Old 06-08-2008, 09:08 PM   #1 (permalink)
^needs to ride more
davidB's Avatar
Default aarrrrggh....26" tube in 29er?
what's the damn trick to this?
I've heard of adding a few psi to the tube to get it. That ain't working. And i'm about to give myself blisters on both thumbs like I did last time.
Originally Posted by AdrenalineBikes on 3/31/08
I have 3 sets back ordered with Stans so once I hear from them I will let you know.
-still waiting. lolz
davidB is online now
Old 06-08-2008, 09:12 PM   #2 (permalink)
Dusty Dirt Devil
richie_rich's Avatar
You really couldn't stretch the tube to fit?
Blow it up quite a bit outside the tire...it will get huge then tuck it in the tire with half the tire on the rim, then let some air out. This should make quick work of it for you.
Let me know if it works...never tried it myself
SHEDEVIL: "Haven't you ever seen me grab my crotch going downhill?"
"The world is small and the trails are smaller, so when you see another biker smile and wave, you never know who you might meet."
richie_rich is offline
davidB (06-08-2008)
Old 06-08-2008, 09:19 PM   #3 (permalink)
Stretch it over the rim and pump it up. I've done it with 26" Slime tubes and never had a problem.
You should just go tubeless on your rims. Yellow tape + valve stem + Stan's and you're done.
davidB (06-08-2008)
Old 06-08-2008, 09:25 PM   #4 (permalink)
^needs to ride more
davidB's Avatar
que?!!!!!!!!!! I can get a 29er tube on obviously but the last 10" of the bead is starting to piss me off.
If I had some rim tape i'd be on this. But SM8's = hard to set as tubeless
inb4tubelesscrossmark is better
Old 06-08-2008, 09:33 PM   #5 (permalink)
It sounds like you may be missing the trick. You want to get the tube fully over the rim before you install the second half of the tire. You'll have to experiment with pressure to make it work.
Years ago, I used to use 16" tubes in my 20" BMX bikes and 20" tubes in my 24" bikes - there's a lot less material to stretch than a 26 to 29 install.
davidB (06-08-2008), mtnbikerfred (06-08-2008)
Old 06-08-2008, 09:52 PM   #6 (permalink)
I stretch the tube by inflating it overnight before trying in install it in a tire. Also work the tube/tire on the rim from the opposite side of the stem. The stem will hold the tube in the channel while you work your way around.
dstepper is online now
davidB (06-08-2008)
Old 06-08-2008, 10:11 PM   #7 (permalink)
I poached, and got busted
singleminded's Avatar
Default Just play around with it...
Pratice makes perfect. I have never run a 29 tube...but did a lot of cursing in the begining
I usuallt put a little air in it so it pops on the rim and helps hole it in place
Eric
"Pain is nothing compared to what it feels like to quit"
singleminded is online now
Old 06-08-2008, 10:35 PM   #8 (permalink)
Why put a 26" tube on a 29" rim?
DeadlyStryker is offline
Old 06-08-2008, 10:38 PM   #9 (permalink)
^needs to ride more
davidB's Avatar
because they can fit (though I gave up and threw in a 29er tube until I go tubeless tomorrow or so). A lot of "lightweight" tubes out there are 26" as well, which is what I was trying to fit in.
banksd1983 (07-31-2008)
Old 06-08-2008, 11:06 PM   #10 (permalink)
I made a Taco this big!
For race days I use Spec. 26" Turbo Tubes in 29" stan's rims
Works so far.
Pho'dUp is offline
26" tube on your 29" wheel? station Trail Talk 9 01-20-2008 09:58 PM
Reba Race 29er, Pace RC31 29er, Moots stem Uncle Rico The Market Place 9 01-20-2008 08:16 PM
Medium Voodoo Aizan Scandium 29er 3.5lbs and other 29er stuff duke777 The Market Place 3 12-11-2007 09:45 AM
Sizing and head tube angle help please dirtmistress General Discussion 11 12-11-2007 08:45 AM
inner tube slippage gurp13 The Workshop 17 09-18-2006 09:44 PM
