Old 07-30-2008, 02:55 PM   #1 (permalink)
SLO Rider
Bryguy17's Avatar
Default setting a tire bead
Hey guys, I've been playing around with my tires lately, and I seem to be having trouble getting my tires to completely bead onto the rim.
Example: I have a 2.5 stick-e blue groove 2-ply that I'm trying to put on a supergo launch wheel (32H cousin of the outlaw). I've got a bonty 2.35-2.5 tube in there that I'm trying to get it to work with. Basically, I can get most of the tire to bead, but there's one section on the left side of the rim where the tire bead will not move into the rim bead.
Check out the picture attached. blue is the rimstrip, red is the rim, black is the tire. It's about a 16" section along the rim that is dipped down like this, and I can't figure out how to get the bead to set where it's supposed to.
The same bead problem was also present when I remounted my 2.1 nevegal UST onto my rim. It would not mount in the correct place on the bead. I don't know how I can go a year using pretty much the same tires and just now start having a problem with this
Anyone got any good tips/tricks/voodoo magic they can lend me? my tire is wobbling and it's kinda distracting
Also, on a slightly related topic, I tried mounting the same tire in a ghetto tubeless configuration with stans, and I couldn't get the bead to come close to setting (the beads just stayed in the middle of the rim). I used a pancake compressor if that makes a difference. Any tips in that regard? I would rather run tubeless if I can on that bike.
Thanks in advance,
Bryan
Bryguy17 is offline
Old 07-30-2008, 02:58 PM   #2 (permalink)
Bike Whisperer
DISCO's Avatar
You can soap it (the bead) or go up to 40-50 PSI then deflate (10-20PSI) and massage it into place. Of course if you roll with a compressor you can just blow till she pops on.
Good luck.
DISCO is online now
Bryguy17 (07-30-2008)
Old 07-30-2008, 03:02 PM   #3 (permalink)
SLO Rider
Bryguy17's Avatar
I might try soaping it. Havn't tried that yet.
So far the tire has been to 50 without setting it, and the compressor doesn't help very much for setting it either (at least with the tube in there)
Bryguy17 is offline
Old 07-30-2008, 03:03 PM   #4 (permalink)
genusmtbkr5's Avatar
Yup, use soap like Disco said or baby powder and pump up the tire to about 50 psi, it will set.
Gene"GuidesNewWarriors"
http://www.sharemtb.com/
genusmtbkr5 is offline
Old 07-30-2008, 03:31 PM   #5 (permalink)
^needs to ride more
davidB's Avatar
soap + compressor to set it without a tube
then put that tube in, talcum/baby powder and soap if you want, and it should "pop" back in around 50 psi
The Counting Coup is a social ride, right?
davidB is offline
Old 07-30-2008, 04:12 PM   #6 (permalink)
SLO Rider
Bryguy17's Avatar
thanks guys. I'll try some soap or powder tonight and see how things go
Bryguy17 is offline
Old 07-30-2008, 04:27 PM   #7 (permalink)
Good Times 'round da Bend
also... try bouncing the tire a few inches off the cement and it can get the beads to sit.
so 50 psi + Bouncing it off the ground = happy tire and happy rider
Nice cross section btw
-Aaron or Chewy
08 VOODOO Canzo 29er
08 Santa Cruz NOMAD
Chewyeti is offline
Old 07-30-2008, 04:32 PM   #8 (permalink)
SLO Rider
Bryguy17's Avatar
amusingly, 45psi + a day at the BMX track with a quite a few cases didn't do the trick
Bryguy17 is offline
Old 07-30-2008, 04:36 PM   #9 (permalink)
Tubeless right?
more pressure LOL
-Aaron or Chewy
08 Santa Cruz NOMAD
Chewyeti is offline
Old 07-30-2008, 08:47 PM   #10 (permalink)
SLO Rider
Bryguy17's Avatar
Tubeless right?
more pressure LOL
That's with it set up tubed. I'm sure the tire will handle a good bit of pressure, but god knows if it went, I wouldn't wanna be nearby.
Bryguy17 is offline
Old 07-30-2008, 09:33 PM   #11 (permalink)
Good Grasshopper
JOx2's Avatar
Default more of the same advice
spray it with soapy water then pump air.
JOx2 is offline
Old 07-30-2008, 09:41 PM   #12 (permalink)
Intensive!
un-kola's Avatar
You might also try pumping it up slowly(10lbs.at a time),then grab the tire with your hands and rock it sidewall to sidewall around the whole tire then add another 10lbs.and do the same.- Lloyd
un-kola is offline
Old 07-30-2008, 10:14 PM   #13 (permalink)
SLO Rider
Bryguy17's Avatar
I actually tried this already. It seems to work better with my kevlar bead tires than the wire bead ones, but
I'll get my suds on tomorrow when i have time/daylight to work with
Bryguy17 is offline
un-kola (07-30-2008)
Old 07-30-2008, 10:32 PM   #14 (permalink)
did you ride a wire bead tire flat for a few seconds you could have screwed up the inside of the bead
Race Photo's robbinspictures.com
Thanks to, Utopia Optics, Azonic USA, Livewire Energy
Old 07-31-2008, 04:52 PM   #15 (permalink)
SLO Rider
Bryguy17's Avatar
nope, run with pressure the whole time. Checked the bead and it looked fine as well. TOday's been hellishly long, so I'm gonna have to wait until tomorrow...
Bryguy17 is offline
Old 08-02-2008, 06:51 PM   #16 (permalink)
dutch's Avatar
soap/bike wash work great. The tire will hold a bunch of pressure (i've had to pump tires to 80+ psi before to seat them), so just keep going (within reason) until it pops into place. The only way you'll blow your tire is if the tube is pinched or if the tire is off the rim. good luck!
dutch is offline
Bryguy17 (08-03-2008)
Old 08-03-2008, 08:18 PM   #17 (permalink)
SLO Rider
Bryguy17's Avatar
I did the soap/water and it worked marvelously for the tubed setup. When I get time I'll go to town converting all my bikes to tubeless, and the fun will continue.
BTW, while the tires will hold a significantly higher pressure than they are rated for, those rating are there for a reason. occasionally, the casing does fail catastrophically and it's not a pretty sight (I've seen it). best to err on the side of safety when dealing with high pressure anything.
Bryguy17 is offline
Nevegal Tire Knobs coming off Sprockethead The Workshop 24 05-02-2008 05:12 PM
which tire with most traction hobie General Discussion 28 04-21-2008 07:38 AM
Panaracer Rampage 29er Tire for faster rolling tire Uncle Rico The Market Place 22 03-29-2008 08:21 AM
Tire problem Dino Brown The Workshop 22 12-26-2007 09:34 PM
setting the bead on tubless tires sailcalifornia The Workshop 30 12-14-2007 08:25 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111
