Old 06-09-2008, 06:25 PM   #1 (permalink)
Officially an OC local!
SDstumpy's Avatar
Default Brake Modulation?
What exactly is Brake Modulation? I have Avid Juicy 5's and I think the only adjustment I have is lever reach. Does lever reach also correlate to how much I have to pull before it engages the pads? Also, my brakes feel a bit mushy, meaning the levers don't spring back out very well. I just replaced the pads and the spider spring and bled the brakes. I wish the juicy's had a better feel. Is this how they are or is there an adjustment I can make.
Does upgradeitis ever go away?
SDstumpy is online now
Old 06-09-2008, 06:28 PM   #2 (permalink)
cjwally's Avatar
Modulation is the ability to exercise precise control over your brakes.... It isn't necessarily an adjustment.
cjwally is offline
SDstumpy (06-09-2008)
Old 06-09-2008, 06:50 PM   #3 (permalink)
I have UGI
dubjay's Avatar
If your brakes had zero modulation, they would lock instantly when you pull the lever.
That being said, brakes with good modulation allows for varying levels of grab, allowing you precise control over braking power.
It's not exactly something you can adjust. Some brake systems just inherently have better modulation than others, although some brake pads may offer better modulation because they don't lock up as easy.
dubjay is online now
cjwally (06-09-2008), onegymrat (06-09-2008), PassatBoy101 (06-11-2008), SDstumpy (06-09-2008), strobelite (06-11-2008)
Old 06-09-2008, 06:58 PM   #4 (permalink)
Knuckledragger's Avatar
Learn it.... Live it.....
Love,
C.K.
Knuckledragger is offline
Old 06-09-2008, 06:59 PM   #5 (permalink)
All my words are rubbish
Allrotor13b's Avatar
If your brakes feel mushy and your levers don't recoil, and you have already bled the system, then the seal on the piston in the master cylinder may need replacement. If that is the case, you're better off upgrading to better brakes anyway.
What's that smell?
Allrotor13b is offline
Old 06-09-2008, 07:46 PM   #6 (permalink)
SDstumpy's Avatar
thanks guys, yeah maybe I need to upgrade my brakes
Old 06-09-2008, 10:30 PM   #7 (permalink)
Winger's Avatar
Ride a bike with rim brakes for 2 weeks and you'll be amazed at the Juicy 5's modulation.
Winger is offline
cjwally (06-10-2008), DeeZee (06-10-2008), dubjay (06-10-2008), mechmann (06-11-2008)
Old 06-10-2008, 01:30 PM   #8 (permalink)
broom wagon
Juicy 5 has plenty of modulation and control over the power and wheel lockup.
Sounds to me like someone put his greasy hands on the rotor and/or pads. Sounds to me like contaminated pads are the problem and a dirty rotor ain't helping.
But that's just a guess.
I would disagree with Allrotor13b's comment. If he had a blown seal on the master cylinder piston it wouldn't be time for a new brake setup. Those seals are easy to replace and they cost about 1/50th (or less) of a new brake setup.
pastamon is offline
Chewyeti (06-11-2008)
Old 06-10-2008, 01:32 PM   #9 (permalink)
I have UGI
dubjay's Avatar
He's just used to those Wankel engines blowing - replacing seals on those are $$$.
Sorry..couldn't resist!
Old 06-10-2008, 01:42 PM   #10 (permalink)
broom wagon
That explains things a bit! I still remember the old Mazda commercial that said "piston engines go doo-whacka-doo-whacka-doo, but the Mazda goes hmmmmmmm." I remember the 1st gen RX-7 that had the fishbowl-like glass around the cockpit/cabin.
pastamon is offline
dubjay (06-10-2008)
Old 06-10-2008, 10:13 PM   #11 (permalink)
SDstumpy's Avatar
Pads are brand new and I cleaned the rotors with Brake Parts cleaner (the kind used on car brake parts). I was very careful not to get any contaminants on the brake pads or rotor. The brakes work fine, they just don't feel as nice as some brakes I've felt on new bikes...XT's namely.
Old 06-11-2008, 06:32 AM   #12 (permalink)
broom wagon
I swear, there's a lot of inferiority to be found in what you have if you want to get something new.
I don't know how you would say that the Shimano XT hydro feels better than the Juicy 5. How are you comparing them? Full rides on steep, tough terrain? Lever pull in a bike shop?
I think your tagline tells the story here -- you feel the Juicy 5 is "low end" and you want to get rid of it. If that's the case why did you start this thread, if you're just looking for an excuse to "upgrade" you don't need this thread. Are you trying to offer "proof" to your girlfriend, fiancee or wife? What's the deal?
pastamon is offline
RS VR6 (06-11-2008), SDstumpy (06-11-2008)
Old 06-11-2008, 06:35 AM   #13 (permalink)
Kritter's Avatar
New bikes always feel better wether its brakes, shifting, rolling, etc...its like a new girl.
Kris Hernandez
Kritter is offline
Old 06-11-2008, 07:31 AM   #14 (permalink)
ubermensch's Avatar
IMO, the bore and stroke of the plunger inside the master cylinder, along with the orientation of how force is applied to that plunger by the lever has most to do with how a braking system feels. Aside from buying a new master, those things you can't change.
The only options I can think of for you is to either change brake pads, or somehow rule out the possibility that it's the way you are bleeding your brakes. If you ride other bikes with juicy 5s and they feel the same as yours, then it's probably just the brakes themselves.
Tom
ubermensch is offline
Old 06-11-2008, 08:22 AM   #15 (permalink)
wild in the streets!!!
chongoblanco's Avatar
DID you bleed your brakes yourself? or did you have a shop do it? They could not have been bled right.
How old are your juicy's sometimes you need to change your fluid due to what they call boiling the fluid.
juicy 7's are the same as juicy 5's if you are looking to upgrade, the only difference is that the 7's have a pad contact adjustment knob which helps with modulation.
Depending on your budget for upgrades, brakes with multiple pistons are going to give you tons of modulation.
2 piston with a mono block caliper will work and modulate better than a 2 piece caliper, example: jumping from juicy 7's, to juicy ultimates.
after that your lurking over to the more freeride/downhill brakes such as 4&6 piston brakes with large diameter rotors.
for A.m and everyday trail use I would recomend a dual piston with a mono/ 1 piece caliper! you will be amazed with the preformance increase.
cheers
YOU ARE NOT HOW MUCH MONEY U HAVE IN THE BANK, YOUR NOT THE CAR U DRIVE, YOUR NOT THE CONTENTS OF YOUR WALLET, YOUR NOT YOUR @#$%ING KHAKIS... YOUR THE ALL SINGING ALL DANCING CRAP OF THE WORLD. {TYLER DURDEN}
chongoblanco is offline
Old 06-11-2008, 08:26 AM   #16 (permalink)
saved by trailjesus
supralight's Avatar
i've got some j5's and i need some new seals on the lever bleed screws. can i get those at a lbs or do i need to contact avid?
supralight is offline
Old 06-11-2008, 08:32 AM   #17 (permalink)
All they are is a tiny o-ring a shop can probably contact avid for some replacements, to save some time shoot them an e-mail to see if they know what size and type it is and cruz over to a hydraulics or industrial harware supply like Mcfaddendale hardware or Anderson Hydraulics in orange.
Just a thought.
Old 06-11-2008, 04:44 PM   #18 (permalink)
Macross Frontier
RS VR6's Avatar
Man...that's one of the true-est things I've read in quite some time!
Cycle World
RS VR6 is offline
Old 06-11-2008, 10:18 PM   #19 (permalink)
SDstumpy's Avatar
Can't argue with that.
I don't know how you would say that the Shimano XT hydro feels better than the Juicy 5. How are you comparing them? Full rides on steep, tough terrain? Lever pull in a bike shop?.
just comparing lever pull. just doesn't feel the same since changing the brake pads. A bit mushy
No, but that is a good idea next time I do need proof that I need a new bike.
Wanted to know what modulation meant and whether it was an adjustment I can make. Sounds like I just need to try bleeding them again.
Hayes Disc Brake 5" Rotor BobBurnes The Workshop 6 02-25-2008 03:55 PM
Avid Hyd. Disc Brake Upgrade question amor587 The Workshop 5 11-29-2007 02:00 PM
Hayes Brake Rotors & Pads project_d The Workshop 10 10-17-2007 08:40 PM
Check your brake cables UR2KLOS General Discussion 15 09-06-2007 11:28 PM
Brake lever pin missing Paul000 The Workshop 4 08-07-2007 11:09 AM
Copyright
