My rear hope hub with less then 300 miles id guess on it is squeaking. I pulled it apart and lubed everything but it didnt fix and is very annoying. It is from what I can tell coming from the end caps(bulb and drive side spacer) that slightly press into a seal and then take the load once the QR is tightened. I can duplicate it on the bench but its 10x worse once fastened on teh bike. I have cleaned and lubed to no avail...
Any ideas? Remove all lube maybe?
Kris Hernandez |
^needs to ride more
When you understand why you dismiss all the other possible gods, you will understand why I dismiss yours. www.thepathbikeshop.com |
| New to STR | Red Hot Sloth | Introduce Yourself | 107 | 06-08-2008 11:42 AM |
| Hope this doesn't make you too *green* with envy... | sdyeti | General Discussion | 108 | 04-01-2008 09:03 PM |
| Red Hope Headset and Red Hope Stem | BrewMaster | The Market Place | 5 | 03-27-2008 07:09 PM |
| Hope Rotor - 183mm for Hope Mini | mntbiker12 | The Market Place | 5 | 12-18-2007 06:54 AM |
| Kam's Garage sale, feat. Seven, Hope, Syntace... | singleSSpeedster | The Market Place | 7 | 05-13-2006 11:18 PM |
