#21 (permalink) |
They have great deals on compressors at Lowe's!!!
My Blog/My Sponsorhouse profile ~Weekends are like recess for adults so play hard until the bell rings Gene Hamilton: Happy, friendly people that may not be the best athletes are more fun than arrogant "experts". |
#23 (permalink) | |
I'll give it a couple more tries today removing the valve core and if it doesn't work, I think I'll just go and get a compressor. Will let you know how it goes. |
Zippo (07-08-2008)
#24 (permalink) |
Thrashed Masher
Switch to the Stans tape - you may be getting air leaks through the stock tape, especially if it's something porous like Velox. And what are you using for a valve stem (I saw that it's schrader & I've only ever seen & used Presta) - did you make your own rim strips?
EDIT: I see now that they do indeed make schrader kits with removable cores. |
#25 (permalink) |
Did I say schrader?
It's presta...sorry!I'm using the kit's rim strips and as for the tape, Stan recommends to use his only when the stock one is too thick and the strip would go beyond the rim's walls, and this is not the case... |
Zippo (07-08-2008)
#26 (permalink) |
Thrashed Masher
have you heard the bead "pop" into place on the rim, or are you unable to get enough air into the tire to get it to set? If the tire is too TIGHT, prohibiting the bead from fitting under the bead lock, you need to remove the rim tape (and possibly even the rim strip requiring you to use an Olympic valve stem w/out a rim strip) and use Stans yellow tape. If the tire is too LOOSE you can build up the center of the rim with Velox or a thick rim strip.
It's also entirely possible that the bead on your tires is stretched out. Unless you plan on using a compressor alot, it may be a wi$er purchase to get a new set of tires. And for unused tires that are stubborn to inflate, mount with a tube to stretch and shape the bead, and then install with tubeless with Stans sealant. |
#27 (permalink) |
I just installed two WTB weirwolf tubless tires onto my SLR tubeless wheels last Thursday. I used only a floor pump to get enough air in the wheel, no soap. I set the valve to about 3 or 6 oclock and had the wheel/tire in the upright position. I had my wife help me hold the tire and we got the front on in one try and the rear took about 3 tries. Good Luck!!
#28 (permalink) | |
Intensive!
#29 (permalink) | ||
Dirtbag
http://bighugelabs.com/flickr/motivator.php |
#30 (permalink) |
The G is for Gear
I was doing the Stans conversion one night and it took a long and frustrating time to get any air into the tire. I had to have the tire touching the garage floor just enough so there was equal pressure from the weight of the tire to create a seal. Of course doing that I had to hold the tire just right with one hand and pump with the other
![]() So finally after a good twenty minutes of one handed pumping (yes, insert pun now ) I finally get enough pressure where the tire is finally holding air. Now I'm dripping in sweat, out of breath due to exhaustion and frustration and can finally relax a bit. All I have to do now is get the tire bead to seat on the rim by getting a few more PSI in. Max tire pressure shows 65 PSI, no problemo! Getting closer now, 60...61....62, okay there's the pop, bead is now seated. Better put a little more air in, just in case. 63...64...65...6...KAPOW!!! I thought I was hit by a flash/bang grenade. I was stunned for a few minutes and all I could hear now was a high pitched whine. The smell of rubber and Stans sealant permeated my nostrils and in my daze I saw Stans splattered all over the floor and the tire hanging flaccidly from the now distorted rim. ARRRRGGH!! I'm still hazy on what I did after that. I think I may have dropped everything right there, turned off the lights, plopped down on the sofa and nursed a beer in my stupor. ![]() |
