Old 06-05-2008, 12:14 PM   #1 (permalink)
Default XT cranks keep moving
so I installed these and tightened them down (non-drive side) and it keeps backing out on me. normally its snug up against the bb what am i doing wrong here?
the sticker says 15lb on the bolts so i didnt want to over torque it but i cab kick it and it'll move in
thoughts?
www.coverageispersonal.com
foofighter is online now
Old 06-05-2008, 12:15 PM   #2 (permalink)
Default .......
thoughts?
make sure you have 29'er cranks
BrewMaster (06-09-2008), foofighter (06-05-2008), jschwart73 (06-05-2008)
Old 06-05-2008, 12:17 PM   #3 (permalink)
Pedal Damn It
davidB's Avatar
i keep getting the same thing on my xt and xtr cranks, though that's just because i installed them myself. Actually on the way to the garage right now to fix both sets.
davidB is online now
Old 06-05-2008, 12:18 PM   #4 (permalink)
pitmang1's Avatar
I had that issue with an xtr BB and Race Face arms. It turned out that I needed an extra spacer (1mm) on the drive side.
pitmang1 is offline
Old 06-05-2008, 12:25 PM   #5 (permalink)
Restepct.
Zippo's Avatar
+1 on the spacer. As far as Race Face goes, it's an elastomeric preload spacer. If you have a 68mm shell you need 2 (one on each side), 73mm you just use one on the drive side.
Vertigo I can handle alright — It's horizonto that drives me nuts.
Zippo is online now
pitmang1 (06-05-2008)
Old 06-05-2008, 12:25 PM   #6 (permalink)
weird because when i had this crank on my ellsworth epiphany it didnt have that problem so you think i need a spacer on the drive side?
Old 06-05-2008, 12:27 PM   #7 (permalink)
Default +2
Originally Posted by Zippo View Post
+ on the spacer. As far as Race Face goes, it's an elastomeric preload spacer. If you have a 68mm shell you need 2 (one on each side), 73mm you just use one on the drive side.
or you are missing the plasitic bolt on the arm (doubt it)
Old 06-05-2008, 12:28 PM   #8 (permalink)
no i think you're right i may just need a spacer
Old 06-05-2008, 12:29 PM   #9 (permalink)
Is this thing on?
station's Avatar
I think I have the perfect solution to your problem:
station is offline
Old 06-05-2008, 12:29 PM   #10 (permalink)
.8down's Avatar
how did you tighten them? did you get your own external BB tool? I got a few spacers at my place if you need em...
.8down designs
.8down is offline
Old 06-05-2008, 12:29 PM   #11 (permalink)
Default .....
yes. It sounds like the Ells has a 73 and the new bike has a 68.
Old 06-05-2008, 12:30 PM   #12 (permalink)
I have UGI
dubjay's Avatar
Sticker says 12-15 N-m - Newton meters. So that's more like 8-11 ft/lbs..but anyways..I would check the need for spacers as well.
dubjay is offline
Old 06-05-2008, 12:31 PM   #13 (permalink)
.8down's Avatar
your bike is even more human powered!!!????
.8down designs
.8down is offline
DeeZee (06-05-2008), foofighter (06-05-2008), station (06-05-2008)
Old 06-05-2008, 12:32 PM   #14 (permalink)
yah i broke down and finally bought that and a cassette tool
Old 06-05-2008, 12:33 PM   #15 (permalink)
on a routine expedition
Marshall Willanholly's Avatar
Does it say 15 in/lbs or 15 N/m? I seem to remember it being 15 N/m, which is 132.75 in/lbs.
2wheel_lee (06-05-2008), foofighter (06-05-2008)
Old 06-05-2008, 12:33 PM   #16 (permalink)
.8down's Avatar
haha, I broke down and got niffty Headset tools, with the amount of bikes I tear down and build I need it.
.8down designs
.8down is offline
Old 06-05-2008, 12:41 PM   #17 (permalink)
Uncle Rico's Avatar
I was having the same problem, ended up having to replace the nondrive crank arm. The threads started to strip inside the arm and it was the only fix according to LBS at that point.
Make sure you get it torqued down right.
Uncle Rico is offline
DeeZee (06-05-2008)
Old 06-05-2008, 12:42 PM   #18 (permalink)
you're right it's Nm, the two bolts dont seem to be stripped they're tight on there i just thing that i need a spacer on the non-drive side...that would be funny if that crank falls off...NOT
Old 06-05-2008, 12:43 PM   #19 (permalink)
Incorrect.
If you have a 68 mm shell, you need two 2.5 mm spacers on the drive side, and one 2.5 mm spacer on the non-drive side.
My memory recalls the same thing. I think it's 13-15 Nm. Shimano's site is down now, so I can't check.
2wheel_lee is online now
DeeZee (06-05-2008)
Old 06-05-2008, 12:43 PM   #20 (permalink)
Team America! F*K Yeah!
duke777's Avatar
if your bb is 68mm you will need 2 spacers on the drive side and one on the none drive side. The extra one on the drive side is for the Etype mech.
73mm BB you only need one on your drive side. and 73mm with Etype then no spacer.
make sure you alternate tightening the pinch bolts
make sure you measure your BB shell
Hi my name is Duke777 and I'm a Ti-holic.
duke777 is offline
