Old 07-22-2008, 04:58 PM   #1 (permalink)
Tri Fanatic
RidetheRAAM4's Avatar
Default Repair Help Please! (road bike)
So I was commuting to work today on my bike and noticed something odd with my cranks.
I don't really know how to describe it, but I will try my best.
When I pedal I sort of feel a click in my pedal stroke, but only when I push hard and always in about the same spot. Could I have cracked a bearing or something? Could there just be some dirt in there? Could my BB be loose? It does not make noise, I can just feel like a bump in the pedal stroke. Anyone experienced this before?
"my gain is your loss" -Some guy on craigslist
Race Progression
RidetheRAAM4 is offline
Old 07-22-2008, 05:01 PM   #2 (permalink)
Loop'n on my Heckler
OTHRIDER's Avatar
Your BB sounds/feels/clicks like my knees......
A man's footprints in life are only as deep as the ones that follow in his steps.
OTHRIDER is offline
Old 07-22-2008, 05:02 PM   #3 (permalink)
Pedal Damn It
davidB's Avatar
you probably have your non drive side crank arm loose
davidB is offline
Old 07-22-2008, 05:04 PM   #4 (permalink)
Will work for Trails
DISCO's Avatar
Pedals first, then Crank arms, then BB if nothing is loose or sloppy check the teeth on your front rings. It's a ball bearing in one of the first three most likely.
DISCO is online now
Old 07-22-2008, 06:04 PM   #5 (permalink)
I second that take off you pedals and lube the threads
Free riding,, because everything else sucks
Old 07-22-2008, 06:22 PM   #6 (permalink)
BFloFoxRider.'s Avatar
i say use it as an excuse to buy BB, Cranks and pedals.. Or just a whole new bike?
Brandon FLOres
This is How we do it!
BFloFoxRider. is offline
Old 07-22-2008, 06:35 PM   #7 (permalink)
TeamDEKEbmx's Avatar
I had the similar thing... There seemed to be a clunk on the down - stroke rt side - when under slight load only. I disassembled BB, prepared to replace it, and it was just loose. Good luck
TeamDEKEbmx is offline
Old 07-23-2008, 03:55 PM   #8 (permalink)
Tri Fanatic
Ok, I took my BB out and I don't think the problem was that it was just loose. There are some metal shavings down in there kinda like my BB turned into a lathe for a while. Strange. And the BB was dirty (it had some dirt on it). I can upload some pictures (blurry of the metal shavings). I think I should just try to find out where the metal came from. Maybe it was left over in the frame and worked its way down there over time? Anyone ever hear of anything like this before?
Race Progression
Redline monocog 29er (it just need wheels) for road bike PassatBoy101 The Market Place 58 07-14-2008 01:59 PM
K2 Road Bike...lightly used sdyeti The Market Place 9 03-29-2008 08:13 PM
12 lb SS Lynskey Belt driven road bike Rob The Roadie Hangout 2 02-18-2008 06:17 AM
a bike for my wife (prefer road) gurp13 The Market Place 11 02-14-2008 09:12 PM
Fenders for Cruiser or Road bike ryandood The Market Place 0 01-23-2008 04:23 PM
