Old 07-15-2008, 06:42 PM   #1 (permalink)
Default ok hfx-9HD problems cont....
I rebuilt the caliper properly everything went well, bled the system multiple times and get little to no movement form the pistons.
Time to rebuild the master cylinder??? OR could it be possible the cap is leaking? something has an air leak? I have bled 9's before with no problems what-so ever so i dont know what gives
Old 07-15-2008, 06:46 PM   #2 (permalink)
bighit8's Avatar
could be possible you have a bad brake hose.
singletrack angel: is that a real hole Fred?
Mtbnbikefred: Yes,I have stuck all kind of things in it.
bighit8 is offline
Rockinthecasbah (07-15-2008)
Old 07-15-2008, 06:55 PM   #3 (permalink)
They bleed strong occasionaly and then act like they get air sucked into the line... so maybe they could have a pin hole in a bent spot that opens up at certian parts of the travel??? the last time I bled them though they wouldnt firm up at all? Maybe i should just buy a new 69.99 nine for the back and put my BFL lever on it
bighit8 (07-15-2008)
Old 07-15-2008, 06:59 PM   #4 (permalink)
bighit8's Avatar
If im not mistaken they can leak internally between the inner and outer layer.I had a similar problem with the same brakes.I had a steel braided line.After trying everything else; I replaced the line and the brake has worked fine since.
bighit8 is offline
Old 07-15-2008, 07:01 PM   #5 (permalink)
I may just go buy a new rear at jensons , 69, new line and pads
Old 07-18-2008, 09:21 AM   #6 (permalink)
DHS
DHS's Avatar
the HFX series also had a couple issues with how they use to be made. the master cylinder in the lever if dropped or hit a certain way, could just break. saw it happen a lot from 2004-2006 at diablo and plattekill. never have i bled so many hayes brakes
DHS is offline
Rockinthecasbah (07-19-2008)
New to STR Red Hot Sloth Introduce Yourself 107 06-08-2008 11:42 AM
Magura bleeding problems... jasonmason The Workshop 8 05-14-2008 05:21 PM
Bike storage problems solved! dutch General Discussion 38 01-05-2008 08:21 AM
Roof Rack Problems? ryandood General Discussion 8 11-28-2007 08:24 AM
Avid Mechanical problems Flat Broke The Workshop 11 10-18-2006 11:10 AM
