Old 07-22-2008, 06:36 PM   #61 (permalink)
Free-XC-Downhiller
SSinGA's Avatar
Have you tried inflating it using a compressors with the valve core out? This method works for a stubborn set of Maxxis prototypes I'm testing. It snapped the bead right into place.
www.t2bikes.com
SSinGA is offline
thephat (07-22-2008)
Old 07-22-2008, 07:06 PM   #62 (permalink)
ah buh bye now
Originally Posted by Piranha View Post
I find it hard to imagine that anyone who actually has exeprience running a tubeless specific wheelset for any length of time, like the Shimano XTR WH-975 (XC), or the Shimano XT WH-M776 (FR & AM) would ever run tubes again. Little to no flats, and very easy to set up and use. Yes, even mounting a UST tire is simple once you've got the hang of it.
Sorry, but does it sound like I've been using the the Shimano XTR WH-975 (XC), or the Shimano XT WH-M776?
Woudn't I have prefaced this thread as "Why is the Shimano XTR WH-975 (XC), or the Shimano XT WH-M776 such a PITA?"
Gone for good. PEACE.
Evil Chocula is offline
DISCO (07-23-2008)
Old 07-22-2008, 07:55 PM   #63 (permalink)
Padre's Avatar
Originally Posted by ODB View Post
No user error here, as i can set up my trusty presta tubes just fine.
We were talking about tubeless set-up, no?
Nice try dodging the point though.
Cowboy.
padre29 AT mac DOT com
Padre is offline
WarPony (07-22-2008)
Old 07-22-2008, 08:11 PM   #64 (permalink)
My opinion:
The folks who say that you only have issues if you don't take your time, or follow instructions do not share my range of experience with the product.
The folks who do not see the benefits of the product also do not share my range of experience.
Stanz is finicky. It can go great for a long time, then suddenly fail. You can have a tire model work repeatedly, then when you get a new tire it can fit a little looser even though it's the same model and brand. This will lead to sudden failures that can be loud and messy.
Stanz can also yeild the lightest possible setup, with performance advantages, and fantastic puncture resistance. There are lots of ins and outs to the situation, and no one answer for everyone.
The best is when a Stanz setup blows off, and somone gets hurt, then you get a letter from a lawyer asking for your insurance info. I wish I never told anyone about Stanz.
thephat is offline
1080P (07-23-2008), 2wheel_lee (07-23-2008), bent steel (07-24-2008), BFloFoxRider. (07-23-2008), BrewMaster (07-23-2008), DBD (07-23-2008), denmother (07-23-2008), DISCO (07-23-2008), jeffj (07-22-2008), mtnbkrdavid (07-23-2008), Shannon (07-24-2008), Shu (07-22-2008), TrojanInsomniac (07-23-2008), WarPony (07-22-2008)
Old 07-22-2008, 08:15 PM   #65 (permalink)
ArrrKelly's Avatar
For those of you putting 100 psi or whatever to set the bead...Are you soaping up the bead like it shows in the video? Watch the video and do what it shows in the video. You should not have any big issues.
Some days you're the windshield, and some days you're the bug.
ArrrKelly is offline
Chewyeti (07-23-2008)
Old 07-22-2008, 08:35 PM   #66 (permalink)
TURNERob's Avatar
I've been using Stans for many years with no major issues or trailside disasters. The biggest problems I've had involved Kenda tires and their already weak sidewalls. I haven't taken the time to read all of this thread but if some of you are using anything above 50-60psi to seat the bead then you are asking for trouble. Just read the directions, watch the vid and use an air compressor with the valve core removed to seat the bead. Depending on use you will need to refill the tire with more sealant about once a month or so. I will never go back to tubes.
TURNERob is offline
Old 07-22-2008, 08:38 PM   #67 (permalink)
ah buh bye now
No compressor, no chance of fitting one anywhere in my apartment.
Old 07-22-2008, 08:39 PM   #68 (permalink)
Thrashed Masher
Zippo's Avatar
+1000000000000000000.
isn't beating this dead horse FUN???!!!
Vertigo I can handle alright — It's horizonto that drives me nuts.
Zippo is offline
Old 07-22-2008, 09:00 PM   #69 (permalink)
ODB
Team Sting-Ray
ODB's Avatar
My point is that i've never seen the need to go tubeless in the first place. The trailside horror shows i've seen have only reinforced my opinion. But if you have a great track record with it, more power to you. Ride what works for you. ... And try not to get so uptight if someone's equipment preference differs from yours.
guero: "it's so good once it hits your lips!"
ODB is offline
DownHillPhil (07-23-2008), Evil Chocula (07-23-2008), Shu (07-22-2008)
Old 07-23-2008, 12:59 AM   #70 (permalink)
OTB
Piranha's Avatar
Sorry to hear of your troubles with Stans and tubeless. I certainly understand your frustration. Good luck whatever direction you decide to go.
__________________________________________________ _
Over The Bars Mountain Bike Club
Piranha is offline
Old 07-23-2008, 06:09 AM   #71 (permalink)
ah buh bye now
Thanks . Sorry if I'm a little snappy, this stan's thing's really worked me into a tizzy.
Old 07-23-2008, 11:44 AM   #72 (permalink)
1080P's Avatar
Default Bitchy and sticky tires
When all else fails.. RTFM. Gotta get the bead seated first before you worry about Satan"s Sealant.
You misunderstood.... I need the screwdriver not for myself but to loosen a few screws of those around me so I can fit in! Kanga "Never open a can of worms, unless you are going fishing"
1080P is online now
Old 07-23-2008, 12:09 PM   #73 (permalink)
Suck on these
uzziboy's Avatar
evil not true, u can go to sears and buy a finish carpentry pancake style compressor very small doesnt make alot of noise. I believe that you could probably get at least 4-5 full tires out of a full compressor.
And if you buy this one you can give me the nail gun for such a brilliant idea
$219.99
1 hp Universal Motor gives greater starting torque than induction motors for improved operation in low-voltage conditions. Compact size, ideal for the homeowner for inflations/small air tools. Includes 3/8 in. x 25 ft. hose, 1/4 in. female quick connect body and plug, thread sealing tape and 18 gauge brad nailer.
Choosing the perfect air compressor
Includes magnesium 18 ga. brad nailer, 3/8 in. x 25 ft. PVC hose
1/4 in. female QC body, hi-flow 1/4 in. female plug, thread sealing tape
Why ask why, does it really matter????????
uzziboy is offline
BrewMaster (07-23-2008), Evil Chocula (07-23-2008)
Old 07-23-2008, 02:25 PM   #74 (permalink)
Let's Ride
mtnbkrdavid's Avatar
Default run a tube first
I run a tube for a week or so, then remove it when the tire fits the wheel and add stanz.
Mountain biking is not what I do - it's who I am
mtnbkrdavid is offline
LncNuvue (07-23-2008)
Old 07-23-2008, 03:11 PM   #75 (permalink)
ah buh bye now
Update:
So, although the front tire is now tubed, I still have Stan's hooked up in the rear, I needed to "restan" it with some new goo.
1. Managed to remove the valve core and inject new goo.
2. Much to my SHOCK, the tire then resealed and reinflated with no problem.
So, year to date, this is the first Stan's related procedure that has gone smoothly for me. There may be hope yet.
Old 07-23-2008, 03:25 PM   #76 (permalink)
Default not counting pec implants
i've only had one flat in the last couple of years. maybe it's where i ride (feather land). maybe i'm doing something wrong...
dirtvert is offline
Old 07-23-2008, 05:26 PM   #77 (permalink)
1080P's Avatar
Update:
Maybe you should skip the stans and only put it in when your tire starts to leak, Carry a 2 oz squirter of Satan's Sealant, a Co2 cartridge and a roll of paper towels handy in your backpack for when you need it?
1080P is online now
Old 07-23-2008, 07:56 PM   #78 (permalink)
Ahh Colorado
sheesh, you guys are causing me to question my belief in Stans with all the talk of blown tires off rims, ringing ears and spooge dripping from the chin ;-)
I've been using it for years with kenda tires, however, just today I thought I'd try a Schwalbe and was not able to air it up with Stan's...bahhh. I agree, it is a PITA and frustrating when you can't get it to air up. I put a tube in and may just leave it..we'll see.
In the last few years of using it though, I haven't had any flats. One slit sidewall which required me to put a tube in and one bead blown off during a crash...but the crash came first and was not caused by the bead coming off. So, I'd have to say that during those several years I would have had several conventional flats...so I think all in all its been a good experience for me.
Not sure I saved any money, as I've bought several bottles of Stans and not sure that there is much if any weight savings, but I think the tire does ride better and traction may be slightly better. The time I have saved by not changing flats on the trail has more than been made up for by the time I've spent installing Stans on new tires...so its not a time saver.
I dunno, someone convince me one way or the other....that broken shoulder story almost pushes me over the edge to Yes Tubes.
EJ_92606 is offline
Old 07-24-2008, 08:44 AM   #79 (permalink)
Default Had to read this more than once.......
Difficult set-up?
Spattered goo?
You must have the wrong system.
Mine is none of what you described. Oh yes, I maintain 4 tubeless wheelsets. 100% easy and goo-free.
Must be user error.
Padre loves "Scams Tubeless"
What is next cats and dogs sleeping together
Hydro brakes now Stans
Now if you ditch the Lenz all will be right in the universe
