After years of living with creaky XT cranks on the 5-Spot, I have replaced them.
The White Brothers Eno square taper cranks and a Phil Wood stainless steel bottom on my Niner sold be on the old square taper design cranks. I had been bidding and loosing E-Bay bids on old square taper cranks until I found a importer for Middleburn. Also these Middleburn Cranks have a removable spider, so you can run 4 bolt, 5 bolt or singlespeed chainrings. I have set they up as the compact gearing 20x30x42. Yes I am cheating with a smaller grany gearand and a 180mm crank. Yes I have given up some clearance, but I got used to longer cranks when I started singlspeeding. The botttom bracket on my Niner is way lower than the 5-Spot. First impersions are that the unramped Middleburn chainrings do not shift anywhere near as clean as Shimano. If it is someting I can't live with, I can replace them with ramped Race Face Chainrings. Finding old 5 bolt pattern chainrings is not a problem and usually cheaper than there 4 bolt counterparts. The Middleburn and Phil Wood make for a silent combo....worth the loose of shifting ease.
STR BUB!!
thats some sweet bling bling eh!!
http://static.flickr.com/11/91529165_041edc585f_m.jpg Perhaps you think you're being treated unfairly? ![]() The path of the righteous man is beset on all sides by the inequities of the selfish and the tyranny of evil men."
Yes I know, but you can not put a 20 tooth gear on a 4 bolt spider. You have to use the gearing that the bike manufactures think you should be using...no choices. Middleburns open up unlimited gearing options.
Did you ever ask yourself why Campagolo still uses square taper?
Dude stop going to South Laguna Beachs. You know that one just South of Aliso (*** Bay).
STR Lurker
I give up Frank, you are right! From now on I will just buy what everbody else buys.
| Time to upgrade them cranks! ADVICE! | ECOdork | The Workshop | 11 | 08-19-2006 09:43 AM |
| Race Face NEXT cranks... | FoShizzle | General Discussion | 5 | 07-29-2006 06:26 PM |
| Outboard cranks??? | Leo14 | The Workshop | 20 | 05-23-2006 10:08 PM |
| Shimano Saint Cranks | dhshuttlemonkey | The Workshop | 6 | 04-24-2006 12:01 PM |
| Intense Uzzi SL frame,Chris King Headset, Race Face Cranks | HeyMoe | The Market Place | 0 | 06-22-2005 07:35 PM |
