Old 07-07-2008, 10:47 PM   #1 (permalink)
KBL
Powered by chocolate
KBL's Avatar
Exclamation Hope Mono Mini Users!
I'm riding the older version of the Mono Mini. It's the one with the fixed rotors and the direct-mount (no adapter) caliper.
While I like the simplicity, the system doesn't leave much room for misalignment. Even the slightest rotor tweakage/heat warpage brings on the rubbing sounds. This is annoying and distracting. I start thinking about what might be wrong with my brakes instead of what's up ahead on the trail.
I am considering swapping out my fixed rotors for Hope's newer floating rotors.
Are any of you using the new-style Hope rotors?
If so, how do you like them?
Do they rub the calipers and make noise?
Thanks for your info...
Kevin
Beware, lest STR suck you in too far...
KBL is online now
Old 07-08-2008, 06:09 AM   #2 (permalink)
Tom Brady Look A Like
MTBMaven's Avatar
I have been using Hope Mono Minis for years. The ones I have are black with gold round thing. Not the older silver minis. Not sure if there is a newer version or not. The ones I have have been excellent!
You must be the change you wish to see in the world Mahatma Gandhi
Border? I have never seen one. But I have heard they exist in the minds of some people. Thor Heyerdahl
All steel stable: '08 DeSalvo - '07 Niner MCR9 - '89 Specialized Sirrus fixed/free
MTBMaven is offline
KBL (07-08-2008)
Old 07-08-2008, 06:42 AM   #3 (permalink)
Default Newest version
The new design does not use shims.
OP....... Do you have any pics? Sounds like an adjustment issue
KBL (07-08-2008)
Old 07-08-2008, 07:08 AM   #4 (permalink)
Quest: Singletrack
mntbiker12's Avatar
Not sure that the floating rotors would help you with your issue. As DZ said, it sounds like they need adjustment.
I have the floating rotors and experience the same problems if the caliper isn't adjusted properly.
Peace, love & bikes!
FOR SALE: 04 Haro XLS R7 • Sunline V3 Bars
mntbiker12 is online now
KBL (07-08-2008)
Old 07-08-2008, 07:31 AM   #5 (permalink)
I've had the floating rotors on two sets of Hopes and honestly, I don't think they'll hep your situation. You can true your existing rotors using an adjustable wrench to slightly tweak the rotor back into alignment.
KBL (07-08-2008)
Old 07-08-2008, 07:52 AM   #6 (permalink)
Hope rotors/pads tend to cause a lot of noise. You might try using iso alcohol to clean your rotor and pads throughly. And then try organic pads if that doesn't work. I am not sure if the new floating rotors would solve your problem.
Cableguy is offline
KBL (07-08-2008)
Old 07-08-2008, 08:17 AM   #7 (permalink)
sounds like purely an adjustmant issue and the caliper needs to be shimmed over
Day Man;Fighter of the Night Man;Champion of the Sun;Master of Karate and friendship for everyone.
DeeZee (07-08-2008), KBL (07-08-2008)
Old 07-08-2008, 08:56 AM   #8 (permalink)
yup you can use tools like the Morningstar drumstix, i still need to order a set
http://www.morningstartools.com/drumstix.html
KBL (07-08-2008), Pho'dUp (07-08-2008), slowSSer (07-08-2008)
Old 07-08-2008, 11:33 AM   #9 (permalink)
ali'i hua
slowSSer's Avatar
my wallet now officially hates you. i need every single one of the morningstar tools!
slowSSer is offline
tkblazer (07-09-2008)
Old 07-08-2008, 11:56 AM   #10 (permalink)
Default +1
KBL (07-08-2008)
Old 07-08-2008, 03:11 PM   #11 (permalink)
KBL
KBL's Avatar
Thanks for all the input. I do have the version that uses shims between the caliper and the mounting tabs. The calipers are black with a gold "plug."
From what I can figure, I must have caught some debris in the rotor, which then rotated into the pads and tweaked the rotor as it went on through. The adjustment was good, and the lines had been recently bled.
I've got an Avid "wavy" rotor that I'm going to try. It is a fixed rotor, but the wavy design should eject trail debris better than the stock Hope rotor, which has no cutouts along its outer perimeter.
One other thing I might try is using a tab-facing tool to true up the mounting tab surfaces. I've been pretty meticulous with my shim spacing, but that only goes so far if the mounting tabs aren't on the same plane as the rotor.
KBL is online now
Old 07-08-2008, 03:22 PM   #12 (permalink)
Default Rotors
Be careful with the rotors. I do not think they are the same thickness (Hopes are thinner) I could be wrong but was told that you can use Hope rotors on Avid calibers but not the other way around.
I am a Hope zealot and if you are in S OC I can take look at them for you
KBL (07-08-2008)
Old 07-08-2008, 03:26 PM   #13 (permalink)
KBL
KBL's Avatar
Thanks...I'll be finding out in the next few minutes.
I'm a Hope fan, too. I'm using a Hope rear hub, which could be joined by a Hope stem and a matching lighting system.
KBL is online now
DeeZee (07-08-2008)
Old 07-08-2008, 09:56 PM   #14 (permalink)
KBL
KBL's Avatar
Default Hope and Avid get along fine...
...at least in this instance.
The rotor thickness appears to be basically identical. I did not have a caliper handy for an exact measurement, but if the two rotors have differing thicknesses I couldn't tell. Both were 160mm six-bolt rotors.
Performance was flawless--as good or better than with the original Hope rotor. I may swap out the front Hope rotor for an Avid. Like I said, I think the wavy design will clear debris much better than the round outer edge of the Hope rotor--no doubt that's why the new Hope rotors have a "shark tooth" profile on their outer edges.
After spending some time truing the rotor by hand, I decided to dig a little deeper into the caliper. It turns out that the dividing spring (the thing that resembles a four-legged spider) was mangled and twisted--no doubt the source of most of the noise I was hearing.
I am sure that some sort of trail debris was the cause. Nothing was left jammed in the caliper, but I have used a Hope disc up front for about three years without tweaking the dividing spring.
I replaced the dividing spring, pads (they still had life left, but not much) retaining pin, and wire clip. Next, the Hope rotor was replaced with the wavy Avid. I spent some time shimming the caliper, and secured it in place with blue Loctite when I found the sweet spot. Finally, I adjusted the fluid level and went for a Turnbull test run.
The brakes are working great. I'm stoked.
The end.
KBL is online now
CalEpic (07-09-2008), DeeZee (07-09-2008)
Old 07-09-2008, 05:52 AM   #15 (permalink)
Default Good to hear!
The end.
KBL (07-09-2008)
Old 07-09-2008, 02:52 PM   #16 (permalink)
KBL
KBL's Avatar
Default There's more to the tale...
I'm gonna change "trail debris" to "severely worn pads" as the culprit.
I took a good look at the old pads and they hardly had any material left on them at all. Lack of pad material means a lack of surface to rest the dividing spring against. This would allow the dividing spring to get sucked into the rotor.
What have we learned from this? Replace your pads sooner rather than later! This applies mostly to you, Kevin.
--Kevin
KBL is online now
DeeZee (07-09-2008)
Old 07-09-2008, 03:10 PM   #17 (permalink)
Default Springs
--Kevin
Had that happen to me with a set of Avid's.........but that is a different rant
KBL (07-09-2008)
Old 07-09-2008, 03:55 PM   #18 (permalink)
yup, same thing happened to me, ruined a set of pads and a rotor
Hope Mono Mini 160mm rear brake TURNERob The Market Place 10 04-02-2008 08:20 PM
Hope Mono Mini 200mm/180mm/180mm + More dubjay The Market Place 11 02-19-2008 08:33 PM
Looking for Hope Mini Mono or Mono 4 Brakes sauce The Market Place 9 01-07-2008 08:40 PM
Hope Rotor - 183mm for Hope Mini mntbiker12 The Market Place 5 12-18-2007 06:54 AM
