Old 10-24-2008, 04:40 PM   #1 (permalink)
Exiled Brit
Lefty Kev's Avatar
Default Wetsuit Glue
So...this afternoon (while I should have been working), I was perusing (not buying) the mountain bike magazines in Barnes & Noble, sipping a smoothie (purchased elsewhere). I happened upon an interesting article in British mountain bike mag mtbr. The article claimed that a nick or slice in a tire could be reliably fixed using a glue intended for repairing rips or tears in wetsuits.
Several of these "liquid rubber" adhesives were discussed including Black Witch, a "fast drying, strong and flexible resin" that can be used on wetsuits, booties, gloves, and hoods. Other similar products include Quick Fix and Aquasure, etc. which might be familiar to those of you that surf.
The article stresses that use of the glue in this application is merely designed to prolong the life of the tire and couldn't fix a major puncture. It just helps prevent a surface tear from becoming worse and causing the tire to fail on a future ride. Presumably, it could be equally successful on either a tubed or tubeless tire.
You deflate the tire, carefully prise open the tear, apply the resin and reinflate. Depending on the brand, it will turn black or clear when it dries.
I know some of you have used superglue or rubber cement in a similar application (I recently filled a slice with Liquid Nails which has held pretty well). I don't know if these wetsuit glues work any better but the article made interesting reading and I thought I'd pass it along to the rest of the STR crew
Safe and happy trails to all this weekend
"Britain and America...two great nations divided by the same language." -- Winston Churchill
Lefty Kev is offline
Old 10-24-2008, 07:37 PM   #2 (permalink)
Neo-Rez was one of my favorite wetsuit repair glues, and it works as you describe. It's available at many surf shops. It does have a limited shelf life, though.
http://www.solarez.com/products/
Other Solarez products on this page a great and easy to use.
- Speed has never killed anyone, suddenly becoming stationary... that's what gets you.
- May the air be filled with tires!
- Know your size.
Lefty Kev (10-24-2008)
Hurley Recon 2/2 Spring wetsuit *MS* tehelmo Non-Bike Related 0 05-25-2008 06:01 PM
Super Glue 6packguywith5spot The Workshop 7 03-24-2008 01:40 PM
Or Sale: 9ft Surfboard, w/carrying bag, roof straps and wetsuit. Evil Chocula The Market Place 9 11-05-2007 04:29 PM
