The RP23 allows you to adjust ProPedal (3 levels even), which I use often. I leave ProPedal on for the (smooth) climbs and open it up for the downhills.
I would definitely spend the extra cash, but ultimately it's up to you. |
Pho'dUp (05-27-2008)
I made a Taco this big!
For $100 bucks more, do it. The extra tunability is worth it. Unless you luck out and the Float R is tuned pretty close to your bike, riding style and weight.
dubjay (05-27-2008)
www.lostmanifesto.com
Well worth it. A friends bike has the Float R and I can feel a good difference between that and my old RP23. The Pro Pedal alone is worth $100 IMO.
Pro beginner
Love the RP23 here as well. I've been doing DH race runs at Fontana with it and it just performs. No complaints at all.
Matt13 "Dont I feel stupid..... I read the thread title, not once, but twice as "Our Reindeer Lives". And I thought, who the hell owns a reindeer????" |
Team Sting-Ray
Probably depends on your suspension design. If you have a frame that's already designed to be a stable climber (DW Link, VPP), there's little point in having ProPedal. You'll see much more benefit on something like a single-pivot.
guero: "it's so good once it hits your lips!" |
cookie monsta
I agree with ODB here. My RIP9 pedals so well I never flip the pro-pedal on, even on extended climbs. The RIPs suspension design is similar to the VPP design found on some SC and Intense models.
If your rear suspension design doesn't isolate pedaling forces very well, or you are a "stand on it and mash it" kind of climber you would be well advised to spring for the RP23 which does all the wonderful things already mentioned. |
ProPedal is a crutch for poorly designed suspensions.
Bring on the flames. I felt like I lost a lot of small bump sensitivity with the ProPedal. When I went to a shock like a Cane Creek Cloud 9 or Vanilla Coil with no ProPedal, it is way more plush on very efficient suspension designs and I was able to climb just as well. |
cookie monsta
The difference is in the number of adjustments you can make. It goes something like this:
Float R = rebound adjust only Float RP2 = rebound and platform on/off Float RP23 = rebound, platform on/off, and 3 platform settings Float RP3 (older model) = rebound, 3 platform settings In short, with the RP23 you can turn the platform on or off as well as setting the amount of platform amongst 3 levels, where with the RP3 it is on and you control how much platform (1, 2 or 3) with the adjustment lever. |
Lebowski Urban Achiever
+1 vote for the RP23 over the R.
I've had each, and the 23 is way more tunable.
Just because the bike can do it doesn't mean the rider can! "My ass is sore after a long ride." - MtnKitty " If you feel like you're going fast, you are!" -CalEpic |
ive got the R and its okay. i think the guide for pressure is a bit high as it says to use 200 for 200lbs. but ive found that i like to run it at ~ 160ish. at that point its al dente for lack of a better term. ive been pretty happy with it so far. i always carry my shock pump and if im going to be doing a lot of climbing, i'll just bump up the pressure (~180psi) or crank the rebound knob to the "hard" position (depends on the terrain) and grind it out. good product!
| New Fox Float R (r/shock) $150 | richie_rich | The Market Place | 0 | 04-29-2008 03:22 PM |
| Rock Shock Reba Race vs Fox Float rlc | SDstumpy | General Discussion | 5 | 04-21-2008 11:02 PM |
| Fox Float R rear shock | dhshuttlemonkey | The Market Place | 6 | 04-06-2008 04:21 PM |
| 2006 Fox float RLC fork | SAR_boats | The Market Place | 0 | 09-06-2007 09:30 AM |
| mmmm, a delicious Vanilla Float | pollu_sean | The Workshop | 17 | 08-20-2007 10:58 PM |
TURNER HOMER
