Old 07-07-2008, 09:05 PM   #1 (permalink)
andygua's Avatar
Default Stans Kit and Floor Pump: Is it doable?
I'm in the process of upgrading my wife's bike and got a stans (notubes) kit for it...
I've tried everything Stan explains on his video but can't get the tire to inflate with my floor pump...is it "doable" with a floor pump? I know an air compressor would do the trick, but I don't have one and the video shows how "easy" it is to do it without one...
Any suggestions?
Thanks!
andygua is offline
Zippo (07-07-2008)
Old 07-07-2008, 09:12 PM   #2 (permalink)
Granny Ringer
silverspot's Avatar
I have done it before several times with a floor pump. Make sure you use plenty of soapy water. Don't set the tire on the floor but hang it from something. If I remember correctly, I had the valve stem positioned on the top. Put a little pressure on where ever the tire leaks most when pumping and pump like a madman...
CO2 also works but only use it to get the initial seal and then pump up the rest.
Good luck!
silverspot is offline
andygua (07-07-2008), Zippo (07-07-2008), Zippy (07-08-2008)
Old 07-07-2008, 09:17 PM   #3 (permalink)
freekengo's Avatar
I always use the floor pump to pump up all of my tubeless setups. As a last resort I'll use the compressor or CO2. Like the above post make sure that the valve stem is at the 12 o'clock position, and make sure that you center the bead on the rim equally.
freekengo is offline
Old 07-07-2008, 09:20 PM   #4 (permalink)
Thrashed Masher
Zippo's Avatar
I'm sure you've watched the movies on Stan's sight, but if not, do so. Some tires are definitely harder to seal than others, but with enough patience you should get your tires to seal with a floor pump. I've found that it helps to hang the wheel with the valve at the top as silverspot suggested, and push down lightly on the tire directly above the valve to help trap the air. Good luck!
Vertigo I can handle alright — It's horizonto that drives me nuts.
Zippo is offline
Old 07-07-2008, 09:20 PM   #5 (permalink)
GET FORMULA
jonathan_sykes81's Avatar
I have been successful a couple times with the floor pump. If you can't get it, just head to your local gas station, they usually have free air.
jonathan_sykes81 is online now
Old 07-07-2008, 09:35 PM   #6 (permalink)
^needs to ride more
davidB's Avatar
this ain't the 90's anymore. they charge for that crap now
anywho, doing it exactly like the video shows is the trick.
Originally Posted by AdrenalineBikes on 3/31/08
I have 3 sets back ordered with Stans so once I hear from them I will let you know.
-still waiting. lolz
davidB is online now
andygua (07-07-2008), banksd1983 (07-31-2008)
Old 07-07-2008, 09:40 PM   #7 (permalink)
Slow Rider
onegymrat's Avatar
Hey Andy, I've been successful every time with a floor pump as well. You really have to set the beads correctly and pump hard. My tires and rims are both UST though.
onegymrat is offline
Old 07-07-2008, 09:44 PM   #8 (permalink)
andygua's Avatar
Thanks guys...I'll try again.
I've watched the video several times now, soaked the beads in soapy water, etc...the only thing I now realized I'm doing different is that I'm inflating the tire with the valve at 6" instead of 12"...maybe that detail can make a huge difference!
I'll try it again tomorrow and will tell you how it goes.
Thanks!
Andy.
andygua is offline
Old 07-07-2008, 09:45 PM   #9 (permalink)
Reciprocal Sandbagger
lukewiens's Avatar
i have found that certain tires grant access to the floor pump process and others do not. most ust specific tires have a beefy enough sidewall for it to seat well enough on the bead for a floor pump to catch. almost all of the non ust tires i have tried have been literally impossible to seat.
all i know is if you can find an air compressor (work, friend, etc.) it can turn the process into a 10 minute job and less all of the sweat and frustration.
"When you get hurt and all of your sacrifice adds up to nothing, are you willing to put it all on the line again?" - Conrad Stoltz
MY BLOG - www.mountainbikeluke.com
lukewiens is offline
Old 07-07-2008, 09:59 PM   #10 (permalink)
Dirtbag
DirtymikeTDB's Avatar
Unfortunatly with teh stans kit, its all about the tire and rim combo, which tires and wheel are we talking about???
Any suggestions?
Thanks!
Good thing they passed that law a couple years back making it illeagal to charge for air if your asked for it!!!!!
If you dont like the local Gas station, just stop at your Local garage, the guys are usually pretty cool about doing something like that.
Originally Posted by Sharky View Post
Well DirtyMike is always UBER sexy .
http://bighugelabs.com/flickr/motivator.php
DirtymikeTDB is online now
Old 07-07-2008, 10:00 PM   #11 (permalink)
^needs to ride more
davidB's Avatar
for reals? i'm gonna go tape a sign to the one on the corner that says "go inside and ask for air, it'll be free"
Old 07-07-2008, 10:04 PM   #12 (permalink)
Dirtbag
Haha, yeah. They either need to give you a token, turn it on remotly, or give you a code to turn it on. Bu if you need air for a tire, and you ask, one way or another they cant charge you for it. One of those new DoT laws trying to keep the streets safer, giving noone an excuse why tehre air pressure was low casuing a blowout Bla Bla Bla.....
Just a note though, if your in need of a compressor to get your tires on with a stans system, your not going to get it on with the quarter op machine at teh station anyways, they usually only supply about 35PSI, and not much volume. What it really takes to get these on is Volume a compressor set at 90 PSI will always do the trick, If you live near me, come see me at goodyear, I would ba happy to shoot your tires up for you
Old 07-07-2008, 10:29 PM   #13 (permalink)
andygua's Avatar
Ok, I couldn't wait (this is killing me!), so just went outside and tried it one more time...
Lots of soapy water, internal rim aligned, valve at 12" and nothing...I couldn't do it with my floor pump
Btw, the rims are WTB DX23 and the tires CST Caballero...nothing fancy (nor UST), just the stock stuff that my wife's bike came with.
Maybe it's a good excuse to get an air compressor?
andygua is offline
Old 07-07-2008, 11:02 PM   #14 (permalink)
Dirtbag
now your talkin, is it presta or schraeder? if schraeder try removing the valve core
Old 07-07-2008, 11:07 PM   #15 (permalink)
92se-r's Avatar
Used tires yes. My success rate with used tires is like 10-20%. With new tires, no way. I have an air compressor now and even now it is like only 50-70%. I've pretty much given up on Stan's. Didn't notice a benefit.
92se-r is offline
Old 07-07-2008, 11:14 PM   #16 (permalink)
Shu
Team Brittle
Shu's Avatar
I've done a total of 3 wheels and have done all 3 w/ a floor pump and NO soapy water....NO problems at all....bead set easy....
The benefit I noticed was passing all the people on Butcher trail in Downieville fixing flats(easily 10+)....I HATE FIXING flats on the trails...
07 Bionicon Golden Willow
Rat Rod cruiser
Shu is offline
Old 07-07-2008, 11:19 PM   #17 (permalink)
andygua's Avatar
It is a schraeder...how do I remove the valve core? That will help by increasing the air flow right?
andygua is offline
Old 07-07-2008, 11:19 PM   #18 (permalink)
jamesdc's Avatar
I could never seal tires with a floorpump, I'm running ghetto tubeless though, not stans. I bought a co2 because I dont have a compresser either and it seals tires usually first try. Buy the gun cartridges though, they are alot cheaper than the ones meant for the inflator.
jamesdc is online now
Zippy (07-08-2008)
Old 07-07-2008, 11:36 PM   #19 (permalink)
Dirtbag
With a valve core tool, there about 2 bucks at your local auto parts house. yes with the valve out, it will allow more volume to come through the stem.
One more question, did you drill the inner wall of the wheel? and what rim tape are you running underneath the rim strip?
Old 07-08-2008, 07:30 AM   #20 (permalink)
Derailleurs R4 Failuers
hoovermd's Avatar
Just did a 650B NeoPacenti tire on a stand rim.
Not only did it require the compressor, I had toremove the valve core the first time to get enough psi and volume to seat the tire the first time.
Mark
hoovermd is offline
