break yo'self foo
how can you tell when you need to replace a tire's tread? can you just switch the back to the front to solve this, or should I use new treads? How long can you use a tread before you should replace it?
DirtymikeTDB (07-06-2008)
GET FORMULA
With basically every bike and every rider the rear tire will go first, I run my rear until it has almost no center tread left and I usually replace both front and rear at the same time, then in an emergency I have my somewhat used front as a back-up in the garage. If you want to swap them then go right ahead. There are a lot of variables to how long you can run a tire; rider weight, tire pressure, tire rubber durometer(hardness), rider weight distribution.
I have really started liking Kenda Nevegal's and I inadvertently learned a trick to make your tires wear at relatively the same pace and give you more traction up front. I run a DTC(Dual tread Compound) in the rear and a Stick-E up front. |
amor587 (07-09-2008),
DirtymikeTDB (07-06-2008),
OldDogDan (07-09-2008),
UseItOrLooseIt (07-06-2008)
Small, but Mighty
I use the same front and rear so that when the rear wears and starts slipping on climbs, I put the old front on the rear and then buy a new tire for the front.
Don't put the used rear on the front: I did that once and it made cornering very exciting.
L8 APEKS: "Never underestimate the power of stupid people in large groups." Swim, bike, run. www.zippyathlete.blogspot.com |
Dirtbag
Personally I run my front tires for... well about forever. Front tires dont wear at all close to as fast as a rear, As far as the rear, I pretty much run them untill I damage the sidewall, or they have become a semi slick.
It depends where I am riding. Around the OC it does not bother me to run wore out tires. But with trails that are loose with extreme exposures I want tires that still have that sharp cutting edge on the knobs. Tires are cheap insurance.
bighit8 (07-06-2008),
freekengo (07-09-2008),
FyrFytrRyn (07-08-2008),
Dumb-fock alert!!!
Mods, somebody please delete this non-sense and ban said idiots IP.
"The perfect lover is one who turns into a pizza at 4:00am." ![]() |
mtnbkrdavid (07-09-2008),
schleppp (07-09-2008)
| 29er Tire Combos | BrewMaster | The Workshop | 241 | 07-10-2008 02:13 PM |
| Nevegal Tire Knobs coming off | Sprockethead | The Workshop | 24 | 05-02-2008 04:12 PM |
| Kenda Dred Tread Review | Team Smitty | General Discussion | 2 | 04-29-2008 04:48 PM |
| which tire with most traction | hobie | General Discussion | 28 | 04-21-2008 06:38 AM |
| Tire problem | Dino Brown | The Workshop | 22 | 12-26-2007 08:34 PM |
