Old 06-20-2008, 07:34 PM   #1 (permalink)
Its that time again...
bvader's Avatar
Default UGH!! Just Found this on My Fork
2007 Talas 32mm
Generally I am very very careful with this type of stuff but I have no idea when / how I did it. In all my years, I have not had a gouge like that and especially no knowing where it care from. I have a feeling it was a garage casualty.
By touch there is nothing sharp "outward" if feels "all in" if that makes sense and not too deep. Put some Slick Honey on it and feels OK I guess. Rest of the shock feel fine / straight / responsive etc.
Planning to ride SART tomorrow unless someone tells me absolutely not. I am not sure if/how this is fixed, or if I need a new fork or do just ride it until it causes a problem.
Anyways just bummed a bit...
Any thoughts? (Feel free to call me names and tell me to get over it)
First picture is with the Shock pump adapter to give size reference
bvader is offline
Old 06-20-2008, 07:49 PM   #2 (permalink)
jamesdc's Avatar
damn, that pretty bad, wet sand it with really fine sandpaper then fill it with nailpolish and it should be fine
jamesdc is offline
bvader (06-20-2008)
Old 06-20-2008, 08:03 PM   #3 (permalink)
Steve Peat Wannabe
project_d's Avatar
If it's not leaking oil, then I'd ride it. I've got some scratches on my stanchions, and I've been riding, and I've been good.
project_d is offline
bvader (06-20-2008)
Old 06-20-2008, 08:27 PM   #4 (permalink)
ghixon's Avatar
Ditto on the nail polish idea. If it's too deep, try some JB Weld and sand with 500-750 grit wet/dry sandpaper. You will wear seals a bit faster, but at least you won't have to shell out $200 to replace the stantions.
ghixon is offline
bvader (06-20-2008)
Old 06-21-2008, 01:48 PM   #5 (permalink)
A little late now, but rather than removing the ano coating surrounding the scratch by sanding, you can scrape the burrs with a razor blade until nothing sticks out.
bvader (06-21-2008)
Old 06-21-2008, 01:52 PM   #6 (permalink)
I second the JB weld. I've fixed countless scratches with it, and its much more manly than nail polish.
This one looks pretty deep.
evdog is offline
bvader (06-21-2008)
Old 06-21-2008, 02:44 PM   #7 (permalink)
OldDogDan's Avatar
It looks like that blob at the bottom may be raised...get a steel rule or other straightedge to lay along the fork, and be real sure nothing sticks up. If it does, remove it. I wouldn't bother filling in the gouge, but I would smooth the edges carefully with emery cloth, without enlarging it any, until it felt completely smooth to the touch. It may be a little deep, but it's not very long...unlikely to compromise the seal as long as the edges are smoothed. But the seal may already be damaged. Smooth it, then ride it & see.
OldDogDan is offline
bvader (06-21-2008)
Old 06-21-2008, 05:32 PM   #8 (permalink)
bvader's Avatar
Thanks all.
Rode it today seems ok but I think I can smooth it out a bit with the suggestions above.
bvader is offline
Old 06-21-2008, 06:36 PM   #9 (permalink)
Kritter's Avatar
never thought of nail polish...super glue or jb weld works and then wet sand it back smooth. Works on motorcycles which see a lot more abuse.
Everytime that passes the seal it will drag oil or air with it in its current condition...whichever it is sealing.
Kris Hernandez
Kritter is offline
bvader (06-21-2008)
Old 06-21-2008, 07:04 PM   #10 (permalink)
I'm a FUN-GI!
L8 APEKS's Avatar
Have you asked Fox about it yet? Maybe they would warranty it. Who knows?
Anyway, I'd use one of the suggestions for a filler (I'd use an automotive filler as it's easier to sand/work with than JB is), and lube the sanction with a little dry oil before rides to help make up for the friction in that spot so it doesn't really impact the life of that part of the seal.
-Sean - Founding Member of the DNF-6 Race Team!
2007 KHS XC204 :: ...and a pair of Chevro-legs!
"Justin had a warm spicy sausage...which I slowly munched on while I sipped Perpetuem and Pepsi." - Allison
L8 APEKS is offline
Old 06-21-2008, 07:32 PM   #11 (permalink)
OMR
OMR's Avatar
Talking Grasshopper...
This didn't seem to stop you from having fun with us today at SART..
OMR .... An elder grasshopper of the Tribe
The journey is the thing .... ride like it's your last one...
OMR is offline
bvader (06-22-2008)
Old 06-22-2008, 08:11 AM   #12 (permalink)
DHS
DHS's Avatar
its not Fox's fault he crashed. these things happen. don't blame someone else
DHS is offline
Old 06-22-2008, 08:13 AM   #13 (permalink)
bvader's Avatar
No It did not. In fact once we started riding low and behold it didn't enter my mind once!
Hey who said I crashed!
bvader is offline
OMR (06-22-2008)
Old 06-22-2008, 09:21 AM   #14 (permalink)
I'm a FUN-GI!
L8 APEKS's Avatar
Ummm...let's re-read the OP...
How about we leave it up to Fox to determine whether or not they feel like replacing it? Some companies do this sort of thing (Camelbak comes to mind), and others don't (Answer/Manitou comes to mind). But I think they can make their own decision.
L8 APEKS is offline
bvader (06-22-2008), nouse66 (07-06-2008)
Old 06-22-2008, 11:00 AM   #15 (permalink)
bvader's Avatar
BTW the thought of calling Fox never entered my mind, but that is why I ask you guys. What ever happened it was certainly my fault. I will probably ask the Path guys since "they are my people", but I don't expect anything, and am not expecting that I/they will contact Fox.
bvader is offline
L8 APEKS (06-22-2008)
Old 06-22-2008, 11:08 AM   #16 (permalink)
I'm a FUN-GI!
L8 APEKS's Avatar
Good businesses are willing to lose the ~$40 it would cost them to replace a sanction tube in order to keep a loyal customer, in hopes that you will share your good experience with other people and therefore, provide more customers.
In practice, they have the potential to make more money this way, than if you were to spend $175 replacing the sanction yourself (especially if, down the road, you and perhaps 2 other people you have talked to buy new Fox forks...spending perhaps ~$1800 instead of $175).
I'm not saying they'll give you a free one, but who knows? It's worth a 30 second phone call to find out if they can do anything to help!
Anyway...it really isn't that bad of a gouge. I think you'll be OK smoothing it out and leaving it be. Worst case scenario, you may have to replace a $20 seal a little more often. No biggie!
For me, the most frustrating part of a blemish like that is just the fact that it's an eyesore! Coulda been worse though. Good luck!
L8 APEKS is offline
bvader (06-22-2008)
Old 06-22-2008, 12:13 PM   #17 (permalink)
A ding on the fork tube that is no way due to a manufacturing defect and you want to get Fox involved? I don't get that sort of pass-the-responsibility attitude.
R
EMrider is offline
Old 06-22-2008, 12:42 PM   #18 (permalink)
I'm a FUN-GI!
L8 APEKS's Avatar
R
Ok, some people on here seem to automatically come up a couple cans shy of a 6-pack in the heat.
I'm not suggesting he call them and ask them to replace it for free. I'm suggesting he could call them directly and ask them what it might cost to replace that part. And maybe if he's nice, and if they have good customer service, there's a chance they may give him a better-than-average price on replacing that part if he plays his cards right.
I worked in the returns dept. for an aftermarket automotive company who did something similar. And we didn't chastize anyone for "not manning-up to their responsibility" either. Unless they were complete douchebags asking for a 6-speed sequential gearbox because their differential failed.
You may get back to your now.
L8 APEKS is offline
Reba questions traumadiver The Workshop 8 02-25-2008 02:04 PM
SOLD! '07 Fox 32 TALAS RLC Fork - 100, 120, 140 mm Travel 2wheel_lee The Market Place 7 02-22-2008 09:08 AM
Fork Help! freewheeler The Workshop 5 01-11-2008 10:23 AM
'06 Fox 36 Vanilla RC2 fork TURNERob The Market Place 25 04-17-2007 07:07 AM
Choosing a rigid fork EndoMaster The Workshop 8 04-05-2006 11:59 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
