What do you guys do with the extra length of screw coming out into the shoe? The liner seems to hide it well but I have a feeling after a couple of rides the liner will be destroyed. My pedals came with stickers to place over the screws but it doesn't look like it'll help. Any tips/tricks for a first timer in clipless?
Old man goin' downhill
Same question as Dirty.
Ever since I switched to Mallets I have noticed a lot of the cleats/pedals seem to come with longer screws then does with the Shimano. I thought it was just the shoes since I had just switched to a new pair but found they were to long for a few different makes of shoes. Grind 'em down - takes about 1min If you have thick soles on yer shoes you could add a spacer/shim under the cleat Go to the hardware store and buy shorter screws Grin and bear it is the easiest way. ![]() EDIT: I just took a look in the CB box and it appears they come with TWO (2) sets of screws, one set longer then the other. ![]()
"If it aint a weight supporting bone then get back out there!!"
wild in the streets!!!
![]() run platform pedals k.i.s.s!yeah what every one else said go to your l.b.s and get the right length screws.
todays forecast heavy 951 with a slight chance of 909.. http://www.ericmaaskesclassictattoo.com/artists.html |
LOL!!! Thanks for the responses!! I guess i'll just get shorter screws. The screw is more than 1/2 an inch long and it seems like half of the screw is sticking out into the sole so I don't think washers will help. I don't have a grinder, just my hand-holding-the-screw-to-the-sidewalk grinder.
BTW, I have SPD cleats/pedals. |
and your sure you hae all the parts in your cleats???
LycraCladChampLike
Cant find the right size screw grind the current screw.
Blue Rat: The Guy was a DWARF! No kidding-- an honest-to-goodness midget! He storms over to my car, looks up at me and says, "I AM NOT HAPPY!" So, I look down at him and say, "Well then, which one are you?" |
My Quick Fix: My shoes came with these phillips screws to secure a cover over the mounting area and those are short enough. I didn't realize I had those but they fit good. I will go to the hardware store and find some replacement ones. Thanks for the help guys! I really appreciate all of your help.
LycraCladChampLike
are you sure you arent using toe cleat screws? I know my shoes came with 2 screws and 2 hole(Pairs) the longer screws were for a toe cleat of some sort and the shorter ones were for the sbd cleat.
#20 (permalink) |
Team Brittle
The longer screws are to help keep your foot from sliding around in the shoe....
BrewMaster (07-17-2008),
destroyer (07-17-2008),
mtnbikerfred (07-17-2008),
osmarandsara (07-17-2008)
| Adapting to flats from clipless | zipsbiker | General Discussion | 45 | 06-24-2008 10:41 PM |
| Clipless pedals? soo confused | BAD_S197 | General Discussion | 83 | 05-02-2008 06:51 PM |
| Clipless Pedals | SheDevil | General Discussion | 31 | 02-03-2008 01:12 PM |
| Thank You -- You Guys Rock!! | queenwilhelmina | The Pub | 12 | 08-18-2007 10:51 AM |
| First clipless pedals? | Frozen208 | The Workshop | 33 | 08-24-2006 08:38 PM |
