can be a problem to track down as they travel and don't aways seam to be coming from where it sounds.
You are on the right track, keep taking stuff apart clean and grease. On my Niner eccentric bottom backet grease would not keep it quite for more than a ride or two. So far good luck with teflon tape.
Old 11-06-2006, 09:05 AM   #3 (permalink)
I had creaking that in that same area. Greased everything, took apart headset/cleaned/greased. Creaking went away. Try loosening your stem and headbolt, readjusting, then tighten.
jruiz is offline
Old 11-06-2006, 10:49 AM   #4 (permalink)
Bend over
soul rider's Avatar
get new hardware too. i replace mine yearly
soul rider is offline
Old 11-06-2006, 05:19 PM   #5 (permalink)
FyrFytrRyn's Avatar
thanks for the help guys, its much appreciated. so it creakes before it cracks huh? well thats not good,
Old 11-06-2006, 08:59 PM   #6 (permalink)
I had creaking in the crown area on one of my bikes. Turned out to be the crown on the fork. Fox fixed it under warranty. To check it, turn the bike upside down resting on the seat and bars. Stand on the bars and rock the fork lowers back and forth to isolate the creaking. If the fork is off the bike, put the steerer in a padded vise and do the same.
Old 11-06-2006, 09:54 PM   #7 (permalink)
FyrFytrRyn's Avatar
so i pulled the whole front end back apart, greased all the bolts and contact points, and pulled the HS out, cleaned it with a scotchbrite pad and simple green, cleaned the frame the same way, regreased it all and pieced it back together. not a noise to be heard.. lets see how long this lasts... thanks for the replies!
Old 11-07-2006, 04:50 AM   #8 (permalink)
Bend over
soul rider's Avatar
one more thing do not over tighten your bolts!!!!
Old 11-07-2006, 10:20 AM   #9 (permalink)
FyrFytrRyn's Avatar
never do soulrider.. i went ahead and took apart the BB again to teflon tape and grease it just in case. try to get a ride in tomarrow, thanks for the replies!
Old 11-07-2006, 01:16 PM   #10 (permalink)
drive monkey, drive!
dirttorpeedo's Avatar
it cood also be your cable housing in the stops,seatpost and clamp.
dirttorpeedo is offline
Old 11-07-2006, 06:12 PM   #11 (permalink)
FyrFytrRyn's Avatar
i found that alot of it was the seat post on the clamp. thanks for the idea chris.
