Originally Posted by PHAT TIRE
I got my set-up completed last night. I am experiencing a few concerns though and you all hopefully can tell me what to do. No, I am not setting around "pulling my toob" in the garage. I am getting frustrated though  . I have followed all the instructions and while it's on the bike stand the brakes spin fine with no rub. I get my ass on the bike and then the front brake rubs slightly eventhough I am not touching the brake lever and it rubs more so on turns. I have tried the re-alignment twice with little improvement.
Also, the brake levers feel squeshy. I did RTFB thoroughly. The instructions  say that eventually some braking noise will go away and the brakes may tighten up. Do I need to bleed them or wait?
 Please help!!!
If they are rubbing on turns then usually that means the hub is either loose or needs a rebuild. Since they are new I'll go with loose. Also using a torque wrench on the mounting bolts of the discs helps
