Old 07-10-2008, 09:27 PM   #1 (permalink)
Question Help removing a crank
I'm trying to paint my bike frame and cant get my crank off its a taper end bottom bracket, I dont have a crank puller, and was just wondering if there is a way to get it off with out buting a crank puller.
maxxisracing is offline
Old 07-10-2008, 09:29 PM   #2 (permalink)
Team America! F*K Yeah!
duke777's Avatar
The answer is no, you should not be able to pull your crank off with out a puller. Just go to performance, they have cheap pullers.
Hi my name is Duke777 and I'm a Ti-holic.
duke777 is offline
Old 07-10-2008, 09:39 PM   #3 (permalink)
OK, I assume you have a flat taper and not an ISIS BB. In a pinch, sometimes you can loosen the bolts, then do some hard pedal strokes on each side to remove the cranks. Sometimes, they may pop off within a couple strokes. This can be dangerous, so be careful. Also, be careful when it does come loose so you don't damage the taper in the crank arm. Yes, this is a hack method.
But it's really best to use a puller.
Old 07-10-2008, 09:40 PM   #4 (permalink)
then replace the cranks bolts with self extracting crank bolts.
Old 07-10-2008, 09:50 PM   #5 (permalink)
Dirtbag
DirtymikeTDB's Avatar
A Puller is best, Self extracting bolts are next best, but if your realy skills, a couple small rattles of a hammer will pop them loose as well.
Originally Posted by deja vu View Post
....Leaving your nuts loose is always a good practice too, but sometimes hard to do when wearing lycra!
DirtymikeTDB is offline
Old 07-12-2008, 11:24 PM   #6 (permalink)
you can use an automotive style gear puller if you have it available at least on the drive side
Free riding,, because everything else sucks
Old 07-12-2008, 11:27 PM   #7 (permalink)
Will work for Trails
DISCO's Avatar
It's not that hard, just use a 14mm on the bolt, put your feet on the frame and work it side to side till it comes loose.
DISCO is offline
Old 07-13-2008, 08:33 AM   #8 (permalink)
downhiller91's Avatar
tke the bolts and and go ride it till the cranks fall off
you can go first or i can go first either way ill meet you at the bottom.
downhiller91 is offline
Old 07-13-2008, 06:16 PM   #9 (permalink)
cookie monsta
SnookDawg's Avatar
A crank arm is the only way to remove the crank and be sure that you won't round off the square-taper interface inside the crank arm. Riding it without the retention bolts is the worse thing you can do, as it would certainly ruin the crank arm. It only takes a small amount of rounding of the soft aluminum crank by the cromoly spindle to start a vicious cycle of the crank coming loose and having to torque it further up the spindle until you are buying a new crank arm, not to mention the frustration with your crank arm coming loose and your chainline constantly needing adjustment, sometimes mid-ride.
Buy/borrow a crank-puller, it's cheaper than replacing your crank arm.
SnookDawg is offline
Old 07-13-2008, 07:07 PM   #10 (permalink)
Sometimes a rubber dead blow hammer will do the trick and it shouldn't damage the crank. Just tap the edges and should vibrate it loose. If that doesn't work I have the removal tool. I will be happy too remove them for ya.
KTMRDR is offline
My Crank Bros Candy SLs or Mallet Ms for your Quattos bikeadict The Market Place 0 05-15-2008 10:45 AM
Crank arms, BBs, wheel set,shock.... theclayster The Market Place 20 05-04-2008 09:41 AM
Garage Sale - Fox Forks / Crank Bros Eggs Ti / Shoes / Moab Frame / XTR Pods and Rear boboso The Market Place 12 01-04-2008 09:27 PM
Crank Set for Beach Cruiser/Coaster Brakes TwoLeggedHorse The Market Place 0 10-08-2007 12:35 PM
Removing chainrings on a XT crank andino The Workshop 10 04-24-2007 02:24 PM
