Old 06-09-2008, 02:22 PM   #1 (permalink)
Pedal Damn It
davidB's Avatar
Default Rear hub problemo
Hope pro II, all of about a dozen rides on it.
I noticed yesterday when walking my bike my crankset would spin with the rear wheel ala fixed gear-ish if i'm not on it.
I probably did something when replacing the cassette and had the freehub itself and the endcap come off.
anywho, where should i be looking first to fix it?
davidB is online now
Old 06-09-2008, 02:28 PM   #2 (permalink)
The Real Slim Shady
Chaos's Avatar
my I9 for my Niner does the same, but it doesn't bother me so much.
this happened when it was new and still does after being serviced by The Path last month. it would be nice to know what's causing this though.
Chaos is online now
davidB (06-09-2008)
Old 06-09-2008, 02:30 PM   #3 (permalink)
Default Ride it
My guess is that once it get's broken it in will lossen-up
Had that happen with a King hub a few years back
davidB (06-09-2008)
Old 06-09-2008, 02:33 PM   #4 (permalink)
Pedal Damn It
davidB's Avatar
nah, it worked just fine right off the bat. I know this because there was a handful of times I pushed my bike down the driveway late at night next to the neighbor's window knowing that the sound of the hub is probably waking them up. Now, no more sound.
Old 06-09-2008, 02:35 PM   #5 (permalink)
wierd... mine dont do that.
Too much grease?
-Aaron or Chewy
VOODOO Canzo 29er
Chewyeti is online now
Old 06-09-2008, 02:35 PM   #6 (permalink)
aka Rogue Rider
Mondo's Avatar
Sounds like something relatively minor and simple -
Get it in to your LBS to have it looked at; The Path services Hope hubs pretty regularly and they can help...
Have you ever danced with The Devil by the pale moonlight?
Mondo is offline
Old 06-09-2008, 02:36 PM   #7 (permalink)
Default Oh
Didn't realized it worked fine at first
Old 06-09-2008, 02:49 PM   #8 (permalink)
david, take a look at the plastic seal that is attached to the freehub.. you need to push 3/4 of it into the grove on the hub shell and then use something like a flat head screwdriver to push the remaining part of the seal in. It will snap into place and work like it should..
BrewMaster (06-09-2008), Chewyeti (06-09-2008), davidB (06-09-2008), SAR_boats (06-09-2008)
Old 06-09-2008, 02:50 PM   #9 (permalink)
Will work for Trails
DISCO's Avatar
Hubs are really easy to adjust on your own, just follow these simple steps.
1. firmly clamp in bench vise.
2. Use MAPP gas and a Claw hammer to loosen things up
3. Adjust with a pipe wrench or vise grips
4. Slather everything with crisco for maximum longevity
5. Re-install for the ride of your life!!
DISCO is online now
Old 06-09-2008, 02:52 PM   #10 (permalink)
Pedal Damn It
davidB's Avatar
thanks, but huh? Once I get home and look at it i'm sure this will make sense
however, i found this thread
http://forums.mtbr.com/showthread.php?t=283367
showing how to rebuild it, so.....
banksd1983 (07-31-2008)
Old 06-09-2008, 03:00 PM   #11 (permalink)
take a look at this picture
http://forums.mtbr.com/attachment.ph...1&d=1175311134
it shows the seal i am talking about.. when you take the cassette off it will all make sense.. even one of The Path mechanics did not know about it
davidB (06-09-2008)
Old 06-09-2008, 03:23 PM   #12 (permalink)
To much bearing tension, lack of grease, need of servicing? Time to take it apart.
Having never owned Hopes can't comment. But when my Kings do that it means service time.
Old 06-09-2008, 03:24 PM   #13 (permalink)
Car Magnet
Nam (TKBlazer) nailed it. If the freehub came off when you were working on the cassette then the black labirynth seal that goes between the freehub body and the hub shell is not in its correct groove. Using a plastic tirelever or other dull bladed instrument, push one side of the seal into the groove and hold it in place with a finger while you work the tool around the seal, pressing the rest into the groove. This can be a little difficult if you have never done it before but keep at it.
BrewMaster (06-09-2008), davidB (06-09-2008), DeeZee (06-09-2008), Pho'dUp (06-09-2008), tkblazer (06-09-2008)
Old 06-09-2008, 10:15 PM   #14 (permalink)
Pedal Damn It
davidB's Avatar
man you guys are awesome.
it was a simple little seal, i could ask how that prevents it from working correctly but that'll probably go over my head. I checked the seal and sure enough about a 1/4 of it was raised out of it's groove. Pushed it in with the screwdriver on my multitool and bam it works sweet sweet buzz of the hubs are back
speckledtrout (06-09-2008), tkblazer (06-10-2008)
Old 06-10-2008, 07:39 AM   #15 (permalink)
glad i could help another STR rider and Air9 owner
Old 06-10-2008, 07:41 AM   #16 (permalink)
cjwally's Avatar
Sweet...I now will know what to do with my HPII's in case of that problemo... Thanks.
cjwally is offline
Deciphering rear shock size jonv05 General Discussion 4 06-09-2008 10:45 AM
Rear D question? Is this a suitable replacement for 8spd rear BAD_S197 General Discussion 22 06-07-2008 08:01 AM
Nevegal as rear tire? ryandood The Workshop 26 04-29-2008 09:56 PM
Iron Horse MKIII Broken rear Triangle dudevf1 The Workshop 24 04-15-2008 09:39 AM
Chris King finally makes 150mm rear hubs tkblazer General Discussion 5 09-10-2007 03:42 PM
