Old 07-06-2008, 09:46 PM   #1 (permalink)
break yo'self foo
UseItOrLooseIt's Avatar
Question Lubing a rear shock
Should you use lubrication on a [FONT=verdana, arial, helvetica][SIZE=1]Manitou Metal RP Coil?
If so, where should it be applied?
[/SIZE][/FONT]
UseItOrLooseIt is offline
kdog4130 (07-07-2008)
Old 07-06-2008, 10:31 PM   #2 (permalink)
Rock it, rip it, shred it
kdog4130's Avatar
Default Let it ride....
Lubrication is not really needed. Just keep it clean, and look for leaks, that's all!
Come and shred some gnar with me
kdog4130 is offline
UseItOrLooseIt (07-06-2008)
Old 07-07-2008, 10:05 AM   #3 (permalink)
Dirtbag
DirtymikeTDB's Avatar
Exactly, keep it clean, look for leaks, ride away. This on a faith three???
DirtymikeTDB is offline
Old 07-07-2008, 09:39 PM   #4 (permalink)
OldDogDan's Avatar
It looks like it has plain bushings in the mounting eyes. Put a little grease on the mounting bolts when you assemble it, and maybe every several months. You could occasionally put a little oil on the shaft at the seal with a q-tip, then bounce it up & down a few times to spread it on the shaft. Don't overdo it or it'll attract dirt. Because of the coil, you'll have to get any excess off with a strip of cloth. But you could skip oiling it if the shaft stays clean & shiny looking -- most seals let a little oil by. But if you live by the coast (salt air), definitely oil it. You could also ask Manitou. Or just ignore it and ride!
OldDogDan is offline
Deciphering rear shock size jonv05 General Discussion 4 06-09-2008 10:45 AM
WTB: rear shock Shu The Market Place 7 04-02-2008 08:36 PM
Anyone else have problems with Specialed rear shock? Scott V The Workshop 13 02-07-2008 05:48 PM
SOLD!!! YETI ASX lg w/ Rocco rear shock upgrade J_Sims The Market Place 19 01-03-2008 04:11 PM
Fox Rear Air Shock BUSHING? PHAT TIRE The Workshop 4 03-12-2007 04:57 AM
