Old 07-22-2008, 12:28 PM   #1 (permalink)
mfoga's Avatar
Default 10mm Bolt on Axle
How tight should a Bolt Axle be. I had 10mm QR on before but switched to bolt on. I am not sure how tight to make it.
mfoga is offline
Old 07-22-2008, 12:31 PM   #2 (permalink)
Will work for Trails
DISCO's Avatar
Also known as 3/8ths in the BMX world, my rule of thumb would be to carry the wrench used to tighten it with you on the trail.If the frame is aluminum with a shouldered nut I would say 20-40ft lbs but have never used a torque wrench for one just kept things nice and snug.
DISCO is offline
Old 07-23-2008, 09:17 PM   #3 (permalink)
tight enough it doesnt move, just a little bit looser then the big pop and breakage. Snug it up nice and tight, if you hit the drop outs with a file and take the paint off where the nuts hit it helps alot
Free riding,, because everything else sucks
mfoga (07-25-2008)
Help with a sram x-9 rear derailleur with stripped mounting bolt chupacabra The Workshop 7 07-20-2008 04:48 PM
Thru Axle question mfoga The Workshop 1 07-19-2008 12:43 PM
Installing cassette on a 10mm bolt on hub TooManyTacos The Workshop 17 03-07-2008 03:06 PM
single speed rear axle replacement new2mtb The Workshop 6 04-16-2007 10:44 AM
Fox 36 axle issue sailcalifornia The Workshop 25 03-25-2007 04:42 PM
