Old 09-07-2006, 08:59 AM   #1 (permalink)
witt's Avatar
Default long throw/short throw rear derailleur?
so on my downhill/freeride..... right now ive got a 38T in the front & an 11/32T casette in the back with a long throw LX derailleur...
http://www.nashbar.com/profile.cfm?c...%20Derailleurs
and i get chain slap like no other.... its annoying as hell. Can i put a short/mid throw/cage derailleur on instead to help alleviate this?
was thinking
http://cgi.ebay.com/ws/eBayISAPI.dll...t&isfrommerc=1
or
Shimano XTR
RD-M960
RD-M952
Oo and the chain is as short as it can get.... i get pedal feedback & the chain actually needs to be longer cuz it gets pushed out when the rear swingarm cycles out....
so ya.... opinions..... suggestions??
thanks
Eric
witt is offline
Old 09-07-2006, 09:48 AM   #2 (permalink)
TURNERob's Avatar
Yes absolutely you can run a short cage rear der. since you only have 1 ring in front. SRAM rear derailuers have stiffer springs and control chain slap much better than Shimano derailuers do however. If you don't want to go with a SRAM derailuer then I'd look into a chainguide/tensioner system if you don't already have one.
TURNERob is offline
Old 09-07-2006, 09:50 AM   #3 (permalink)
Throw some Dee's on it
roadkillross's Avatar
no clue
roadkillross is offline
Old 09-07-2006, 09:55 AM   #4 (permalink)
TURNERob's Avatar
Originally Posted by downhillross13 View Post
no clue
Then why post anything
TURNERob is offline
Old 09-07-2006, 11:05 AM   #5 (permalink)
witt's Avatar
neat.....
um ive got an XT shifter... it wont work with SRAM stuff huh? somthing about 2:1 vs 1:1....
can some1 clue me in a lil on what will work with what?
ive got a E 13 chainguide/bash-thing commin in the mail... and yes i rode without one @ mammoth.... and yes... the damn chain came off..... alot.. it was quite annoying...
but i learned to just keep pedaling, never backpedal... that kept the chain on ok....
what setup do you reccomend? if you were to do it urself?
no clue
well said... haha...
witt is offline
Old 09-07-2006, 11:10 AM   #6 (permalink)
TURNERob's Avatar
The E-13 should take care of all your issues then, no need to really switch your derailuer.....but you still could run a short cage if you wanted to absolutely......it would give you a little better rock clearance and slightly crisper shifting.
Oh and yes you would have to change your shifter to run a SRAM derailuer.
TURNERob is offline
Old 09-07-2006, 12:57 PM   #7 (permalink)
Evel Knievel's Avatar
Lots of guys run a road cog and shimano 105 road der for DH. Short cage , quick clean shifts and cheap .
Evel Knievel is offline
Old 09-07-2006, 06:00 PM   #8 (permalink)
witt's Avatar
koo.. thanks for the tips & advice....
since i do go uphill (i try not to but it happens) as well as downhill with this bike i'll stay away from the road stuff for now.....
i'll put the chain guide on and see how i like it... if i dont.. then a SRAM setup might be in order...
Thanks guys
witt is offline
Old 09-08-2006, 10:22 AM   #9 (permalink)
drive monkey, drive!
dirttorpeedo's Avatar
u run a long cage for long travel bikes cause some ders. cant handle the long throw.you can tear them off when your bike goes throo the travel.the chain guide shood do it tho,maybe take out 2-4 links from the chain and ride it before you spend the doe on the derailuer.
dirttorpeedo is offline
Old 09-08-2006, 06:49 PM   #10 (permalink)
witt's Avatar
ya i already have the absolute min # of chain links on my setup.. in fact i might need to add 1-2 cuz of the chainguide.. it'l take up some slack (nonexistant slack) in the chain now.....
witt is offline
shi+mano front derailleur help mrpoonerson The Workshop 3 09-25-2005 11:41 AM
Wanted Wanted Rear Derailleur imapodaddy The Market Place 3 02-04-2005 03:28 PM
