Those non-sealed bearing hubs are some of the best rolling hubs out there, and they're the most durable, providing you maintain them.
Because they are loose bearings, the XT hubs are relatively easy to take apart, clean, regrease, and reassemble. I'd use a relatively light synthetic or lithium grease. There are many great greases out there, and the Phil Wood grease is often recommended. "However, I'm not that partial to any one brand of grease, though. How often you'll need to do this depends on your riding conditions and how you wash your bike. I would rebuild the hub, give it some time, and do it again. If the grease still looked really good, then perhaps you rebuilt them too soon; that's ok, wait longer next time. It's better to do maintenance too frequently than not often enough.
EJ_92606 (07-09-2008)
Chumba Pimp
If you want to give it a try get some cone wrenches for a standard QR it's typically a 15mm and a 5/8ths or 16mm on the outer nut. There are various tubs of soap based junk but I like to get tubes of the highest quality synthetic available. Pro-long was good, Phil's is better. Clean the old crap out with some paper towels and fill the cups and drop in the balls with the axle in to prevent drop out. You ought to wear gloves or let a shop do it but they will have the good grease anyway. If you try ace hardware there is a small grey tube for like four bucks that has served me well.
Ahh Colorado
Thanks guys, I'm going to give it a try myself. These hubs have never been serviced and are about 4 years old, but have been sitting on a shelf for the last 2 years...but their first two years they saw many thousands of miles of use. Probably not a bad idea to replace the bearings and cones at this point eh?
Chumba Pimp
Yeah and even if they are galled, pitted and scored from Cavitation a little grease will go a long way. Resist the urge to use one of those needle tipped grease guns that spew cheap white lithium, it wont last unless you get all the dirt and powdered heavy metal out.
But if the bearings, races, or cones are galled, pitted, or scored, replace them. They may last for a while, but their life is very limited.
Chumba Pimp
Makes want to search for the Video of Captain Kirk saying "dont correct me it sickens me".
You are correct sir cavitation requires some kind of liquid and few of us ever get our grease that hot. For finding today's secret word you get a cookie, or rather whats left after the G.I. Tract is done with it. Still crunchy cups and cones can eventually re-bed if not too far gone. My favorite is when people keep riding the cups after all the balls have dropped, leaves that really cool shoulder on the axle. (tre Flinstone) |
Its an easy process. You can get the lube from just about anywhere. I used the stuff i found at performance. It worked, but i had to clean the hubs more often. The best I ever had was some very thick red stuff i bought 15 yrs ago. cant find it though.
just make sure you tighten the nuts back right. I had the problem of the cups being too tight when i closed the QRs. I did not use a cone wrench which is probably the problem.
Spank me and call me Jonny! |
Ahh Colorado
I recently rebuilt my XT rear hub and it doesn’t get much easier. It all started when I was having what I thought was ghost shifting issues. The bike is fairly well maintained so I started to replace drive line items; chain first then the cassette, still had sporadic “shifting” problems. I finely diagnosed the freehub was skipping.
A new freehub and 18 new bearings at 10 cents each has my old XT hub working like new again. ![]() |
#13 (permalink) | |
Stick with grease.
Dirtbag
I am doing the roadie wheels this weekend myself, personal favorite for grease are Phil wood of coarse, but also if your looking for that stupid smooth and fast roll, you can use slick honey, just know that it wont last as long as proper grease. Any poly synthetic grease will work.
P.S. Stay away from Lithium greases, that type os grease is designed for metal sliding on metal, not rolling. Whatever you get, make sure its approved for bearing use. |
#15 (permalink) | |
Ahh Colorado
