Old 10-09-2008, 04:30 PM   #1 (permalink)
Pato's Avatar
Default Hopelessy flat tube seeking long term relationship with reliable commuter tire.
I need some help from you commuters out there please. My friend is getting flats due to glass/thorns on a daily basis. He is currently running a 28x1 3/8 commuter tire and is looking to replace the tire with something more thorn/glass resistant.
I am not that familiar with commuter tires so I'm reaching out to the community for some assistance.
I have checked the current tire and there are no thorns or glass stuck in there causing the repeated flats. The rim strip is intact and stays in place. No sharp edges on the inside of the rim either. We have tried putting in a protective tire liner, but no luck. I have checked and verified that the the holes in the tubes are indeed on the outside edge indicating a foreign object piercing through the tire and tube.
Our next step is to buy tubes and fill them with either Slime or Stan's. My main issue here is that I'm really looking to get recommendations for a reliable, long lasting tire that will offer flat protection. Lightweight be damned.
Need help ASAP.
Sincerely,
Forever Flat
Pato is offline
DownHillPhil (10-09-2008)
Old 10-09-2008, 04:35 PM   #2 (permalink)
freekengo's Avatar
I don't know about the availability in a 28" size, but anything armadillo edition from specialized has been bullet proof for the commute. Heavy as sin, but takes a lick'n and keeps on tick'n. I use their Nimbus armadillo for the street stuff. Good luck!
freekengo is offline
duke777 (10-09-2008), Pato (10-09-2008)
Old 10-09-2008, 04:37 PM   #3 (permalink)
Oh Deer!
duke777's Avatar
I second the armadillo too.
What size is he running? I have a pair of new armadillo size 23 for 25 bucks.
$2,237.66 in damage.......Bambi must die!
duke777 is online now
Pato (10-09-2008)
Old 10-09-2008, 04:39 PM   #4 (permalink)
Pato's Avatar
Originally Posted by freekengo View Post
I don't know about the availability in a 28" size...
I believe 28" tires are compatible with 700cc tires. I'm not absolutely positive, but I'm sure someone will correct me if I'm wrong.
Also forgot to add that I'd like the tires to be at least 35mm wide.
Pato is offline
DirtymikeTDB (10-10-2008)
Old 10-09-2008, 04:47 PM   #5 (permalink)
freekengo's Avatar
Pato, the width shouldn't be an issue with the armadillo tires. They make them in quite a different variety. I think they made those tires specifically for the commuters. Good luck!
Pato (10-09-2008)
Old 10-09-2008, 05:32 PM   #6 (permalink)
autoduel's Avatar
Mr Tuffy's Tire Liners.
Heavy, but bulletproof.
Steve
Just along for the ride
autoduel is offline
Pato (10-09-2008), Pho'dUp (10-10-2008)
Old 10-09-2008, 05:36 PM   #7 (permalink)
Pato's Avatar
Thanks, I'll look into them. Any others?
Thanks, but he's already using those exact liners yet he's getting multiple flats daily.
Pato is offline
Old 10-09-2008, 05:45 PM   #8 (permalink)
Is he riding through any goatheads?
Pato (10-10-2008)
Old 10-09-2008, 05:49 PM   #9 (permalink)
Crank it out
Alex's Avatar
Could it possibly be a 27" tire? I know 27" and 700c tires have a 8mm total difference between them, but I've read the two are not interchangeable (I haven't tried it myself though). Hmm...
vwolf - mtb'ers are the golden rule.
Alex is offline
Pato (10-10-2008)
Old 10-09-2008, 05:56 PM   #10 (permalink)
Pato's Avatar
Not sure what goatheads are, but I've pulled out a couple of thorns and a staple. Lots of glass cuts on the tire as well.
Well, according to the Fuji website the rim/tire is listed as a 700cc, but the tire that came o there from the shop is clearly marked as a 28x1 3/8. I know that 700cc=27.56" so I'm not sure what to use. I'm leaning towards the 700cc tire since I can't find any 28" tires.
Pato is offline
Alex (10-09-2008)
Old 10-10-2008, 04:52 AM   #11 (permalink)
Derailleurs R4 Failuers
hoovermd's Avatar
I am partial to the Schwalbe Marathon Plus line myself.
If they are available in the size you need I'd highly recommend them.
Extra thick on the road side of the casing and reflective sidewalls as a bonus.
They roll nice too!
Mark
hoovermd is offline
Pato (10-10-2008)
Old 10-10-2008, 07:43 AM   #12 (permalink)
=w=
jeff^d's Avatar
I commute with Continental Ultra Gatorskins and have had 2 flats in about 2000 miles, which I consider pretty good for this area. 1st flat was glass, 2nd was a thorn (not a goathead). After my 2nd flat, 500 miles ago, I put in Mr. Tuffy strips and am hoping to go flat-free for the next 2000.
They're available in standard 700c sizes.
jeff^d is online now
Pato (10-10-2008)
Old 10-10-2008, 08:34 AM   #13 (permalink)
Intensive!
un-kola's Avatar
Goatheads are small knobs(1/4 inch or so),of very hard,dry wood-like material with one or two large thorns sticking out at an angle.When you look at them from the side,they look like a goats head.Hence the name.I don't know what kind of weed they're from,but they're at the worst this time of the year.The bane of mtbr's. They're the reason that I went tubeless.Haven't had a problem with goatheads since.- Lloyd
un-kola is offline
Pato (10-10-2008)
Old 10-10-2008, 09:02 AM   #14 (permalink)
Pato's Avatar
Thanks for all the help guys and gals. My friend went with the Schwalbe Marathon Plus since that's the only one he can get online and was $10 cheaper than the Specialized Armadillos and the Continentals only come in a 700x28. Hope this works out for him.
Pato is offline
Old 10-10-2008, 12:13 PM   #15 (permalink)
Dirtbag
DirtymikeTDB's Avatar
28x1/38 IS 700c. They are Identical size. So, your options are anything in a roadie tire, or anything in a 29er tire. Personally, Forget the liners, forget the thick tires, forget the TR tubes.
Go for the slime, in seven years I have not had a flat, simple, easy, very effective
Originally Posted by Sharky View Post
Well DirtyMike is always UBER sexy .
http://bighugelabs.com/flickr/motivator.php
DirtymikeTDB is offline
Pato (10-10-2008)
Old 10-10-2008, 11:28 PM   #16 (permalink)
hoovermd's Avatar
I don't think he will be unhappy.
Mark
hoovermd is offline
Old 10-11-2008, 12:16 AM   #17 (permalink)
newpos's Avatar
stans???
newpos is offline
Old 10-11-2008, 01:46 AM   #18 (permalink)
skflow's Avatar
Add a bit of Slime or Stans to the tube also for good measure. With prestas, need to do the extra monkey motion to get the goo in, but worth the hassle.
Ride Your Way.
skflow is offline
Pato (10-11-2008)
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
